bne jmp bpl
Turns out I was wrong about my earlier post...as I could only find LDA-BPL/BMI combos in that other program.
But just as a test, I'd altered Adventure's routine...
;original
LDA Jstick ;Get joystick record.
AND #$C0 ;Merge out previous presses.
CMP #$40 ;Was it previously pressed?
BNE PickupPutdown_2 ;If not branch.
;works
BIT Jstick
BVS PickupPutdown_2
;fails
LDA Jstick
AND #$40
BVS PickupPutdown_2
;fails
LDA Jstick
AND #$40
CMP #$40
BVS PickupPutdown_2
I wonder if there might be different behavior in different versions of the 6502 architecture? I know the 65C02 has additional instructions and addressing modes that the 6502 and 6507 don't. Perhaps later versions of the chip do update the V flag on a compare instruction...?
Sorry, I was wrong about the Compare instructions. (I've modified my post.) I assumed that since CMP is so close to SBC that it would also affect the oVerflow flag (and didn't check my own refs :ponder: ). Wierd. I wonder why the designers decided to explicitly exclude it. Maybe there is a well known routine which needs that behaviour.
Sorry Erik, we were both wrong.
I think the reason CMP's are excluded is because the purpose of V is to guarantee accuracy when doing extended calculations with signed numbers. Since CMP doesn't affect any values, V wasn't deemed necessary.
My point is it probably required extra transistors for CMx to not update V, and all indications are the 6502 design team didn't waste transistors without a good reason.
