tjlazer Posted March 29, 2006 Share Posted March 29, 2006 Hi, I am trying to burn a TOS 2.06 image for my Mega STE. I have to split the file in two files to burn to ROMs. I used a PC program called WinHEX that can split every other word to make a new file, and I used it to make a Amiga 1200 kickstart ROMs successfully. The question I have is for the LOW and HIGH ROMs on the Atari. The low is the first set and high the second set? ROM 1 and ROM 2 is LOW/HIGH Correct? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted March 29, 2006 Share Posted March 29, 2006 Hi, I am trying to burn a TOS 2.06 image for my Mega STE. I have to split the file in two files to burn to ROMs. I used a PC program called WinHEX that can split every other word to make a new file, and I used it to make a Amiga 1200 kickstart ROMs successfully. The question I have is for the LOW and HIGH ROMs on the Atari. The low is the first set and high the second set? ROM 1 and ROM 2 is LOW/HIGH Correct? I believe thats correct. Although the ROMs I have are listed as "EE" and "EO". EE goes in ROM 1 and EO goes in ROM 2. HTHs. Quote Link to comment Share on other sites More sharing options...
krupkaj Posted March 30, 2006 Share Posted March 30, 2006 You can use pinatubo for splitting ROM files. I believe it is available on some ftp. I certainly downloaded it from internet. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted March 31, 2006 Author Share Posted March 31, 2006 I did and could not figure out to use the program! Do you know how? Quote Link to comment Share on other sites More sharing options...
krupkaj Posted March 31, 2006 Share Posted March 31, 2006 (edited) It is easy. I hope you have the English version (if not there is patch for german rsc file in the archive). I am using the program together with Junior-Prommer for programming EPROMs. If you have not aproproate programming hardware you can still use it for preparing data for burning. Choose type of memory you have (Options -> Choose Type). Load your image. Choose which part of image you want to use for programming (Options->Split Even/Odd). Now you can programm the EPROM or just save part to disk. The program asks you what you want to save (whole file or selected part). I hope it is enough. My English is not good enough for writing how-tos. Edited March 31, 2006 by krupkaj Quote Link to comment Share on other sites More sharing options...
tjlazer Posted April 29, 2006 Author Share Posted April 29, 2006 That was mostly the problem, I have the german one and don't speak deutch. lol Do you have the English one? Quote Link to comment Share on other sites More sharing options...
krupkaj Posted April 29, 2006 Share Posted April 29, 2006 PM sent Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted January 16, 2013 Share Posted January 16, 2013 Does anyone know how to split 1.04 single .img file into 6 images? I can write a win32 exe to do this if anyone knows how to split the file? I guess I need to also understand which 3 will be LO and which HI? Searched loads for this and cannot find anything detailing the process. Quote Link to comment Share on other sites More sharing options...
Lynxman Posted January 16, 2013 Share Posted January 16, 2013 (edited) Does anyone know how to split 1.04 single .img file into 6 images? I can write a win32 exe to do this if anyone knows how to split the file? I guess I need to also understand which 3 will be LO and which HI? Searched loads for this and cannot find anything detailing the process. 1) Split into high/low-Byte 2) Split both files in 32K segments Edited January 16, 2013 by Lynxman 1 Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted January 16, 2013 Share Posted January 16, 2013 Thanks! Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 17, 2013 Share Posted January 17, 2013 I think that my SW, made specially for Atari ST(E), TT machines should not be problem how to use: http://atari.8bitchip.info/astopensw.php Romsplit.zip Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted January 17, 2013 Share Posted January 17, 2013 Thanks! You've got some awesome utilities on your site - just looking at your site has saved me posting more questions. I was going to ask for apps to make ST think it has 0.5 / 1 mb but thats on your site =) Is it a.good idea to put 1.04 on my STFM or should I stick with 1.02, or us there any reason to go to 1.03 or other? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 18, 2013 Share Posted January 18, 2013 ... Is it a.good idea to put 1.04 on my STFM or should I stick with 1.02, or us there any reason to go to 1.03 or other? If you don't use hard disk, then 1.02 will be OK. 1.03 ??? 2.06 is best TOS v. for ST, STE, but not if gaming is main usage. And you need little circuit + if want to use 2.06 in ST. Quote Link to comment Share on other sites More sharing options...
Audronic Posted February 18, 2015 Share Posted February 18, 2015 (edited) @ All I have just split the tos206US into 2 files :- tos206us.lo with a checksum of A695 (h) tos206us.hi with a checksum of 27C2 (h) does anybody know if this is correct. and / or is there a listing of checksums somewhere Please. Thanks Ray W__________ Edited February 18, 2015 by Audronic Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted February 18, 2015 Share Posted February 18, 2015 TOS 2.06 calculates checksum at every boot (reset). So, if it does not complain during it, checksums are OK. If you did split and checksum fix with romsplit (link above) then it must be OK. CRC calculation used by fixing is taken from TOS 2,06 himself And, checksums are at end of TOS - just need to combine properly. I guess A6 with 27 and 95 with C2 - you'll figure it out . Quote Link to comment Share on other sites More sharing options...
Audronic Posted February 18, 2015 Share Posted February 18, 2015 @PLM Thanks for that, I was after a link or list of checksums for the various TOS versions. It would save a lot of time if i had a list of the checksums. Thanks anyway Ray W______________ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted January 6, 2023 Share Posted January 6, 2023 (edited) Is my problem of not detecting my hard drive on the 1040STF simply because that Atari ST only has TOS 1.0, i have 6 sockets with TOS 1.0 in them, what I want to do is put TOS 2.06 into my 1040 ST. Russ PS: I have 2 extra Eprom Burner kits all complete if anyone desires one. I am not interested in cash for them, perhaps a trade of some sort? And I have one external SF314 drive without power supply or cables, and 4 Atari Internal drives for trade. Edited January 6, 2023 by rcamp48 Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted January 6, 2023 Share Posted January 6, 2023 2 minutes ago, rcamp48 said: Is my problem of not detecting my hard drive on the 1040STF simply because that Atari ST only has TOS 1.0, i have 6 sockets with TOS 1.0 in them, what I want to do is put TOS 2.06 into my 1040 ST. Russ PS: I have 2 extra Eprom Burner kits all complete if anyone desires one. I am not interested in cash for them, perhaps a trade of some sort? STF can only work with TOS 1.04 and below if you want to take the easy route. Just needs 6 new EPROMs. For TOS 2.06 you need some decoder logic. So additional hardware is needed. That is because TOS below 1.04 is 192Kb and TOS 1.06 and higher is 256Kb so it will not fit at the same address space. Quote Link to comment Share on other sites More sharing options...
