Session 15 - Playfield top wall displaying 2x as large
3 replies to this topic
#1 samcan OFFLINE
samcan
    Combat Commando
  • 1 posts
Posted Sun Apr 7, 2019 4:40 PM
Hi, I tried the exercise from Sessions 14-15 to draw a box around the playfield. But my code is rendering funky in both Stella and z26. In Stella, the top wall is rendering twice as thick as the horizontal walls, while the bottom wall is the same thickness as the horizontal walls. (My understanding is that the top wall should be the same thickness.) In z26, the top wall is roughly 4x thicker than the horizontal walls, with a corresponding black gap at the bottom of the screen with a thin red line below that.  I tried Andrew Davie's exercise code provided in Session 15, and the output looks very similar to mine in both Stella and z26, not matching what the screenshot shows. Though his has a black background (mine has the rainbow background), he still has the extra thick top wall, and in z26, the black gap on the bottom.
I'm using z26 3.02.01, and Stella 6.0. I'm compiling my code with dasm 2.20.11:
dasm.exe "..\..\Documents\Docs\@Inbox\atari\playfield-3.asm" -lplayfield-3.txt -f3 -v5 -oplayfield-3.bin
My code follows:
				processor 6502
				include "vcs.h"
PAT_PF0_THICK			= %11110000
PAT_PF0_THIN			= %00010000
PAT_PF_THICK			= %11111111
PAT_PF_NONE			= %00000000
				SEG
				ORG $f000
; Clear RAM and all TIA registers
Reset
				ldx #0
				lda #0
Clear
				sta 0,x
				inx
				bne Clear
				; once-only initialization
				lda #$45
				sta COLUPF
				; mirror the playfield
				lda #%00000001
				sta CTRLPF
				ldy #0
StartOfFrame
				; vertical sync
				lda #0
				sta VBLANK
				lda #2
				sta VSYNC
				sta WSYNC
				sta WSYNC
				sta WSYNC
				lda #0
				sta VSYNC
				; vertical blank
				ldx #0
VerticalBlank			sta WSYNC
				inx
				cpx #37
				bne VerticalBlank
				; start drawing picture
				ldx #0
				; start drawing top wall
				lda #PAT_PF0_THICK
				sta PF0
				lda #PAT_PF_THICK
				sta PF1
				sta PF2
PictureTop			sta WSYNC
				inx
				cpx #8
				bne PictureTop
				; start drawing main area
				lda #PAT_PF0_THIN
				sta PF0
				lda #PAT_PF_NONE
				sta PF1
				sta PF2
PictureMain			stx COLUBK
				sta WSYNC
				inx
				cpx #184
				bne PictureMain
				; start drawing bottom wall
				lda #PAT_PF0_THICK
				sta PF0
				lda #PAT_PF_THICK
				sta PF1
				sta PF2
PictureBottom			stx COLUBK
				sta WSYNC
				inx
				cpx #192
				bne PictureBottom
				; overscan area
				lda #%01000010
				sta VBLANK
				ldx #0
Overscan			sta WSYNC
				inx
				cpx #30
				bne Overscan
				jmp StartOfFrame
				ORG $FFFA
InterruptVectors
				.word Reset
				.word Reset
				.word Reset
				END
Thank you.
#2 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Sun Apr 7, 2019 5:02 PM
I just tried this code on an actual console, and the output matches Stella 6.0 exactly (well, except the colours are slightly different, but that's to be expected).  z26 hasn't been updated in many years, and I recommend to do all further testing in Stella.
#3 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,933 posts
Posted Mon Apr 8, 2019 1:50 PM
Aside from not being updated in (nearly) a couple of decades, z26 was only useful for producing a detailed trace file...but that isn't needed with Stella's current version, since the time machine function is more convenient.  Plus you get real-time results when altering things on-the-fly, which is impossible to do with z26.
#4 Andrew Davie OFFLINE
Andrew Davie
  • 1,837 posts
  • Dr.Boo
Posted Tue Apr 9, 2019 5:43 AM
Try setting PF0, PF1 and PF2 to 0 after the PictureBottom loop
Edited by Andrew Davie, Tue Apr 9, 2019 5:44 AM.
