DOS 1.0 files, they're out there
In looking over the ACE of Columbus disks, I originally thought disk acec027b.atr had some problems, but it turned out, it simply had something I hadn't seen before, a DOS 1.0 file on a DOS 2.0 disk. You can see this by using the -dir command we wrote in the past.
00 42 039 004 DOS SYS 01 42 014 043 INFOBITSBAS 02 40 080 085 STING 03 42 150 165 MALAGUEN 04 42 092 315 FLIGHT 05 42 069 416 ELEPHANT 06 42 185 485 QUEST 32K 07 42 031 670 TARGETS BAS 08 42 017 701 ENEMY BAS 09 42 010 057 INFOBITSTXT 10 42 012 067 MAIL BAS
Notice that the file STING has a status byte of 0x40 instead of 0x42 like the rest of the files. The 0x02 bit indicates a DOS2.0 format file, so this file is in DOS 1.0 format.
What is DOS 1.0 format? Well, it's very similar to DOS 2.0 format, except the byte count field is instead a sector index (0 in the first sector, 1 in the second, …) in all but the last sector, where it is the traditional byte count again but with the 0x80 bit set as well.
For parsing a DOS 2.0 file we handled the last three bytes in the following way:
my ($nextSector, $nBytes) = link_data($sectorData); $out .= substr($sectorData, 0, $nBytes); $sector = $nextSector & 0x3ff; last if $sector == 0;
We can support DOS 1.0 files as well by adding this after the first line:
$nBytes = ($nBytes & 0x80) == 0 ? 125 : ($nBytes & 0x7f) if $dos10;
Which is the Perl code to implement the following code you can find in DOS 2.0S:
104C 68 5040 PLA ;GET LEN 104D 3002 5041 BMI RDNS2 ;BR IF OLD SHORT SECTOR 104F A97D 5042 LDA #125 ;ELSE SET FULL SECTOR 1051 297F 5043 RDNS2 AND #$7F ;TURN OFF MSB 1053 48 5044 PHA ;BALANCE STACK
Notice that this design means the sector index has to wrap every 128 sectors, but that's not a problem. The problem with this design (and likely why it was changed with DOS 2.0), is that the sector size can't be larger than 128 bytes, since you only have 7 bits to store the length of the last sector. DOS 2.0S supports 256 byte sectors, so something had to change. There are many possible changes they could have made, making the last byte the actual byte count is just one solution.
