liquid_sky Posted June 24, 2001 Share Posted June 24, 2001 i have an oddessy2 and an atari 2600... i am having problems hooking them up to my tv, i lost the converter box... do you have any information on how to make your own, or a place to purchase a cheap replacement? Quote Link to comment Share on other sites More sharing options...
Alex Posted June 24, 2001 Share Posted June 24, 2001 As for the 2600, I recommend you buy a simple coaxial/rca converter at Radio Shack, should run you a couple bucks. Check this page for more info. It's smaller and will give you a clearer signal than a switchbox. You can get a coax channel selector to change between game and TV if you want then. 02 should be the same way, although I seem to recall that some models (all?) require a special modulator box. Not sure about that one. Quote Link to comment Share on other sites More sharing options...
JagDiesel Posted June 24, 2001 Share Posted June 24, 2001 For the Odyssey2, I would recommend trying a standard box, but if it has the oddball end like Alex is talking about, I would replace the AV line with a standard Atari type and use a coax fitting on the end to hook up to the tv. I have done that with 3 different O2's and they all have worked fine... Quote Link to comment Share on other sites More sharing options...
liquid_sky Posted June 24, 2001 Author Share Posted June 24, 2001 thanks for the help guys, ill have to run by the shack and get a coax converter for the 2600.. and for the o2 it does have the weird end, so ill have to rig up one of those boxes, thanks for the help. that page was right, its like an adventure to hook them up.. its been quite a while i might not remember, but didnt the 7800 hook up easier? Quote Link to comment Share on other sites More sharing options...
slapdash Posted June 26, 2001 Share Posted June 26, 2001 Regarding the O2 with the odd end on the video cable... I think you might be able to replace it with a regular cord if you go inside and swap it, as it has the regular miniplug (or whatever it's called) on the inside. I think... Quote Link to comment Share on other sites More sharing options...
JagDiesel Posted June 26, 2001 Share Posted June 26, 2001 Russ is right about the socket inside the O2... if you have the tools with you, the changeover can be done in under 10 minutes.. Its an easy fix and eliminates that damned box... Quote Link to comment Share on other sites More sharing options...
