Car troubles
My car's been acting really weird lately. I had it looked at on last Friday and the ignition switch was replaced because I thought that was the problem. It turns out that the problem is much worse.While driving to work today, I stopped to get some gas. After filling up, I attempted to start the car and nothing happened. So, I had to call AAA and have them call a flatbed. I had the car towed to a service station 2 and 1/2 miles from where it broke down. It turns out that the car has an oil leak somewhere and that leak has caused the starter to get dirty, thus affecting the way the starter works. It appears to be a new starter but for some reason, the mechanic thinks it is malfunctioning due to the oil leak.So, in turn, I told the mechanic to go ahead and replace the starter with a rebuilt starter. He says this might work for the short term but in the long term, I will need to find the leak in the engine and fix it. The only reason I didn't opt for that is because it would cost more money than what I can afford and there's still no guarantee that things would be fixed. My boss suggested that I clean off the engine, start the car and watch and see where the oil leaks. If it leaks out of the head gasket, it'll cost $$ to replace. If it's somewhere else, I might be lucky. Until then, hopefully that rebuilt starter will help for the short term. I really don't have a lot of money to put in the car. Also, I feel a sense of responsiblity by taking the car to a mechanic and paying for the repairs. For the first time since I got my license, I'm not depending on my dad to help me with this. I feel that I've gotten enough help from him over the years and that it is time for me to take responsibilty for my car. I've evaded this for years and ended up owing my father a lot of money in the process. It has to end sometime.Hopefully my car will be ok. I really do hope.
