Lynx I McWill Battery Question
9 replies to this topic
#1 Izen OFFLINE
Izen
    Star Raider
  • 63 posts
Posted Mon Apr 8, 2019 12:26 PM
Hi everyone,
I recently upgraded my Lynx I with a McWill LCD. Everything works great, but today I was playing and then the music from the game stopped, and the screen got fuzzy. The batteries got hot, so I immediately removed them. I tried a different set of batteries and everything seems fine. I checked the voltage when I did the upgrade and my Lynx was at 5.01v, so I did not replace the MOSFET. Could this be why the batteries got hot (aside from use)?
#2 McWill OFFLINE
McWill
    Moonsweeper
  • 253 posts
Posted Sat Apr 20, 2019 8:12 AM
Hi everyone,
I would recommend to install the 5-Volt mod (RECOM DC/DC) to prevent any damages caused by a faulty zener diode. The original power circuit is a ticking time bomb. Also if the zener diode is new.
#3 Izen OFFLINE
Izen
    Star Raider
  • 63 posts
Posted Sat Apr 20, 2019 8:43 AM
Hi McWill! First off, thanks so much for the work that you do. I'm loving this screen and I purchased one for my Game Gear. Might even buy a Lynx II just for another screen.
So far it's been running fine, but on batteries, after a while, they get a little warm, but I've been using my AC adapter and it seems fine. The only game that got warm for me was Dracula The Undead. I'd rather not do the 5V mod if I don't have to, so would you recommend that I also replace the zener diode to help protect it? Thanks!
#4 McWill OFFLINE
McWill
    Moonsweeper
  • 253 posts
Posted Sat Apr 20, 2019 10:34 AM
Thank you ;-)
I would do the 5-Volt mod, but it's up to you. I had a working LYNX-II for testing my LCD mod kits and it was working fine. But after thousands of times switching it on and off, the zener diode got broken and my LYNX and the tested mod kit were "fried" (because the complete voltage of the power supply went through the LYNX - about 9-15V!)
#5 Izen OFFLINE
Izen
    Star Raider
  • 63 posts
Posted Sun Apr 21, 2019 8:32 PM
Thank you ;-)
That's crazy! I can see why you would put that in the instructions. In terms of voltage I am getting the required 5V. Are there specific instructions for doing the 5V mod to the Lynx I and are there any negatives to doing it?
#6 McWill OFFLINE
McWill
    Moonsweeper
  • 253 posts
Posted Mon Apr 22, 2019 2:29 AM
Look here: http://atariage.com/...-atari-lynx-ii/
#7 Izen OFFLINE
Izen
    Star Raider
  • 63 posts
Posted Mon Apr 22, 2019 5:59 AM
I saw that post before, but it's for a Lynx II. I have the Lynx I, but would the components that need to be removed the same for both?
Edited by Izen, Mon Apr 22, 2019 6:00 AM.
#8 karri ONLINE
karri
  • 2,693 posts
Posted Mon Apr 22, 2019 7:21 AM
Lynx I has a soldered LCD so the removing process is very different from Lynx II.
Console 5 has  nice wikipedia describing where the caps, zener and MOSFET is located on a Lynx I. The parts are also slightly different for both consoles.
Edited by karri, Mon Apr 22, 2019 7:26 AM.
#9 McWill OFFLINE
McWill
    Moonsweeper
  • 253 posts
Posted Mon Apr 22, 2019 3:32 PM
For LYNX-I also look here:
https://circuit-boar...u-SMD-Variante/
It's in german, but Google Translate will help you ;-)
#10 Izen OFFLINE
Izen
    Star Raider
  • 63 posts
Posted Mon Apr 22, 2019 3:46 PM
Thanks so much!
