    36
    32
    73,370
Ms. Pacman - Fruit Locations
jwierer
After playing upside down Ms. Pacman (see this blog post) i was a little disappointed with where the fruits would appear because they were still set to the original tunnel locations. If that locations happened to be a maze it would warp though it - awkward, but ok. If it had some empty space followed by a maze part the fruit would appear, bounce into the wall and then disappear off into space and you'd never get to eat - not the desired result. Based on some additional technical knowledge I got from Bob, I know now that Ms. Pacman and Pacman collection both contain a table of "row" locations with specify where the tunnels are in each level. The columns for these locations are actually shared for the entire game so a change there would mean all levels would need to conform to that change. Because it's just easier to use coumns 0 and 27, I used as fixed columns that can hold the tunnel locations. It's now possible to set fruit start and end locations in my Pac-man editor!
You can actually change the pattern that the fruit takes, but for the sake of my purposes that is a bit more involved than is necessary :)
Now the fruit locations are correct for my upsidedown Ms. Pacman
While I am at it, it was pretty easy to create an upside down version of Pacman. While I was at it I corrected the dot color. The arcade is actually slightly peach colored, not white!
and for anybody interested in trying these out here are the binaries
upsidedownMsPac.bin UpsideDownPacman.bin
-Jeff
