flashjazzcat Posted May 8, 2019 Share Posted May 8, 2019 That must be why RespeQt claims it has 722 sectors, IIRC. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 8, 2019 Share Posted May 8, 2019 (edited) There is a possibility that they are not SpartaDOS, I used to 'tinker' with most DOS's to see if they could operate at high speed too, I did manage this with SmartDos and possibly others, so it may be my boot code is fouling things up. Unfortunately I have lost most of the code I wrote due to a lot of my floppys degrading so badly they are unreadable. I'll try your reccomendation and use a 'real' ROM we have become very good at reading the unreadable disks, please allow one of us to recover your data, preferably with a Super card pro owner or Kryoflux owner, the next choice would be someone who has modified drives or double headed drives (like the xf) to pull the data with the typical gentle disk clean up and of course clean polished drive heads. There are several threads full of tips on how and what to do also Edited May 8, 2019 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted May 8, 2019 Share Posted May 8, 2019 So... I wonder what old version of SIO2PC software created these bad ATR's then? Would be ironic if Nick Kennedy's own software strayed from the spec, but then again, reading this page about the early developments, double density support was added incrementally, and he was still figuring out how to do UltraSpeed.. ( circa 1992-1995) http://pages.suddenlink.net/wa5bdu/readme.txt Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 8, 2019 Author Share Posted May 8, 2019 I can confirm I created these ATR's using SIO2PC from Nick Kennedy in 2010. 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 8, 2019 Share Posted May 8, 2019 I've just added support for this aberrant DD ATR in the U1MB/Incognito PBI BIOS, which previously only supported no padding and a correct paragraph count, or 384 bytes of padding directly after the boot sectors. It now supports those two, plus the unusual type under discussion, and DD ATRs where each boot sector is followed by 128 bytes of padding. I think that should cover it. The sector count was also off by one for (fortunately fairly uncommon) DD ATRs with the 394 bytes of padding. I've fixed that as well. 2 Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 9, 2019 Share Posted May 9, 2019 I wrote a small Python script to scan all of the double-density ATR images in the AtariOnline.pl collection, and the result is interesting: 199x 183952 718.5 111111 f:\a8\arch\0-9\64 Figury\64 Figury (2011)(Blue Kitten Software)(PL)(PD).atr 17x 184336 720.0 000000 f:\a8\utils\C. Emulatory\Apple II emulator\Apple II disc (s1).atr 15x 183952 718.5 000111 f:\a8\arch\A\AtariBlast!\AtariBlast! (2016-09-10)(Lay, Paul - Kong Tin, Harvey - Szpilowski, Michał)(US)(Side B)[1088k].atr 9x 184336 720.0 111000 f:\a8\arch\inne\Lords Of Time;Dungeon Adenture;Return to Eden;Colossal Adventure;Adventure Quest.atr 8x 368272 1438.5 111111 f:\a8\arch\B\Booby Jackpot\Booby Jackpot (2015-09-21)(Animkomials)(PL)(en).atr 3x 183952 718.5 100111 f:\a8\arch\A\Archers, The\Archers, The (1986)(Mosaic Publishing)(GB)(Part 1, Part 2).atr 3x 409232 1598.5 111111 f:\a8\arch\D\Duszpasterz Jan Rzygoń\Duszpasterz Jan Rzygoń (2016-01-02)(Mgr. Inz. Rafal)(PL).atr 2x 654992 2558.5 100101 f:\a8\arch\C\CoreWars\CoreWars v1.0 (-)(-)(-).atr 2x 736912 2878.5 111111 f:\a8\utils\2. Grafika\TIP Animator anims for extended memory\buzzed_576k.atr 2x 183952 718.5 111101 f:\a8\utils\4. Programowanie\Action!\Action! Demos (s1).atr 2x 368272 1438.5 110000 f:\a8\utils\4. Programowanie\Turbo Basic XL\Turbo Basic XL 2.0 (v3).atr 1x 368272 1438.5 100111 f:\a8\arch\A\AtariBlast!\AtariBlast! (2016-09-10)(Lay, Paul - Kong Tin, Harvey - Szpilowski, Michał)(US)[1088k].atr 1x 183954 718.5 111111 f:\a8\arch\B\Beata\Beata (-)(-)(-)(Side A)[preview].atr 1x 184336 720.0 111010 f:\a8\arch\L\Lords of Time\Lords of Time (1983)(Level 9 Computing)(GB)[a].atr 1x 265872 1038.5 111111 f:\a8\arch\P\Pang (TeBe - Vidol - Ooz - Rocky - stRing)\Pang v4.5 (2016-12-15)(TeBe - Vidol - Ooz - Rocky - stRing)(PL)(en)[Req 256k][stereo].atr 1x 183952 718.5 111000 f:\a8\arch\T\TLC\TLC (2010)(Samar Productions)(PL)(en)[128k].atr 1x 183952 718.5 110101 f:\a8\utils\1. Biuro\ASCII ATASCII Converter\ASCII ATASCII Converter v1.2 (2015-08-13)(fujidude)(-)[Req SpartaDOS X].atr 1x 511632 1998.5 111111 f:\a8\utils\2. Grafika\GR Finder\GR Finder 0.75.atr 1x 183952 718.5 000000 f:\a8\utils\B. Rozne\blank disc 180 kB.atr Columns are: count, file size in bytes, paragraph size converted to 256-byte sector count, bitmap contents of the first six 128 byte slots, and the first file encountered with that signature. The first thing we can conclude is that the packed, non-padded case of just 3 x 128 bytes for the boot sectors and a half-sector sized file is the most common case. These have a mask starting with 111 and a sector count with an extra half (N+0.5). Second, the weird form of 3 x 128b boot sectors + 3 x 128b padding, and a whole sector sized file, is not as common but present in non-trivial quantities. These have a mask of 111000 and a whole-integer sector count. Then... we have the interesting entry #2, the disk images from the awesome hack called the Apple II emulator. These are converted Apple II disks with 256 byte sectors. The sectors are aligned to 16+256*N in the file, so this must interpret the first three sectors as full 256 byte. So here's the third interpretation. These have a whole-integer sector count with any possible mask. In Altirra's source code, these three forms are given the designations of default, really screwed up, and fubar. Atari800 uses the slightly more descriptive terms logical, SIO2PC, and physical. Now, in the case of the Apple II converted disks, the first 6 x 128 bytes are all zero (bitmap mask of 000000), so either of the last two interpretations will work as there is no difference. But then, there is another gem hiding in this list, the Lords of Time disk with the bitmap 111010. As it turns out, the correct interpretation of the boot sectors on this disk image is 3 x 256b, it will not boot with either 3 x 128b form. That makes this essentially the counter-case of the image that started this thread, and one that is probably the hardest to distinguish. Same file size (184336 bytes), same sector size (256 bytes), same paragraph count ($2D00), and zeroes in the last few sectors of the file. So here's a case where a hide-the-zeroes heuristic fails, this image has non-zero data in an area that is not visible as readable sector data. atrscan.zip 5 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 9, 2019 Share Posted May 9, 2019 Candle in 2011: I guess we make a proprietary image format for the PBI BIOS and a conversion tool, since ATRs are so awkward to handle? Unless you think they can be dealt with directly? FJC: Hold my beer. God... what a mess. But what a useful and illuminating tool. Such pragmatic analysis is long overdue. Likely my implementation will fall on its ass in the face of the Apple II variation (I will try it and see), but at least the others are handled (including the 'padding at the back' type). 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 9, 2019 Author Share Posted May 9, 2019 Wow, never thought my little question would involve such detecive work, nice work 2 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 9, 2019 Share Posted May 9, 2019 When things like this pop up its like an itch you just have to scratch to our bods, it also can prompt finding other issues or traits so its helpful as well. Quote Link to comment Share on other sites More sharing options...
JoSch Posted May 9, 2019 Share Posted May 9, 2019 (edited) Wow, never thought my little question would involve such detecive work, nice work At least, it uncovered a major bug in RespeQt when dealing with ATRs. Edit: Thanks to flashjazzcat for pointing me to it. Edited May 9, 2019 by JoSch 1 Quote Link to comment Share on other sites More sharing options...
