+Random Terrain Posted July 29, 2005 Share Posted July 29, 2005 (edited) There are two easy ways to force an 'indent' (a no-break space) at most message boards. If you have a Windows PC, you can 'type' it by holding down the Alt key and punching in the numbers 255 or 0160 with the numbers on the side of your keyboard or you can use that cool little program called Character Map. If you run that and look between the tilde and the inverted exclamation mark, you'll see the no break space. You can copy and paste it when you need to force a blank space. Whether you copy it from Character Map or use Alt+255 or Alt+0160, it's pretty fast and not too much of a pain. You can read more about it here: http://www.fileformat.info/info/unicode/char/00a0/index.htm If you have a long chunk of code to post, you can use kisrael's free online tool: http://alienbill.com/2600/basic/aabbcc.cgi Edited July 29, 2005 by Random Terrain Quote Link to comment Share on other sites More sharing options...
NE146 Posted July 29, 2005 Share Posted July 29, 2005 For some reason I always used alt 0928 Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted July 29, 2005 Share Posted July 29, 2005 There are two easy ways to force an 'indent' (a no-break space) at most message boards. You can 'type' it by holding down the Alt key and punching in the numbers 255 with the numbers on the side of your keyboard or you can use that cool little program called Character Map (if you have a Windows PC). If you run that and look between the tilde and the inverted exclamation mark, you'll see the no break space. You can copy it and paste it when you need to force a blank space. Whether you copy it from Character Map or use Alt+255, it's pretty fast and not too much of a pain. You can read more about it here: http://www.fileformat.info/info/unicode/char/00a0/index.htm That's a 160, not a 255. 255 being a blank is a PC-ism and doesn't apply to non-PC hardware. Also, there's " " to force a blank. Which is generally a lot more reliable when you're entering plain HTML rather than bbcode. Anyhow, on this BB software, the CODE tags work right except that the first blank of every line that starts with a blank is removed. Which is annoying as hell. FWIW, "0928" is just a fancy way of saying 160, since ALT+keypad wraps around every 256. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted July 29, 2005 Author Share Posted July 29, 2005 There are two easy ways to force an 'indent' (a no-break space) at most message boards. You can 'type' it by holding down the Alt key and punching in the numbers 255 with the numbers on the side of your keyboard or you can use that cool little program called Character Map (if you have a Windows PC). If you run that and look between the tilde and the inverted exclamation mark, you'll see the no break space. You can copy it and paste it when you need to force a blank space. Whether you copy it from Character Map or use Alt+255, it's pretty fast and not too much of a pain. You can read more about it here: http://www.fileformat.info/info/unicode/char/00a0/index.htm That's a 160, not a 255. 255 being a blank is a PC-ism and doesn't apply to non-PC hardware. Also, there's " " to force a blank. Which is generally a lot more reliable when you're entering plain HTML rather than bbcode. Anyhow, on this BB software, the CODE tags work right except that the first blank of every line that starts with a blank is removed. Which is annoying as hell. FWIW, "0928" is just a fancy way of saying 160, since ALT+keypad wraps around every 256. 900916[/snapback] http://www.fileformat.info/info/unicode/char/00a0/index.htm How to type in Microsoft Windows: Alt+00A0 Alt+0160 Alt+255 I use Alt+255 since it is one less number to type and I have a PC. Quote Link to comment Share on other sites More sharing options...
kisrael Posted July 29, 2005 Share Posted July 29, 2005 I think the solution I list at http://www.atariage.com/forums/index.php?showtopic=73644 is the best bet, at least for CODE blocks....remember there's a chance that other people might not be able to see the spaces Quote Link to comment Share on other sites More sharing options...
NE146 Posted July 29, 2005 Share Posted July 29, 2005 FWIW, "0928" is just a fancy way of saying 160, since ALT+keypad wraps around every 256. Aaahh! So that makes sense now :Þ ¡¢£¤¥¦§¨©ª«¬Ë®¯°±²³´µ¶·¸¹º»¼½¾¿ Quote Link to comment Share on other sites More sharing options...
