Trying to hack Kaboom! (for the 5200)
6 replies to this topic
#1 nems OFFLINE
nems
    Chopper Commander
  • 153 posts
Posted Mon Mar 28, 2005 8:38 PM
I want to try hacking Kaboom! for the 5200. I'm a total newbie at this and need some help... :?
My plan is to open the .bin in dis6502 and save the disassembly listing as an .ASM file. Then open the .ASM file in TextPad, manipulate it, and then reassemble using DASM. Does this plan seem correct?
Are there particular values I should set in the "assembler format" options in dis6502 so that the .ASM file will later be accepted by DASM?
Anybody already have a disassembly of Kaboom! for the 5200?
#2 nems OFFLINE
nems
    Chopper Commander
  • 153 posts
Posted Wed Mar 30, 2005 7:14 PM
Please help...
I created an .ASM using dis6502 (see attached), but even before changing any code I am unable to reassemble it using DASM. Any idea what I'm doing wrong? :?
#3 moycon OFFLINE
moycon
  • 21,989 posts
  • moycon?? What the hell is that??
Posted Thu Mar 31, 2005 3:55 AM
Sorry I'd help it I could, but I've never hacked a 5200 game before.
To be honest, I didnt even know it was possible.
#4 Tom OFFLINE
Tom
    Moonsweeper
  • 455 posts
Posted Thu Mar 31, 2005 4:45 AM
Why shouldn't it be possible ? You can hack anything, given enough time and knowledge.
#5 s0c7 OFFLINE
s0c7
    Dragonstomper
  • 607 posts
Posted Thu Mar 31, 2005 11:43 AM
It depends on what you are trying to do. I had never really thought about doing anything with the 5200 before, so I was curious and gave it a try. If you are only wanting to change graphics - I was able to change graphics with BitHacker without any problems. I would imagine all the other programs of that type would work too.
As far as disassembly, I tried using Distella. If you are looking for something easy to read, this ain't it. But it will recompile with DASM no problem.
#6 s0c7 OFFLINE
s0c7
    Dragonstomper
  • 607 posts
Posted Thu Mar 31, 2005 12:33 PM
Just to show you, this is what I did with BitHacker. Took about 15 seconds to do. Note the hat and slightly different body.
#7 nems OFFLINE
nems
    Chopper Commander
  • 153 posts
Posted Thu Mar 31, 2005 10:18 PM
Thanks for the replies! :)
I've used BitHacker to change sprites before, but want to change the playfield and sounds in Kaboom!
I didn't know that Distella would work with a 5200 file, but the .ASM you posted reassembles just fine! Thanks again!
