Programming in a subdirectory
No replies to this topic
#1 SeaGtGruff OFFLINE
SeaGtGruff
  • 5,566 posts
Posted Tue Aug 9, 2005 8:45 PM
I don't know if anyone else has mentioned this already. If you create all of your programs in the main Batari BASIC directory, it quickly fills up, and becomes very cluttered. You can keep things better organized by creating a subdirectory for your programs, so that just the main Batari BASIC files are in the main directory.
For example, my directories look like this:
C:\Atari
then
C:\Atari\2600
C:\Atari\5200
C:\Atari\7800
C:\Atari\800
etc. And inside each of those I have more subdirectories, like this:
C:\Atari\2600\docs
C:\Atari\2600\emus
C:\Atari\2600\roms
etc. So naturally I added another directory for Batari BASIC:
C:\Atari\2600\Batari BASIC
And then I added a directory inside of it for my programs:
C:\Atari\2600\Batari BASIC\Programs
I should mention that I'm using the 2600ide program, which is inside the main Batari BASIC directory. Anyway, when I load a program into 2600ide and compile it, I get an error because it can't find the programs.
To make it work, all you need to do is edit the 2600baside.bat file, and add a "cd .." command, like this:
@echo off
cd ..
2600bas.exe<%1>%1.obj
copy /y /a 2600basic.asm +%1.obj +2600basicfooter.asm %1.asm>nul
dasm %1.asm -f3 -o%1.bin
Note that you must do this with the 2600baside.bat file that's in the subdirectory where your games are. Once you do this, the compiles will execute correctly.
Michael Rideout
