raster/c.p.u.
Posts
224 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by raster/c.p.u.
It's really interesting to me.
I made suggestions over about 3 years and Raster doesn't even give 2 cent for attention.
PG wanted a longer envelop for the instruments (which is a logical thing! ) , Raster made it....
3 years ago, I asked for the same... nothing happened ....
I made longer envelopes Emkay wanted over about 3 years ...
... and Emkay is angry.
I have been expecting he will be happy.
Emkay, peace, please...
Nice game.
Cool!
Please, boys from LaResistance group, keep your great work.
The new SIO2USB Version 3 will be presented at the annual ABBUC meeting on 21st of October.
Carsten
Great project!
It would be nice to see video (in DivX) of this SIO2USBdevice presentation.
Please, can I expect it?
There is already a SIO alternative made by a8maestro.com.
It uses a DB25 connector. I have not used it so I do not know if its what you are looking for. Also DB25 switches and parts are probably going to be easier to find than DB15(in the US for sure). I do not know about your parts availability in the Czech republic.
Thanks. I wanted explore it, but I can't find scheme of "EASIO-S SIO adapter cable" wires connection on a8maestro's website.
btw - cannon d-sub15 connectors availability is good in the Czech Republic. It's a "normal" connector as well as d-sub9 and/or d-sub25.
...to make ESIO port (Enchanced SIO)
I'm sorry. I don't care to design any "enhanced" SIO port, I'm looking for substitution of rare Atari SIO connectors (male/female).
No building into Atari will be necessary, but one easy adapter cable will be sufficient for all sio devices.
Ok, here is my suggestion on the picture in attachment.
Advantages of this idea:
- pinouts placement is similar to Atari SIO (no wires crossing)
- d-sub M15 is male as well as Atari SIO connector
- d-sub M15 has proper top-bottom orientation for PCB mounting
Your opinion?
From memory, the popular suggestion seemed to be the DB-15 connector...
Yes, standard 15 pin cannon DB-15 connector was mentioned there I think, but there is a lot of variations: male/female, pinouts assignment (1=1,..,13=13, 14+15unused / or Atari SIO assignment style / or ? ).
btw - For a long time I have decision there (for DB-15) would be best the Atari SIO style pinouts assignment and male gender, but now I discover the problem with connector bottom-top orientation when DB-15 for PCB is used (PCB would have to be bottom up and all the other electronic parts too).
Some time ago somebody started the discussion about alternative connector for Atari SIO port. Because I have a few devices which are connected to Atari SIO and I plan to make others, I like this idea for some new _standard_ for Atari SIO port.
I don't know if discussion about it has ended and if any new standard was choosen already?
(I want to create adapter cable between Atari SIO and new standard connector and I want to be conformable to the others. )
Fandal, you are the KING!
and ... I vote for Desert Toppler.
Great!
(btw - to be continued? )
Great work, Fandal.
It's great to have such a player integrated in your own code. When I have more time I will check if it is possible to use it in ACTION! language, as it allows you to implement anything you like, even in assembler inline code. I know RMT player uses zero page addresses so it could be a problem if ACTION! uses them either.
Yes, RMT uses more zero page addresses, but it isn't a big problem - at the beginning of player routine you can store registers in this area to some temporary memory area and at the end of player routine restore it.
(if no better way will be found )
It's easy.
ldx #<MODUL ;low byte of RMT module to X reg ldy #>MODUL ;hi byte of RMT module to Y reg lda #0 ;starting song line 0-255 to A reg jsr RASTERMUSICTRACKER;Init ; ldy #<vbi ldx #>vbi lda #$07 jsr $e45c ;Start VBI routine ... ;
And VBI routine:
vbi jsr RASTERMUSICTRACKER+3;1 play ; jmp $e462 ;end vbi
That's all.
If you want use RMT also for SFX effects, please, see the /asm_src/sfx/sfx.a65 example.
There is all you need to do.
Fandal, It's great!
I'm able to imagine it was hard work, because of cart's bankswitching is in $8000-$bfff memory area (two areas / 8 x 8KB banks), but extended memory bankswitching is in $4000-$7fff (one area / 4 x 16KB banks).
You are the KING!
I think this capacitor should be of a small value only, for example 100nF (ceramic).
It is not too important.
Very nice game!
I really can't imagin that Raster used wrong values.
And even if the RMT has differend values than someone should verify my values first
In RMT there are the same note-frq-tables as in TMC 1.x.
(8bit pure tones, 8bit bass table 1, 8bit bass table 2, 16bit bass table)
Nice game.
But I'm sorry, I like my dear joystick too much than I would play this kind of games.
What method does it use?
pokey1 equ $d200 pokey2 equ $d210 STEREODETECTION lda pokey1+$09 beq iss2 ;0 => last key L ;no last key L lda pokey2+$09 beq issyes;0 on second POKEY KEY reg => stereo issno lda #0 rts iss2 ldy #7 iss3 lda pokey2,y;POT regs bne issno ;some one is not zero dey bpl iss3 issyes lda #1 rts
You should probably look for Pokeys in d5xx as well.There in d5xx area can be any cartridge hardware. I don't know if any "normal" program (game or demo, not music player sw or system tool) supports stereo at d5xx...
(Also it could evoke whatever when you will read/write to d5xx area, depend on inserted cartridge.)
Emkay: RMT is a good tool for making experiments. Your musician did the right descision, because RMT misses a lot of pokey programming features.
Emkay, you have very special sounds requirements.
If somebody want to create some classical earthly listenable melodic music, RMT is sufficient for it I think.
(I made RMT for it. )
But, I will not pressure anybody to use RMT, of course.
20.2.2006 ... new RMT 1.23 tracker with SFX support.
http://raster.infos.cz/atari/rmt/rmt.htm
Changes in RMT 1.23
- Improvements in MODule import function (with tone-portamento effect).
- Support for SFX effects.
"File - Export As - RMT stripped song file (*.rmt)" there is improved
export dialog with "SFX support" checkbox.
You can use instruments for sound effects in your programs -
- example is in "/asm_src/sfx/" directory.
- Better playmode switching to "Play from currently edited position"
if song is playing with "follow song" already. (Sounds aren't breaked.)
- Some internal improvements.
(rmt_ata.sys,rmt_msx.sys,rmt_sap4.sys and rmt_sap8.sys system data files
are included in RMT tracker executable.)
RMT routine changes
- New option FEAT_SFX for SFX support feature. RMT routine is a bit longer
and slower with SFX support enabled, so, enable it only if you will
use RMT routine also for SFX effects.
(Coders, you have to use new rmtplayr.a65 and rmt_feat.a65)
New song
- Song "commando.rmt" (Commando - sack/cosine, 2003. original by Rob Hubbard)
in "songs/sack_cosine" directory.
Enjoy it!
when will Raster include digi voices in his RMT....
Raster is working on other projects at present.
And btw - Raster already knows, that greater number of RMT features isn't evoke greater number of RMT musicians/users.
(He tested it many times. )
after looking into the code (atari800win + F8 monitor) i discovered that the whole code uses just one VBLBut be aware of code in VBL can consume all the CPU power too.
in my patched routine there is no VBL but i start the music driver at rasterline 0 just to see how many CPU cycles are needed...Yes, when samples are starting to play, all the CPU cycles are used.
Fandal is speaking the truth. I saw him when he was playing Joust. Beware...OK. But you should know that 10,000,000 points in Joust is not a problem for me as well...F.
AY-2-POKEY
Yes. It's interesting.
But, IMHO, Atari SID player by Swiety is more amazing for me.
And I will be glad if this SIDplayer project will be finished, please.
Some old beta versions of SIDplayer works superb - exists some new version?
Many thanks and greetings to Swiety and his great works with sound emulations.
