Swami Posted May 7, 2019 Share Posted May 7, 2019 I've started playing Miner 2049er after decades. I've been trying to use the "2137826861 + Keys SHIFT + 4" cheat code to jump to level 4, which I'm getting stuck on, but it does not seem to work in Altirra. Anybody get this type of cheat code to work? Also, is there an infinite lives version. Only so many times I can take repeating the first easy three levels. Quote Link to comment Share on other sites More sharing options...
Swami Posted May 16, 2019 Author Share Posted May 16, 2019 I've started playing Miner 2049er after decades. I've been trying to use the " 2137826861 + Keys SHIFT + 4" cheat code to jump to level 4, which I'm getting stuck on, but it does not seem to work in Altirra. Anybody get this type of cheat code to work? Also, is there an infinite lives version. Only so many times I can take repeating the first easy three levels. Atr from Best 800 Emulator game pack did not work with cheat code (2137826861 + Keys SHIFT + 4) , but this rom file from Atarimania did. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 16, 2019 Share Posted May 16, 2019 (edited) Here's a cheat file you can load in to Altirra cheat interface, I have not checked it but I'd presume infinite lives.. Delete the .txt at the end of the file (only on there so its easy to put on here..) Confirmed as Infinite Lives.... Miner 2049.a8t.txt Edited May 16, 2019 by Mclaneinc 1 Quote Link to comment Share on other sites More sharing options...
Swami Posted May 16, 2019 Author Share Posted May 16, 2019 Here's a cheat file you can load in to Altirra cheat interface, I have not checked it but I'd presume infinite lives.. Delete the .txt at the end of the file (only on there so its easy to put on here..) Confirmed as Infinite Lives.... Thanks! I see a guy on youtube did a playthrough with one with no collision and infinite time. He may have done that himself for playthrough, but I don't expect it would be any fun at all that way. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 16, 2019 Share Posted May 16, 2019 (edited) Time and No collision are easy to do, in fact in Altirra under the cheat menu you can turn off collisions there, it MAY have adverse effects depending on the coding of the game... If you want time I'd look in to it BUT its more fun if there are at least some obstacles... Oh go on then...Infinite time added... This is an Altirra own cheat file hence the name change as I just added the cheat this sec, remove the .txt as before.... Try not to use the collision detection cheat as its not even worth playing the game then.. Paul Miner 2049.atcheats.txt Edited May 16, 2019 by Mclaneinc 2 Quote Link to comment Share on other sites More sharing options...
