Posts
1,374 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by sage
1 hour ago, LordKraken said:
newcc65 vintage and lynxer
a lynxer still. but why.
3 hours ago, LordKraken said:
yep so I guess I have a problem with the bootloader somehow, because creating the rom with 2048 bytes/block seems to work fine.
Any idea where I should look for that?
can you give details about your chain?
On 8/25/2020 at 7:06 PM, karri said:
Titan is just a graphics "look, what I can do" game with some fun ballistics. It was only 50% ready after the 4 days I had time to write code. I should have read the instructions earlier.
Minimal is also just "work in progress"hehe with this competitors maybe i should have thrown in some 50% done game engine, too ?
- 1
same ancient code base.
maybe different patches in the last years.
6 hours ago, 42bs said:
I see one problem with the current releases (tool set problem): The files are filled with 0x00, which means for flashing each byte needs to be written. Better would be to fill them with 0xff.
parameter -f
- 1
a pity that it only supports to cores and is not working with the epyx comlynx code ?
i really would need some better way to test and make
promo video
- 1
- 1
ah. who wanted to do that?
Is there any progress on this?
It was somewhere hidden on my web site, which i did not update for loooong time.
I guess i should move everything to github ... but i am too lazy to check the copyright things ?
https://github.com/bspruck/lyxass_lib
I normally softlllink al files into a single folder... thus some of my code might need pathname changes, like in
https://github.com/bspruck/badapple
i am always to lazy to put some examples somewhere , but here you can see how i structure my makefiles
you can use the "copy an already working environment" ansatz.
if you look into the chipper folder for example, you see that it compiles the music to a full rom as all tools and sources are included. (for windows, and quite outdated)
you need:
lyxass
lyxass "libraries" -> includes/macros/vardefs
(and optional a rom builder, as most emulators and flash card tools can handle single-file-memory-living-programs directly)
optional: sprpck (for building sprites from pictures)
if you want to have a more complicated project, which contains several files dynamically loaded from card, title pic etc it gets complicated..
the template is for cc65, not necessary for assember projects
4 minutes ago, OldAtAtari said:
Was lynxer the assembler before lyxass came about?
no, it is the old ROM builder.
but it is a bit annoying as it can only create this "troyan horse" style card layouts.
you find a replacement on http://lynxdev.atari.org/ or newer on my github site
same for some bugfixed/patched version of lyxass.
if you use C wit the current cc65, it doesnt matter, as it embeds its own card layout and builder.
On 8/5/2020 at 11:04 AM, OldAtAtari said:
--> lynxer/
gosh, there is still someone using lynxer ... this only makes troubles
On 7/29/2020 at 4:34 AM, karri said:
The Lynx adapter is available separately. It is not included. I also wonder a bit on the fact that there is no ROM code in the Analogue Pocket. This also means that it cannot boot everything a real Lynx can. Some people may rely on an existing ROM in the unit.
if they copied my code from the emulation core, it will work for 99.x% of the roms. beside some homebrew demos maybe
- 1
i says i *will* get an card adaper, not that it plays lynx games
ps unil now i have no seen a working lynx core yet
- 1
- 1
holiday in finland, why not
- 1
as you like :shrug:
On 7/10/2020 at 6:30 AM, miker said:
I'm interested in arpeggios like 0 3 7, 0 4 7, 0 5 7 etc. (where the numbers are successive tranpositions in note table).
Is there possibility to make such a ones in Chipper? If so, can anybody help me?
no. unluckily, there is not note table. the frequency steps arenot very accurate, too.
you cannot use negative coordinates.
-> The screen offset need to be larger than the sprite position (action point), (the sprite might still be go out of the full world map depending in wher you set the action point).
- 1
Start????
opt 1 and 2 normally map to "1" and "2", A and B to YX or ZX, depending on your keyboard
yeah too busy and lazy.
18 hours ago, SainT said:
Any you wish to contribute will be welcomed!
without knowledge on how you do the patching and without a cartridge, unlikely. But you can PM me if you have details.
Lynx 2020 Programming Competition
in Atari Lynx Programming
no
