+SpiceWare Posted May 28, 2006 Share Posted May 28, 2006 Your Air CSS Battle is quite impressive! Quote Link to comment Share on other sites More sharing options...
nmoog Posted May 28, 2006 Share Posted May 28, 2006 Thanks SpiceWare! I actually thought making a game using DOM scripting would be pretty challenging. Then I started following Andrew's tutorial here. Turns out I didn't know the meaning of challenging Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 28, 2006 Share Posted May 28, 2006 I was lucky in that I already knew 6502 from my C= days. That made it a lot easier to get Medieval Mayhem started. Quote Link to comment Share on other sites More sharing options...
nmoog Posted May 29, 2006 Share Posted May 29, 2006 Hey Guys, Although I'm having a great time messing around with this stuff, I was hoping you could give me a hand as I think if I keep going by Im going to be leading myself into a path of pain. I've got a lil' guy moving up and down... kind of. He magically gets a hat when going down and a podium when going up. THough this isn't the bit thats really troubling me. I don't know where in each frame (before the frame starts, after the vertical syncs, during the screen drawing etc) I should be doing: * Joystick checking * Horizontal Positioning * vertical positioning In the horizontal positioning subroutine that Andrew listed it starts with "sta WSYNC" - does that mean I don't do the wsync at the end of the main loop as well? Thank for your help spriteMove.zip Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 29, 2006 Share Posted May 29, 2006 I don't know where in each frame (before the frame starts, after the vertical syncs, during the screen drawing etc) I should be doing:* Joystick checking * Horizontal Positioning * vertical positioning Joystick: best before positioning, since you want to react to the players input immediately. Positioning: before the display kernel, after stuff like joystick, collision checking etc. Actually, there is no strict pattern you have to follow. Just do it in some logical order. Later on, you might discover that reordering your code may make things easier. In the horizontal positioning subroutine that Andrew listed it starts with "sta WSYNC" - does that mean I don't do the wsync at the end of the main loop as well? The RESPx commands have to be timed exactly, so you need a WSYNC before. But that doesn't mean you have to do it inside the kernel. You can do everything whereever you want (except HMOVEs during vertical sync). Quote Link to comment Share on other sites More sharing options...
nmoog Posted May 29, 2006 Share Posted May 29, 2006 Yes! Thanks Thomas! I was trying to run the xpositioning code during the screen draw. Whoops! Now I've got a lil' guy running round the screen - on an atari 2600!!! I have another query on the WSYNC thing though - if I do the 37 vertical blank WSYNC before drawing, then one WSYNC for the X Positioning code - then 192 WSYNCS for the screen then 30 WSYNCS for the overscan... don't I have 1 WSYNC too many? Doesn't that WSYNC I called for the X positioning push everything down one line? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 30, 2006 Share Posted May 30, 2006 (edited) Yep, but most TVs are forgiving if you provide too many or too few lines, provided it's the same number of lines each time. ie sending 263, 263, 263 would be OK, but sending 262, 263, 262 will cause the screen to jiggle up/down. You'll probably want to next look at replacing the 37 vertical blank WSYNCs and 30 overscan WSYNCs with the timer. Check this sample code from khryssun where he's using the timer for the vertical blank. The key things are setting the timer using TIM64T and checking if the timer is done using INTIM. Edited May 30, 2006 by SpiceWare Quote Link to comment Share on other sites More sharing options...
nmoog Posted May 30, 2006 Share Posted May 30, 2006 That's really cool - I was wondering where the game logic went! I love your Medieval Mayhem game too - great idea. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 30, 2006 Share Posted May 30, 2006 I love your Medieval Mayhem game too - great idea. Thanks! I decided to do it after getting my nephew's friends hooked on Warlords when I was visiting this past Xmas. Having grown up with PS2s, they'd been been slamming the Atari's graphics. They changed their tune once they realized graphics weren't everything . If you'd like to see the source for it, it's available in my blog. Quote Link to comment Share on other sites More sharing options...
Moose1900 Posted December 21, 2015 Share Posted December 21, 2015 does anyone have a working example of a skipdraw routine? I have seen many postings of the code for just the routine, but never a simple program that draws a sprite on the screen using skip draw. I have tried for the past few weeks, but can't seem to get it to work. I think if I saw a simple example that works, then I could see where I am going wrong. Any help would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted September 15, 2017 Share Posted September 15, 2017 (edited) does anyone have a working example of a skipdraw routine? I have seen many postings of the code for just the routine, but never a simple program that draws a sprite on the screen using skip draw. I have tried for the past few weeks, but can't seem to get it to work. I think if I saw a simple example that works, then I could see where I am going wrong. Any help would be much appreciated. Thanks. I'm asking my self the same, i have the same problem with this skipdraw routine, and can't understand how it works just for a few lines how's possible to write pointer content to GRP0 register if A register isn't transferred to Y regsiter as index? a little confused, even i saw this url: http://www.biglist.com/lists/stella/archives/200309/msg00059.html and there's a tay instruction before loading accumulator with pointer TAY LDA (ZERO_PAGE_PTR),y STA GRP0 BUMP... Edited September 16, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted September 16, 2017 Share Posted September 16, 2017 (edited) ok, think it's done, now will take the bin and run into stella's debugger to understand in a more detailed way what's going on with carry and brach. cheers. processor 6502 include "vcs.h" include "macro.h" seg.u uninitialized org $80 SpriteEnd ds 1 SPRITEHEIGHT equ 8 spriteP0 ds 2 SEG DATA ORG $F000 Reset lda #0 ldx #0 clear_mem sta $0,x inx bne clear_mem lda #30 sta COLUP0 lda #60 sta SpriteEnd ; SPRITE Y POSITION lda #<Sprite0Data sta spriteP0 lda #>Sprite0Data sta spriteP0+1 Start_of_frame: lda #0 sta VBLANK lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC ldy #36 vertical_blank sta WSYNC dey bne vertical_blank ldx #191 scan_lines: sta WSYNC sec txa sbc SpriteEnd adc #SPRITEHEIGHT bcc .skipDraw tay lda (spriteP0),y sta GRP0 .skipDraw dex bne scan_lines lda #%01000010 sta VBLANK ldy #29 overscan sta WSYNC dey bne overscan jmp Start_of_frame Sprite0Data .byte #%00000000 .byte #%11111111 .byte #%00000000 .byte #%11111111 .byte #%00000000 .byte #%11111111 .byte #%11111111 .byte #%11111111 ORG $FFFA InterruptVectors .word Reset .word Reset .word Reset END Edited September 16, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted September 16, 2017 Share Posted September 16, 2017 (edited) the only way i found to make Andrew's solution work was adding one instruction TAY please correct me if i'm wrong. Andrew's solution sec; ;2 can often be guaranteed, and omitted tya ; 2 sbc SpriteEnd ; 3 adc #SPRITE_HEIGHT ; 2 bcs .MBDraw3 ; 2(3) nop ; 2 nop ; 2 sec ; 2 bcs .skipMBDraw3 ; 3 .MBDraw3 lda (Sprite),y ; 5 sta GRP0 ; 3 .skipMBDraw3 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- ldx #191 scan_lines: sta WSYNC sec txa sbc SpriteEnd adc #SPRITEHEIGHT bcs .draw nop nop nop sec bcs .skipdraw .draw tay ; <······························································ EXTRA INSTRUCTION lda (spriteP0),y ; use indirect loading here sta GRP0 .skipdraw dex bne scan_lines ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Cheers. Edited September 16, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2017 Share Posted September 16, 2017 (edited) No, that's not the way it is meant to be. SkipDraw is optimized for CPU time, therefore you have to setup the sprite pointers correctly outside the kernel. Also SkipDraw assumes that Y contains your current scanline and not X. Only then you can use Y directly for pointer reads and X is completely free for other stuff. Also the branch to .draw wastes one cycle. To avoid that, branch the non-draw to somewhere outside the kernel and then return to .skipDraw. Edited September 16, 2017 by Thomas Jentzsch 1 Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted September 16, 2017 Share Posted September 16, 2017 (edited) No, that's not the way it is meant to be. SkipDraw is optimized for CPU time, therefore you have to setup the sprite pointers correctly outside the kernel. Also SkipDraw assumes that Y contains your current scanline and not X. Only then you can use Y directly for pointer reads and X is completely free for other stuff. Also the branch to .draw wastes one cycle. To avoid that, branch the non-draw to somewhere outside the kernel and then return to .skipDraw. Hi Thomas, ty for your fast reply, please can you show me some url with example code? do you mean with, outside kernel, to set something outside the 192 scanlines? i have arranged pointers outside the 192 scanlines. am i right? (code bellow) processor 6502 include "vcs.h" include "macro.h" seg.u uninitialized org $80 SpriteEnd ds 1 SPRITEHEIGHT equ 8 spriteP0 ds 2 SEG DATA ORG $F000 Reset lda #0 ldx #0 clear_mem sta $0,x inx bne clear_mem lda #30 sta COLUP0 lda #60 sta SpriteEnd ; SPRITE Y POSITION ;--------------------------------------------------------------------------------------------------------------------------- lda #<Sprite0Data sta spriteP0 lda #>Sprite0Data sta spriteP0+1 ;--------------------------------------------------------------------------------------------------------------------------- I saw here: http://www.biglist.com/lists/stella/archives/200309/msg00060.html this: > .contDrawPlayer: > dey > tya > sbc yPosP0 > adc #H_TANK > bcs.doDrawP0 > lda #0 > NOP_W > .doDrawP0: > lda (ptrP0),y > sta.w GRP0 The key is the NOP_W, which is an equate for $0C, which is the opcode NOP abs. (An illegal/undocumented version of NOP. The documented way is to use $2C which is BIT abs) So if the bcs is not taken the lda (ptrP0),y gets absorbed into the NOP and is not executed. Is sta.w another undocumented opcode too or just a type error?i have found undocumented opcodes for 6502 but dunno if it works with 6507 http://nesdev.com/undocumented_opcodes.txt returning about this subject, vertical position, Dear Thomas, any example code would be really really appreciated. Thanks again and thanks in advance. Subject: [stella] Usefull illegal opcodes (part 1)From: "Thomas Jentzsch" <tjentzsch@xxxxxx>Date: Fri, 23 Feb 2001 08:59:28 +0100 Hi,yesterday, i was thinking about a faster way to decide in a kernel if you are on a sprite drawing line or not.The best way, i knew until now, was (if y contains linecounter): tya ; 2 (sec ; 2) <- this can sometimes be avoided sbc SpriteEnd ; 3 adc #SPRITEHEIGHT ; 2 bcx .skipDraw ; 2 = 9-11 cycles ...If you like using illegal opcodes, you can use dcp (dec,cmp) here: lda #SPRITEHEIGHT ; 2 dcp SpriteEnd ; 5 initial value has to be adjusted bcx .skipDraw ; 2 = 9 ...Advantages:- state of carry flag doesn't matter anymore (may save 2 cycles)- a remains constant, could be useful for a 2nd sprite- you could use the content of SpriteEnd instead of y for accesing sprite data- ???Have fun!Thomas Edited September 16, 2017 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 16, 2017 Share Posted September 16, 2017 Check this post..w just tells the assembler to create a 3 byte instruction when you access a zero page address, which is useful if you want to waste 1 cycle. 1 Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted September 18, 2017 Share Posted September 18, 2017 (edited) Check this post. .w just tells the assembler to create a 3 byte instruction when you access a zero page address, which is useful if you want to waste 1 cycle. Ty Thomas, was searching around the web for skipdraw and have found a lot of info, once my brain be able to process it... will post something here to receive your blessing. pd: ty 4 da url. cheers. Edited September 18, 2017 by zilog_z80a 1 Quote Link to comment Share on other sites More sharing options...
Sheldon Sims Posted May 13, 2018 Share Posted May 13, 2018 (edited) 2) Create another data table, and use a variable to determine which of the two data tables to display. You might like to have it switch between these tables every second, or perhaps use the joystick button to determine which is displayed. As a hint - remember, you need to setup the zero page pointer to point to the table for your sprite draw to use - so all you need to do is change this pointer, and leave your kernel code alone. I am back after a 13-year hiatus. I was about to give up on this one, but after having a little talk with Jesus, I figured it out. I was beginning to think that my 47-year old brain didn't work well anymore. Anyway, I borrowed a little code from Kirk Israel and nmoog, and came up with the attached solution to Exercise 2. It uses a variable to point to one of 6 tables based on input (or lack thereof) from the joystick. Programming the Atari VCS is definitely challenging, but I am determined. The program reacts accordingly to joystick left, right, up, down, button or no input at all. Now on to exercise 3. kernel10-2.bin Edited May 13, 2018 by Sheldon Sims Quote Link to comment Share on other sites More sharing options...
