amigaman07 Posted December 21, 2014 Share Posted December 21, 2014 (edited) A Bit of related Trivia... http://www.atarimuseum.com/computers/8bits/xe/65xe/65xe.html Edited December 21, 2014 by amigaman07 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 10, 2016 Share Posted October 10, 2016 Just discovered a PAL 800XLF in the spare room. Missing 74LS08 but otherwise intact: 4 Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 10, 2016 Share Posted October 10, 2016 (edited) I don't quite get it... the Freddie chip has CO14889-01 part # which is GTIA (as per the actual GTIA on the board), but Freddie should be CO61991 or CO61992 Edited October 10, 2016 by Rybags 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 10, 2016 Share Posted October 10, 2016 Good spot. I probably chucked GTIA in the FREDDIE socket by mistake (presumably FREDDIE should be bottom left). Quote Link to comment Share on other sites More sharing options...
Guest Posted October 10, 2016 Share Posted October 10, 2016 mine's a standard 6-pin monitor 64-k secam rose Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 10, 2016 Share Posted October 10, 2016 I remember working on a SECAM machine (making a video cable for it). Was it that one? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 10, 2016 Share Posted October 10, 2016 yep... it's really nice. i'd like to track down 128k, but they're rarer than hen's teeth a question for the knowledgable - esp as i've never seen either of the other two flavours. the other "two types" - ie scart/peritel and 128k... do these connect thru the same 6-pin monitor connection, or does either model have a dedicated/integrated scart-out socket? only asking as one of the previous posts i this thread could be interpreted that way Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 11, 2016 Share Posted October 11, 2016 F.Y.I. Freddie is just a glue chip which contains the logic that was formerly done by 74LS chips and the C060472 delay. The delay is accomplished by running through multiple inverters. Attached is a diagram of the internal workings of Freddie. Freddie is a good chip, first used in the 14x0XL models. important: (somewhat related) Does anyone remember that Phi2 timing-fix module that replaces the 74LS08? I have been looking for that for a while. Is it still available? Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 11, 2016 Share Posted October 11, 2016 Freddie = large chip on the left but 2nd row from the bottom. The other thing is deletion of the delay line since Freddie takes a ~ 14 MHz input and divides down appropriately. Sort of strange though, they could have taken the opportunity and had the PAL version run at ~ 17.9 MHz then used that clock to derive both the CPU and colour clocking, though then of course it becomes another system dependant component. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 11, 2016 Share Posted October 11, 2016 Freddie = large chip on the left but 2nd row from the bottom. The other thing is deletion of the delay line since Freddie takes a ~ 14 MHz input and divides down appropriately. Sort of strange though, they could have taken the opportunity and had the PAL version run at ~ 17.9 MHz then used that clock to derive both the CPU and colour clocking, though then of course it becomes another system dependant component. I don't see how they could have done that because the video framerate is dependent on the CPU clock frequency. It's just the way ANTIC works (unless I completely mis-understand this {which I don't think I do}) . Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 11, 2016 Share Posted October 11, 2016 (edited) C64 Pal machines derive both clocks from the one master, but of course it's dependant on there being a direct relationship between the colour clocking and pixel/CPU clocking. Atari NTSC, it's a direct relationship, 4 hires pixels = 1 CPU clock, colour clocking 2:1. Atari PAL, the colour clocking is faster to the ratio of 10:4. So all's needed is to have the master clock such that it can be divided down to provide both, ie ~ 17.73 / 10 for CPU clock and /4 for colour clock. Edited October 11, 2016 by Rybags Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted October 11, 2016 Author Share Posted October 11, 2016 mine's a standard 6-pin monitor 64-k secam rose IMG_20161010_1606282.jpgIMG_20161010_1606051.jpg Does that say REV R2 or REV R3 on the solder side? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 11, 2016 Share Posted October 11, 2016 Freddie = large chip on the left but 2nd row from the bottom. That's what I thought, and why I stuck a GTIA in the socket on the front row. But FREDDIE is bottom left, and GTIA moved to the row behind. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 11, 2016 Share Posted October 11, 2016 Does that say REV R2 or REV R3 on the solder side? Rev R3 all details Under (solder) side - L-R [c] 8-84 GX-211 VO C024968-001 REV R3 0585 800XL - SECAM Top (IC) side (top right corner) 800XL - SECAM ROSE CA024969 - 001 REV - Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted January 13, 2017 Author Share Posted January 13, 2017 So, in my quest to obtain a Freddie 800XL (anyone want to sell me their PAL 800XLF?) I've come across some hints as to what XL's might be Freddie. In particular, the "rainbow" shadow under the 800XL on its box was supposed to indicate a higher likely hood for the Freddie chip, and a late 84 manufacturer date, as there are September and November Freddie board variants. Now I've stumbled across someone who has a 800XL, in a Rainbow box, made in late 84 but its NTSC -- and afaik, no NTSC Freddie was ever made. The person who has this refuses to open it up and take a motherboard picture, and the price is a bit excessive for it, so I'm left gambling if I were to buy it. But its always easier to give money away to someone with a sure thing. Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted January 13, 2017 Share Posted January 13, 2017 I have a PAL 800XL that's probably an XLF: it came with rev. C BASIC in ROM and whichever revision of the XL OS that doesn't have the 4 minute CIO timeout bug. I'm not sure I want to sell it, though: it has some display/sound/RAM problems that I've been meaning to turn into a repair project. How can I tell if it actually has a Freddie chip? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 14, 2017 Share Posted January 14, 2017 (edited) How to tell at a glance if it's got a Freddie? A stock 800XL has 5 large ICs. 6502 "Sally" CPU, Antic, GTIA, Pokey, PIA. A Freddie machine has 6 (note, disregard the OS Rom at top right which along with the Basic Rom is larger than the 7400 and 4500 type ICs). The reason for existence of Freddie machines? I think we've gone over this but Atari was going well in some Euro markets to the point of the XL line being sold there longer. Brand identity was retained by naming their local 130XE variant "800XE". The Basic Rev C thing might be a good indicator too. I would suspect that the Freddie equipped models all get Rev C. You can test what Basic is present without pulling apart the machine. Test for Basic revision: ? PEEK(43234) If you get 162 you have Rev (brown Cartridge).If you get 96 you have Rev B (stock for XL Computers).If you get 234 you have Rev C (XE, some late XL, standalone cart replacement from Atari). Edited January 14, 2017 by Rybags 1 Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted January 16, 2017 Share Posted January 16, 2017 So, in my quest to obtain a Freddie 800XL (anyone want to sell me their PAL 800XLF?) I've come across some hints as to what XL's might be Freddie. In particular, the "rainbow" shadow under the 800XL on its box was supposed to indicate a higher likely hood for the Freddie chip, and a late 84 manufacturer date, as there are September and November Freddie board variants. Now I've stumbled across someone who has a 800XL, in a Rainbow box, made in late 84 but its NTSC -- and afaik, no NTSC Freddie was ever made. The person who has this refuses to open it up and take a motherboard picture, and the price is a bit excessive for it, so I'm left gambling if I were to buy it. But its always easier to give money away to someone with a sure thing. I have 2-3 mainboards "XLF" (PAL) with Freddie in my basement. If you want, I can check one. Let me know Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted January 16, 2017 Share Posted January 16, 2017 How to tell at a glance if it's got a Freddie? The Basic Rev C thing might be a good indicator too. I would suspect that the Freddie equipped models all get Rev C. You can test what Basic is present without pulling apart the machine. This is one way, but also there are a lot of non-Freddie mainboards with BASIC "C" in the wild. The much easier way is to use a S-Video monitor cable. All Freddie-based 800 XL (called "XLF") mainboards have Chroma on pin 5 like every XE mainboard. So if you connect a S-Video monitor cable and get color - it´s a Freddie-based 800 XL. 2 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted February 12, 2017 Author Share Posted February 12, 2017 The Atari 8-bit faq states: "August [1984]: Atari engineers completed the prototype "800XLF" motherboard design, to be used in new-production 800XL computers. The new 800XL machines wouldinclude the new FREDDIE memory management chip (previously developed atAtari, Inc.), the new Revision C of Atari BASIC, and a reinstated chrominancevideo signal on the Monitor port (missing on the 1200XL/600XL/800XL producedby Atari, Inc.). The new 800XL machines would be produced in PAL and (forthe first time, France-specific) SECAM versions, but not the NTSC version dueto ample existing supply of NTSC 800XL machines." Does anybody know what the source is for this date? I ask because the 800XLF boards have the following dates: Rev-R1 © 4/84 [Possible prototype board] Rev-R2 - never seen one or heard of one. Rev-R3 © 9/84 Rev-R4 fabrication schematic 10/18/84, Revisions 6/7/85 and 2/4/88 The 800XL-SECAM (that uses Freddie) has: © 4/84 REV-X1A [Possible prototype board] week 18 of 84 © 8/84 REV-R3 I've seen boards made week 42 of 84 and 05 of 85 Obviously, August fits right in the middle there as a good timeline, but was wondering if there were any notes or official sources. Quote Link to comment Share on other sites More sharing options...
Marsupilami Posted February 12, 2017 Share Posted February 12, 2017 (edited) In France, Atari sold "PAL" XLF first but they had problems to deliver enough quantity, that's why the XLF Pal is the rarest. The SECAM (XLF) was produced a few month later and the quality was better. If you want to know if it's an XLF Secam without opening it, just look at the rear, ie search the "TV switch (Color/B&W)" or the lack of coaxial output. This is a NTSC : http://atarinside.dyndns.org/blog/wp-content/uploads/AI/photo-gallery/NTSC.jpg This is a PAL (not XLF - no Freddie) http://atarinside.dyndns.org/blog/wp-content/uploads/AI/photo-gallery/PAL_001.jpg This is a SECAM XLF http://atarinside.dyndns.org/blog/wp-content/uploads/AI/photo-gallery/SECAM.jpg Edited February 12, 2017 by Marsupilami Quote Link to comment Share on other sites More sharing options...
redhawk668 Posted July 13, 2018 Share Posted July 13, 2018 I've completed an s-video cable for use on my 800XL and connected it, to my surprise the machine had a color display instead of the black/white I expected, so I opened it up. It's an 800XLF Rev. R3 from late '84 so I guess one out of the last production run of the 800XL before the XE series came out. The machine I have is a PAL system and is in good condition. Case has yellowed a little bit, but the PCB looked absolutely mint. This 800XLF will not receive any mods, and I'll preserve it. Quote Link to comment Share on other sites More sharing options...
Marsupilami Posted July 13, 2018 Share Posted July 13, 2018 I've completed an s-video cable for use on my 800XL and connected it, to my surprise the machine had a color display instead of the black/white I expected, so I opened it up. It's an 800XLF Rev. R3 from late '84 so I guess one out of the last production run of the 800XL before the XE series came out. The machine I have is a PAL system and is in good condition. Case has yellowed a little bit, but the PCB looked absolutely mint. This 800XLF will not receive any mods, and I'll preserve it. Hi, are you sure i's an XLF PAL ? I mean the output is a coaxial cable but with a Freddie inside ? Could you upload a picture of the motherboard ? Thanks. Quote Link to comment Share on other sites More sharing options...
redhawk668 Posted July 13, 2018 Share Posted July 13, 2018 (edited) Hi, are you sure i's an XLF PAL ? I mean the output is a coaxial cable but with a Freddie inside ? Could you upload a picture of the motherboard ? Thanks. Yes, I am sure of that. It says 800XLF Rev. R3 on the underside of the PCB, it has a modulator and it’s a European machine so that means PAL version. It has a Freddie chip, because the lay-out is completely different and it has a chip with the markings CO61618 on it and the GTIA has moved upwards, so yeah pretty sure of that . Uploading a picture means I have to disassemble it again..., so will take some time. Edited July 13, 2018 by redhawk668 Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted April 1, 2022 Share Posted April 1, 2022 I just opened up one of my eBay purchases and found one of these. Is there any info available concerning memory or video upgrades. Quote Link to comment Share on other sites More sharing options...
