Posts
444 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by adamcon
3 hours ago, rietveld said:
i will try those also if you post them. i am used to CP/M kermit but didnt see that in the archive
Here ya go. BITD I think I used Zmodem more because I could set it to auto and download stuff from BBS's while I was gone for the day.
Found a copy of Quick Term for CP/M
http://adamarchive.org/archive/Adam/CPM & TDOS/Telecommunications/
there is also Madam 7 and also Z modem. Will upload soon.
Tain't looking good here, Florida still locked down in our county, and when we get to Michigan 3rd week of May, they are locked down till June.
7 hours ago, videofx said:
I cant find my MicroFox's Dual CF IDE Boot Disk or DDP
Anyone know where I can download? Cant find it in any of the archives.
Also anyplace to get a printer cable for the IDE card?
Thanks!
Should be what you want I think. Also if you need a printer card for the printer card, I have them.
ADAM IDE Boot Driver with Hard Disk System v5.0 (2014) (AJM - RJD Software).dsk
15 hours ago, rietveld said:
Tested..................like as in it can read the cardboard shipping disk? But, but, the light comes on and not quite sure where the ribbon cable attaches.......
6 hours ago, RT12 Productions said:
I assure you that it ISN'T vaporware! Derek Else (the original programmer) recently did some more demo updates (which DON'T seem to work within BlueMSX, by the way), but DO work within ColEm, and some other ColecoVision emulators. He and I are looking into further programming developments to help bring this much-needed game into fruition. Good quality video games DO take time to produce. Thank You!
You are correct RT12, I have an updated version from Derek (not for release) and it is rather good. Can always use some polishing like most things. KEEP GAMING!!!
10 hours ago, rietveld said:
I have everything working. There is a wire that connects to the 'Access 'light on the front panel but I can't find anything on the harddrive that it connects to. I assume this was for a floppy drive since the case and PCB seem to have room for those components
Somewhere, somehow, there is usually a set of pins for a hd light. The trick i to find it. When used for an MI disk drive, is used as a power on light.
8 hours ago, rietveld said:
it seems that the IDE does not work with atapi Zip drives. i assume that the original Zip 100 was not an atapi and as such does work . I tried all combinations of jumper settings but no luck.
I guess that the larger Zip drives use the same ATA Packet interface as CD roms
BINGO!!! The drive must be labeled as a Zip IDE in the id label; ATAPI drives will not work. These are hard to find and are the only ones that will work. If I recall, the 100 version is the only one that will work. The small Sparq drives work the same way as the Zip. Other than a cool adaptation, the mainline IDE hd or the CF versions are easier and more reliable to use.
The IDE card can certainly be used with a physical IDE hard drive. It is slower than the compact flash version and susceptible to failure at a higher rate than than compact flash cards which are basically memory chips. I have an ADAM's set up that way as well as with a zip drive and one with a sparq drive (just for fun). It takes a special set of disks to format and set up the physical drives on a physical spinning IDE drive.
AH HA !!! there is a recipe for failure. I also have reused lots of disks, 5 1/4 and 3 1/2. The failure rate of old reused disks is a problem; I have no knowledge of why or how, but I do know that they tend to go bad quicker than new old stock - even old ADAM disks seem to fair better than other reused computer disks.
I have had a few disks work perfectly after I make them, then suddenly have missing blocks when I go to use themn a few days later. This doesn't happen to all the disk.
Better safe than sorry. On another note, I have left booting ddp's in for years (pop open after booting to not heat the ddd) and they boot up every time when the ADAM is turned on. Maybe it could be described as a crap shoot.
The disk does read fine. It just wonnt format a blannk disk. I keep getting a write protection error. Is there a sensor that see the notch on the disk?
YES, there are 2 sensors along the left side of the drive mech; if memory serves. They are a light and sensor, if the light is bad, the sensor won't see it and says the disk is write protected. The 2nd sensor is disk IN I "think"
3 hours ago, Pixelboy said:
Season's Greetings, ColecoVisionados!
Is that a new title Luc? You are AWESOME as usual. A very HAPPY HOLIDAY today to you! And to all other AtariAge ites! Luc "May the wind under your wings bear you where the sun sails!" (Tolkein)
38 minutes ago, rietveld said:
I have always kept both plugged in but I jusst recently picked up the plastic tray that holds the two together and found that it has a tab that covers the colecovision power cord port.
And there is your answer. Probably made no difference by leaving both plugged in, as the voltages all go the same place; but the idea of the module 3 ADAM add-on was that the stuff out of the box was a complete ADAM if you added your own CV unit to the back of the ADAM module.
1 hour ago, rietveld said:
Seller has a high opinion of that cart, I got 2 of them I think. Maybe I can sell them if I can get that price. Then I can retire from my reitrement
40 minutes ago, SalemFrost7800 said:
looks AWESOME!! a GREAT idea for you CV
- 1
10 hours ago, Pixelboy said:
Postacrads... Sounds like a sarcastic synonym of Pinterest.
Sympathy to you Luc.
34 minutes ago, Mike Harris said:
Methinks someone has a screw loose here. But then, show knows.
This is a Micro Innovations IDE hard drive interface card, goes into the left slot as you face the ADAM. Requires an IDE device wit special software installed so that ADAM can access it.
4 hours ago, Mike Harris said:
I keep seeing this and I KNOW it has to be some ripoff but for my education can someone fill in the blanks.
A ripoff I agree too. This has to be a custom label made to look original and a price out of whack; but hey a person has to try, right?
41 minutes ago, FiveJay said:
I tried searching for this topic, but I couldn’t find it. If it already exists, sorry about that! Please let me know the link, then, as I’ve had trouble finding results that were helpful to me.
I’m new to the Adam, and I took a chance on a cheap auction that has no printer. I’ve seen vague references to other options, but I couldn’t find many details. For new folks and non-technical folks, can we have a list of all the known alternatives for power supplies other than the giant printer that wipes tapes when it’s turned on? I’ve heard it’s possible to make one, but how does a newbie go about doing that? Detailed info on any alternatives would be great!
I can update this top post with all the different suggestions so it’s easy for new folks to find.
Thanks for your help, everyone!
A good question for sure. In your case the best solution would be to use an old ibm desktop power supply that will provide you with +12v -12v +5v and -5v the rub is finding the -5v to use and no getting at AT power supply that needs a specified load for it to kick in. Attached is a jpg of the power needed. For others (you included), the power supply can be removed from the ADAM printer and used natively. BUT, that takes an ADAM printer to steal it from.
- 1
32 minutes ago, doubledown said:
Are people still using Coleco ADAM disk drives or has everyone switched to some sort of SD card type thing-a-ma-jig? Reason I ask is I have 4 for sure (maybe five) Disk Drives I'm going to need to get rid of and just trying to get an idea of use/value? I know all 4 work, I have Coleco power supplies for 2, and I know the more readily available Atari disk drive power supplies are a substitute for the other 2. All 4 have the drive cable, and I know I have the box/packaging/manual for either 1 of these 4, or that box, has a 5th drive inside (can't remember) so 1 is complete in box. I saw it the other night, but can't find it right this second.
What about ADAM mini power supplies (printer replacement)? I have the last mini power supply that I made for myself that I'll need to get rid of too after I completely test all of my ADAM hardware/software and the likes. I remember people use to really want one of these. Just trying to get some sort of idea of value of these items. Thanks in advance for any thoughts/input.
Disk drives are worth $250 and up, especially working; and are very sought after. Power supply in the $50-75 range maybe.
My home built Coleco Adam wifi modem
in ColecoVision / Adam
My question also, does it work.....................I have to believe it does though. CONGRATS!! Only problem case looks a little big.....maybe..... Just got done here making a data drive from Eric P plans, docs and programming. Gave it zero chance with my skills at soldering.............BUT, it works! Miracle!
