2,909 -
Posts posted by Rob Mitchell
Work great .. there are some label errors on the PCB. verify circuit via continuity meter ..
Q: ask me ..I have built four ..
Interested as well for 2.
1 hour ago, Nathan Strum said:Sadly, in the very next panel, he was picked off by a sniper.
Haha!
2 hours ago, Philflound said:How much did you pay?
$10
I finally modified my RSI to be a 7800 controller .. I have a second one I might modify to work with the Vectrex.
More stuff up on his page ..
I chose not to take the rubber hand grips off their shafts because I was just cleaning things up and investigating the pot. It went back together just fine.
Problem with Stunt Cycle is that the mechanism limits the range of the pot which on the Vectrex registered from 1/2 UP to full UP when I tested it. Adding resistors changed nothing.
Some variable joysticks can be modified to work with the Vectrex with the addition of resistors to the outside tabs of the pots.
This afternoon I took the Stunt Cycle down to its bits for a complete cleaning .. I did everything but take the rubber grips off the plastic shafts .. I’ll clean the pot with deoxit to keep it working smoothly .. and the switches too.
The pot is 100k Ohm .. nice clean spring to make the grip return to rest.
I am thinking of adding a port to the back of the unit so that I can connect it to other consoles .. like the Vectrex.
Is it the machine or the sticks? If you detach both sticks .. does the problem go away?
On 9/21/2019 at 1:29 AM, atari2600land said:This evening my wife helped me by printing out end labels for some of my carts. 2, 3, 4, 5, 9, the site is missing end label scans for 10 and 14.
Anyone know of another site with scans?
Does anyone have a spare Push To Eject Button as in the above picture?
Who has controllers with the red fire buttons in front?
Does anyone have a spare “Press to Eject Cartridge” black button?
On 11/17/2019 at 8:31 PM, Kcvex said:Anyone know where i can get that black plastic clip that holds the controller when you store it? Mine broke
I have an extra .. You will have to be able to remove the CRT and circuits out of the way.
A pair of driving controllers were packed in with each Atari Indy 500 / Sears Race cart .. originally released the first year 1977. Cost was $40 then.
i did not understand how they worked until I plugged them into the Vectrex running the controller test function .. many years ago:
They are rotary digital switches which create button pushes called Quadrature encoding ..
Interest: Color Composite video of Coleco Combat?
in Dedicated Systems
Is anyone interested in a new circuit which puts out a composite color signal from Coleco Combat?
Rob Mitchell
