    657
    2,692
    898,698
improved 6507 to C defines
One of the difficulties about working with 2 sets of code (6507 assembly and C) is there's some common info that both need to know. Manually maintaining that info in 2 places is error prone, so you want to limit that as much as possible. While developing Stay Frosty 2 I came up with the idea of having the 6507 assembly maintain that info, and output it for C via echo commands:
echo "#define SUB   queue[",ARMsub,"]"echo "#define SWCHA queue[",ARMswcha,"]"echo "#define SWCHB queue[",ARMswchb,"]"echo "#define INPT1 queue[",ARMinpt1,"]"        echo "#define INPT4 queue[",ARMinpt4,"]"echo "#define ElevatorHM26 ",ElevatorHM26echo "#define ElevatorHM31 ",ElevatorHM31
which dasm would output in the terminal:
#define SUB   queue[ $0 ]#define SWCHA queue[ $1 ]#define SWCHB queue[ $2 ]#define INPT1 queue[ $3 ]#define INPT4 queue[ $4 ]#define ElevatorHM26  $f7d1#define ElevatorHM31  $f804
I would manually copy/paste that into a C header file, followed by an additional step to find/replace the $ with 0x as dasm and C use incompatible formats for representing hex values.
#define SUB   queue[ 0x0 ]#define SWCHA queue[ 0x1 ]#define SWCHB queue[ 0x2 ]#define INPT1 queue[ 0x3 ]#define INPT4 queue[ 0x4 ]#define ElevatorHM26  0xf7d1#define ElevatorHM31  0xf804
Eventually I discovered that dasm could out values in decimal by wrapping the value in brackets followed by a d:
echo "#define SUB   queue[", [ARMsub]d ,"]"echo "#define SWCHA queue[", [ARMswcha]d ,"]"echo "#define SWCHB queue[", [ARMswchb]d ,"]"echo "#define INPT1 queue[", [ARMinpt1]d ,"]"        echo "#define INPT4 queue[", [ARMinpt4]d ,"]"echo "#define ElevatorHM26 ", [ElevatorHM26]decho "#define ElevatorHM31 ", [ElevatorHM31]d
which would output:
#define SUB   queue[ 0 ]#define SWCHA queue[ 1 ]#define SWCHB queue[ 2 ]#define INPT1 queue[ 3 ]#define INPT4 queue[ 4 ]#define ElevatorHM26  63441#define ElevatorHM31  63492
Still had to copy/paste the values, but less work.
Then in 2016, while we were working on Bus Stuffing, cd-w came up with this:
dasm testrom1.asm -f3 -otestrom1.cu | awk '!x[$$0]++' | grep "#define" > $(BASE)/defines_dasm.h
It uses awk and grep to automatically capture the echoed out #defines and stash them in the header file for the C code. Awesome!
After implementing that in SpiceC I wondered if I could improve upon it as writing all those echo statements would be tedious. After reading up on awk and realizing it could process columns of data, I got to thinking that the symbol file dasm outputs was in columns:
--- Symbol List (sorted by symbol)0.FREE_BYTES             0000                  1.CLEAR_STACK            7c02              (R )2.KernelSize             0100              (R )2.PageCount              0001              (R )2.Start                  7c41              (R )AMPLITUDE                0022                  ARMaudc0                 000b                  ARMaudc1                 000c                  ...VerticalBlank            7c2a              (R )VerticalSync             7c19              (R )VSYNC                    0000              (R )WSYNC                    0002              (R )--- End of Symbol List.
If I could format the results I could use columns 1 and 2 to create the define file. One issue is the first and last line would be invalid, as would the symbols that started with numbers like 2.Start, so I'd also need to include some selection logic.
After some trial and error, and a bit of pondering, I came up with the following:
dasm ../../Include/main.asm -I$SPICEC_INCLUDE -f3 -v0 -s$PROJECT.sym -l$PROJECT.lst -o$PROJECT.binawk '$0 ~ /^__/ {printf "#define %-20s 0x%s\n", $1, $2}' $PROJECT.sym >> $DASM_TO_C
The dasm step does a normal compile and creates a symbol file. The awk step scans the symbol file for anything starting with __ and creates the define file for C. Given this:
--- Symbol List (sorted by symbol)0.FREE_BYTES             0000                  1.CLEAR_STACK            7b02              (R )2.VBwait                 7c02              (R )5.KernelSize             0015              (R )5.PageCount              0001              (R )5.ScoreLoop              7d0a              (R )5.Start                  7d00              (R )__ARMmode                0009                  __AUDC0                  000b                  __AUDC1                  000c                  __AUDF0                  000d                  __AUDF1                  000e                  __AUDIO                  0000              (R )__AUDIO_MUSIC            0001              (R )__AUDIO_SAMPLES          0002                  __AUDIO_TIA_ONLY         0000              (R )__AUDV0                  000f                  __AUDV1                  0010                  __COLUBK                 0012                  __COLUPF                 0011                  __DISPLAY_DATA_4_ARM     0013                  __FRAME                  000a                  __FUNC                   0000                  __INPT1                  0005                  __INPT3                  0006                  __INTP4                  0003                  __INTP5                  0004                  __OSTIME                 0008                  __RUN_GAME_OS            0004                  __RUN_GAME_VB            0003                  __RUN_INIT               0000                  __RUN_INIT_LEVEL         0007                  __RUN_MENU_OS            0002                  __RUN_MENU_VB            0001                  __RUN_SPLASH_OS          0006                  __RUN_SPLASH_VB          0005                  __SWCHA                  0001                  __SWCHB                  0002                  __VBTIME                 0007                  __WAVE_SIZE              0020                  AMPLITUDE                0022              (R )ARM_CODE                 0800              (R )ARM_CODE_SIZE            0fe1              (R )AUDC0                    0015                  AUDC1                    0016                  AUDF0                    0017                  ...VerticalBlank            7d3d              (R )VerticalSync             7d20                  VSYNC                    0000              (R )WSYNC                    0002              (R )--- End of Symbol List.
the resulting file contains:
#define __ARMmode            0x0009#define __AUDC0              0x000b#define __AUDC1              0x000c#define __AUDF0              0x000d#define __AUDF1              0x000e#define __AUDIO              0x0000#define __AUDIO_MUSIC        0x0001#define __AUDIO_SAMPLES      0x0002#define __AUDIO_TIA_ONLY     0x0000#define __AUDV0              0x000f#define __AUDV1              0x0010#define __COLUBK             0x0012#define __COLUPF             0x0011#define __DISPLAY_DATA_4_ARM 0x0013#define __FRAME              0x000a#define __FUNC               0x0000#define __INPT1              0x0005#define __INPT3              0x0006#define __INTP4              0x0003#define __INTP5              0x0004#define __OSTIME             0x0008#define __RUN_GAME_OS        0x0004#define __RUN_GAME_VB        0x0003#define __RUN_INIT           0x0000#define __RUN_INIT_LEVEL     0x0007#define __RUN_MENU_OS        0x0002#define __RUN_MENU_VB        0x0001#define __RUN_SPLASH_OS      0x0006#define __RUN_SPLASH_VB      0x0005#define __SWCHA              0x0001#define __SWCHB              0x0002#define __VBTIME             0x0007#define __WAVE_SIZE          0x0020
One of the benefits of using __ as a prefix is it lessens the chance of these defines conflicting with any end-user code.
  • Like 5
3 Comments
With batari Basic, I use one underscore at the beginning of variable aliases and two underscores at the beginning of labels. Then I don't have to worry if I'm using the same name for variables and labels. You might want to start those with 3 underscores in case others do what I do. Then there would be absolutely no chance of having conflicts with end-user code.
Will do.
I'm making good headway on the C side, the SpiceC make compiles everything for your project and makes a functional ROM, though at the moment the only thing it does is clear out Display Data RAM. Next up I'll be working on the routines to implement the Splash Screen, Menu, and Game - basically console detection (so colors will be correct for NTSC/PAL/SECAM) and support for SELECT and RESET to take you to the Menu and Game respectively.
I've removed some diagnostic info from the following. The game.c file contains your C code for your project. I've set it up so multiple C files can be in your project, allowing you to break up the code (such as menu.c, game.c, newlevel.c, etc,) and the make step will automatically find them and include them in the compiled project (though I've not yet tested it to confirm it works).
darrell@darrell-VirtualBox:/media/sf_Atari/SpiceC/Projects/test$ spicec.sh make
Step 1/4 - Create info needed for C code
 29440 bytes available for C code & data
Complete.
Step 2/4 - Create defines_from_dasm.h for C code
Step 3/4 - Compile C code
    Compiling bootloader
    Compiling SpiceC main
    Compiling game.c
    Creating ELF file
    Extracting ARM code
Step 4/4 - Build BIN
 324 size of C code & data
 29116 bytes free
Complete.
Tested the multiple C files during lunch, worked as expected. I revised all the temp files to also start with ___ and to automatically add a date-time stamp to the BIN file (so when you upload BINs to AtariAge it'll be easy for people to know which version they're testing). The example below is for project test
Darrells-Mac-Pro:test darrellspice$ ls -l
total 328
-rwxrwx--x  1 darrellspice  staff    340 Mar  6 12:51 ___arm_code
-rw-r--r--  1 darrellspice  staff   1164 Mar  6 12:51 ___custom.o
-rw-r--r--  1 darrellspice  staff    912 Mar  6 12:51 ___game.o
-rw-r--r--  1 darrellspice  staff   2072 Mar  6 12:51 ___main.o
-rw-r--r--  1 darrellspice  staff    912 Mar  6 12:51 ___menu.o
-rw-r--r--  1 darrellspice  staff  58296 Mar  6 12:51 ___test.lst
-rw-r--r--  1 darrellspice  staff   9462 Mar  6 12:51 ___test.sym
-rwxrwx--x  1 darrellspice  staff   8860 Mar  6 12:51 ___testarm.elf
-rw-r--r--  1 darrellspice  staff   7347 Mar  6 12:51 ___testarm.map
-rw-r--r--@ 1 darrellspice  staff    280 Mar  4 13:16 config_for_c.h
-rw-r--r--@ 1 darrellspice  staff    261 Mar  6 12:22 config_for_dasm.h
-rw-r--r--  1 darrellspice  staff   1417 Mar  6 12:51 defines_from_dasm_for_c.h
-rw-------@ 1 darrellspice  staff    133 Mar  6 12:22 game.c
-rw-------@ 1 darrellspice  staff    133 Mar  6 12:46 menu.c
-rw-r--r--  1 darrellspice  staff  32768 Mar  6 12:51 test_20180306_125120.bin
current output of spicec.sh make:
Complete.
Step 2/4 - Create defines_from_dasm_for_c.h
    36 defines created
    Compiling game.c
    Compiling menu.c
    Creating ELF file
    Extracting ARM code
Step 4/4 - Build BIN test_20180306_125120.bin
 340 size of C code & data
 29100 bytes free
Complete.
