Posts
1,374 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by sage
12 minutes ago, karri said:
I am not an expert here. But basically setting AUDIN is like:
and #$10 ora #$b sta IODAT
So the bit to set corresponds to the mask $10
I think this is teh reason that not the register, but a shadow variable is set
i know that feeling
35 minutes ago, Fadest said:
Thanks, this confims what I saw/understood.
Do you confirm that AUDIN to use is bit 5 of IODAT and not AUDIN ?
some old code i found. maybe this explains how i do it
The boot loader needs to be in both AUDIN switchable banks, as the power up state is undefined or better, differs between different lynx versions.
Thus the first thing the bootloader code has to do is to bring the bit to a defined state.
Where you put your directory is then up to you.
I decided to have it in bank0 only, and switch AUDIN back and forth each time I access it. the bank is encoded in the upper bits of the offset as the block number is already using 8 bits.
i am not sure if this was already called "fork" 20 years ago...
hmmm... i have to check the license for the one i am using ... not sure if i am allowed to pulish my changes...
13 hours ago, 42bs said:
? SIMIS contains a "Handy-Protection". Of course, I have a version w/o
I repeat. good work ?♀️
maybe a bad idea :-((((
luckily i was able to find the problem within minutes.
ugly bug:
lyxass accepts
stx (tmp)
and
sty (tmp)
but translates it to
STA ($00) ;
STX $00 ;
STY $00 ; -
really? i never got simis runnign in the emulator even with eeprom. good work
Feel free to upload the Roms ?
For preservation purpose only ... eeproms dont last forever ... ?
33 minutes ago, LordKraken said:
@sage(I replaced all non-secure C function).
26 minutes ago, Clint Thompson said:
So a quick search and I found that Duranik has a mod player for the Lynx that you can convert 4ch mods into lynx music, though I'm unsure how you implement the player or where you would find that. Has anyone used their tracker before?
yes sure, you find the source code for asm and cc if you look for it. but it is very limited in terms of cpu, memory and supports no effects. But this was discussed already 17 years ago...
including eeprom support
7 hours ago, karri said:
Thanks @sage. Most useful utility.
happy to hear that.
a pirate copy?
but it looks like Carl is using the old compiler ?
somewhere i still have the source files to access 8 and 16 bit for different kind of eeproms for cc65. if you need it i might dig them out.
On 3/6/2020 at 11:06 AM, JohnBuell said:
Somebody broke sound in Gates of Zendocon from 0.971 to now. Doesn't seem to work in 0.98 or this 0.99 version. The laugh of Zendocon is my first test for sound compatibility.
there is no offical numbering. everybody numbers his compiled release different. would be nice if you meantion the source of your download.
Just a remark: the instrument export is really bad. I agev up on making it better. Thus you better optimize them afterwards or take from sass.
what a strange coincidence, indeed.
well it does not write out this complicated SASS files, but directly the assembler code (with macros for better readability).
As it is creating directly a lnx file (and there is a reason the lnx file looks very similar to the handymusic example :-)), you can easily see how to include the files into your own project.
so you want your keyboard sound like a lynx, not connect the keyboard by midi to a real lynx?
17 minutes ago, enthusi said:
You can do it at 60Hz as well. I think HBL is not best suited since you lose the time you would otherwise have in Vblank. But it should work as well in HBL ?
The tree is nice In general you'd want motives with vertical gradients to show off the colors.
ONe question: how much is the music distorted if you use this?
Lynx arranger instrument
in Atari Lynx
You can ?
Just have to stream the midi commands from the card -> see my synth examples
