CosmicJoke Posted February 25, 2002 Share Posted February 25, 2002 I need some help. Can you play Sege Genesis carts in a Mega Drive? Can you play Sega CD games in a Mega CD? Or, do both these need to be modified? Any help or opinions would be appreciated Quote Link to comment Share on other sites More sharing options...
Adrian M Posted February 25, 2002 Share Posted February 25, 2002 Genesis to Megadrive (and vice versa) will work without a mod since a Mega Drive has a larger cart opening allowing you to use any cart without modification. The connector parts are identical on the U.S. Genesis and the Mega Drive, its just that the U.S. Genesis has a differently shaped plastic casing which will restrict the type of carts you can use. However, this is easily bypassed. Back in 1989, my friends and I used the so-called "shaving" technique to round out the cart port casing. Or you could just buy a cart port extender thing (they call them a convertor, but they don't actually convert anything) that looks like the Sonic and Knuckles cart. As for SegaCD to MegaCD, that's a different story. According to import game shop, Playthegames.com, you can use a MegaCD and Genesis HARDWARE interchangably, you can't use SegaCD and MegaCD software interchangably, at least not without a convertor thing called a CD-X (or something like that). From what I understand, these convertors are rather hard to come by. You may want to do some research on the net as there may be some hacks or workarounds, but this does sound right to me as I remember reading into this subject in detail back in the early 90's. Quote Link to comment Share on other sites More sharing options...
Eduardo Posted February 25, 2002 Share Posted February 25, 2002 You should also notice that there are 4 jumpers inside the unit, Jumpers 1-2 set the language (jap or english) and Jumpers 3-4 set display typle (NTSC or PAL) I strongly recommend you to read the Sega Genesis FAQ section 1.2 to understand in depth all about the compatibility issue. Quote Link to comment Share on other sites More sharing options...
CosmicJoke Posted February 26, 2002 Author Share Posted February 26, 2002 Thanks for the help guys I wasn't aware of a Sega Genesis FAQ, so, I will check it out. Quote Link to comment Share on other sites More sharing options...
King Atari Posted February 26, 2002 Share Posted February 26, 2002 On a somewhat related note, Genesis Double Dragon states on the cart's label that it will work in both ! Quote Link to comment Share on other sites More sharing options...
