Retro-Bit Sega Genesis 6 Button Arcade Pad Review & Comparison
Retro-Bit Sega Genesis 6 Button Controller
8 replies to this topic
#1 Jin OFFLINE
Jin
    Solar Striker
  • 3,219 posts
Posted Sun Apr 21, 2019 2:01 AM
Hey there guys and gals! :) This afternoon I got a couple of Retro-Bit's new 6 Button Sega Genesis controllers in the mail from Amazon, and since a lot of folks around here have been curious about them I thought I'd take a few minutes to do a little review of these controllers and compare them to Sega's own 6 button controller from back in the day. First off let's take a look at the packaging.
Retro-Bit did a really nice job on the box, which as far as I can tell looks almost identical to the boxes that Sega shipped their 6 button controllers in back in the 90's. The plastic insert inside the box that holds the controller in place is rather flimsy feeling, but the controller it holds is most certainly not. To cut straight to the chase, let's take a look at Retro-Bit's offering next to an original 6 button Genesis controller from 1994 that I purchased brand new on eBay a couple months ago and have only put a few hours of use on since then.
From the outside it's clear that Retro-Bit's partnership with Sega on this project was a fruitful one. The color, feel, fit and finish of the controller's shell is absolutely identical to the original Sega controller and the cord looks and feels the same as well; with the only difference being that the Retro-Bit controller features a 10 foot long cord as opposed to the 6 foot cord on the Sega controller. Aside from the lack of a "TM" next to the Sega logo on the front and the addition of the Retro-Bit logo on the back, the text on the controller is just the same as the original and the only obvious difference is that the finish on the D-pad and A/B/C buttons on the Retro-Bit controller have a soft matte texture to them whereas the D-pad and A/B/C buttons on the original controller are slightly glossy. As long as we're on the subject of the D-pad and buttons, when pressed down the only difference I could feel between Retro-Bit's D-pad and buttons and the original were that the Retro-Bit ones required ever so slightly more pressure to activate; somewhere in the area of 3 to 5 grams of actuation force if I had to venture a guess.
To give them a proper test with a fairly demanding game I popped Mortal Kombat II into my Genesis and first did a full play through of the tournament mode with my original Sega controller, then upon beating the tournament did a second play through with the Retro-Bit controller. After two play through's of MK II's tournament I'm pleased (and a little surprised, to be completely honest) to say that I could find no discernible difference in build quality or function between Retro-Bit's new Genesis controller and Sega's original from 1994. During the 45 minutes or so I spent playing through MK II's tournament mode with the Retro-Bit controller I never once experienced a false input and in practice the tiny bit of extra force required to move the D-Pad and buttons was negligible. My thumbs didn't feel any more tired after playing with Retro-Bit's controller than Sega's and none of my movements felt any slower or less precise.
In order to get a better idea of why Retro-Bit's controller performed every bit as good as Sega's original, let's open them up and take a look inside.
Peering inside, it quickly becomes apparent why Retro-Bit's new Genesis controller performs so well. It is in every respect, down to the millimeter, an exact copy of the original Sega design. They are so identical that I would be very surprised if they weren't using the same mold that the originals were made with. With the exception of the screws that secure the two shell halves together (which are slightly longer on the Sega controller) every part is 100% interchangeable between the two controllers. In fact, when I swapped the silicone button and D-pad contact pads from the Sega controller into the Retro-Bit one the actuation force required to press the D-Pad and buttons became exactly the same as the Sega controller had; which makes it pretty clear that the only reason the Retro-Bit controller's buttons and D-pad required a tiny bit more force to press is because it has brand new silicone pads in it and the Sega controller's silicone pads are about 25 years old at this point.
The especially nice thing about Retro-Bit's controllers being internally identical to the original Sega ones is that if you do ever manage to wear out the silicone button contacts or any other part then they can be easily replaced with any of the numerous replacement parts on the market made for Sega's original controllers. With that future proofing in mind I give Retro-Bit's Sega Genesis 6 Button Arcade Pads my highest recommendation.
Never in my life have I encountered a third party controller for any system that was such a perfect copy of the original first party controller as these, and at only $15 each and officially licensed by Sega there's absolutely no reason whatsoever that I can think of to go try and hunt down a used original Sega controller when Retro-Bit's new Genesis controllers are available. They are, for all practical purposes, the exact same controller. Whether your looking for some top quality wired controllers to pair with your new Analogue Mega Sg or just need a good controller or two for your trusty old Genesis, I don't think you'll find a better option than Retro-Bit's Sega Genesis controllers anywhere; past or present.
Edited by Jin, Sun Apr 21, 2019 2:58 AM.
#2 Defender_2600 OFFLINE
Defender_2600
    Dragonstomper
  • 577 posts
Posted Sun Apr 21, 2019 4:44 PM
Great Review & Comparison! Thank you! :)
#3 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,189 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Mon Apr 22, 2019 7:28 AM
Yes I finally played some wolf3d using my new retro-bit controller on my Genesis this weekend. It pretty much felt the same as my normal 6-button Sega pad I use and didn't have any ghosting direction issues etc that I've had with other third party controllers in the past. I opted for the clear blue shell controller and it looks fantastic!
There is one very slight difference on the boxes that these come in compared to the original Sega ones. The Genesis logo is embossed with a shiny foil to make it stand out more. I seem to recall the originals were just printed with black lettering on them. Yes..yes this doesn't have anything to do with the controller themselves, but it sure does make the rest of the presentation look that more snazzy!
  • Jin likes this
#4 Austin OFFLINE
Austin
  • 13,033 posts
Posted Mon Apr 22, 2019 8:38 AM
Excellent stuff. I don't really *need* these since I already have some official six button pads, but I may still grab one anyway. Them pretty much being a perfect 1-to-1 of the originals makes me happy. I can't say the same for the one Hyperkin put out many years ago.
#5 Yurkie OFFLINE
Yurkie
    Q*bert Champion
  • 4,090 posts
  • US Distributor for NESRGB and 2600RGB
Posted Sun Apr 28, 2019 12:13 PM
Thanks Jin for the review! It is great to hear positive news like this.
Be awesome if they would make a new 3 button version!
#6 zborgerd OFFLINE
zborgerd
    Space Invader
  • 11 posts
Posted Wed May 1, 2019 9:05 PM
Thanks for the pictures and write-up. I was looking everywhere for info on this.  I was going to tear mine down but I don't have any originals (only Hyperkin GN6) to compare them to. These feel much better. Shorter button throw and a better d-pad than my other third party 6 button controllers. So glad that classic gaming just keeps getting better and lives on. Now, to find one for the Saturn.
#7 Lord Thag OFFLINE
Lord Thag
  • 3,643 posts
  • We put our faith in Blast Hardcheese
Posted Fri May 3, 2019 8:20 AM
These are very good, but the 8bitdo wireless Genesis pads are so damn good, I rarely use anything else these days.
Great review and teardown!
#8 Dr Manhattan OFFLINE
Dr Manhattan
    Dragonstomper
  • 731 posts
Posted Tue May 21, 2019 9:25 AM
This is an outstanding and very informative review. I love these controllers and they deserve more exposure. Excellent quality stuff. Thanks for posting this.
  • Jin likes this
#9 BrianC OFFLINE
BrianC
  • 1,734 posts
Posted Yesterday, 11:27 PM
There is also talk about the controllers here. I liked the controllers quite a bit myself, but the response here was more negative and the controller is lumped in with the GN6 and Old Skool clones. Also, while the controller is close, the pad presses down, unlike many of the originals. I didn't feel it affected anything, though.
Also tagged with one or more of these keywords: Retro-Bit, Sega Genesis, 6 Button, Controller
