    36
    32
    73,370
Creating an Animated Title Screen in in bB
jwierer
If you're reading this, then you've already downloaded this test version of visualbB, if not you're not going to get this to work! One of the nice features of the title screen kernel is you can use the 48x1 mini kernels to create an animated component of your titlescreen. This example uses the ex3-animation images included with the titlescreen kernel.
1.Launch the Titlescreen editor
2.Add 5 new kernels with the following settings
 a.Kernel = draw_48x1_2
ii. Set the backcolor to white
iii.Check the colorcycle checkbox
 b. Kernel = draw_space
i. Spaces = 10
 c. Kernel = Draw_48x1_1
ii. Set color to $77
iii.Change the kernel to Draw_48x2_1 (this is a trick to set each line color since this kernel uses a color per line)
iv. Height = 40 (This is height of each frame and is the an important for the effect to render properly)
v. Check the Animated radial button
 d. Kernel = draw_space
i. Spaces = 20
 e. Kernel = draw_48x1_3
3.Click Preview and you should see something like this
