Posts
171 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by blacka013
I've just received my Turbo Freezer today, thanks Panos.
Now to read through the manual, and start playing with it.
- 1
It's a shame you over in the States, I would have asked you to manufacture two of these for me. They really do look good.
Hi,
I'm still interested in one please.
Regards
Hi ijor,
thanks for the info.
Another question, what software do you require for this?
Regards
I have a question of those who know how this works. If you can back up protected software for preservation with this device, can you also write disks from these protected back up files?
The reason I ask this is because I have several original disks (manuals and packaging) which sadly no longer load due to surface damage/degradation, and I would like to write a disk and then put the floppy mylar into the original disk sleeve.
Gnusto,
have a look here, slightly more affordable, but still expensive for a tape in my opinion.
Regards
Remove all socketed ICs and check there is no tarnishing on the pins and sockets. If there is clean them. If in doubt clean them.
If you have a can of compressed air, blow through the sockets to clear any debris. Reseat all the ICs and test.
Regards
Hi Voxel,
that would be great.
Regards
Hi,
can I get 2 please, or is that too small an order?
Regards
Hi Panos,
I'm interested in one please.
Regards
Very strange. When you examine the bottom set of solder pads, they don't appear to have been tinned ready for soldering, they appear to be bare copper.
Also the solder in the through holes would appear to be from the wave soldering process.
- 1
Hi TGB1718.
if you can't find the problem with the board, I'm just up the road south of Lincoln if you want me to have a look at it for you.
Regards
It certainly can't hurt. I have this version of the Happy board and I found some of the soldering left a lot to be desired.
Does your board have a resistor pack across pins 8 - 16 of the 6502?
You should also check the value of the resistor, as it is not 4k7 ohms.
SIDE2 updated successfully, using FJCs video, great work there.
Now I need to get the Ultimate 1MB installed and then run the update.
Regards
- 1
And a Happy May day to you Bee. Stay safe.
- 1
Hi FJC,
great video especially showing the different ways the updates can be carried out. I will be updating my Side2 shortly.
A question, can you do a video on upgrading an original Candle O Sin board from V1 to V2?
Regards
- 1
Hi Faicuai, thank you for the info, much appreciated. I can get on and update this early board.
Hi,
I have a Xilinx DLC9LP so I can update my early Ultimate 1MB. The problem I have is the leads that came with it, they are all 2.54mm connectors.
Does anyone know where I can source the 2.0 mm connectors from? I've been looking online and can't find any.
Hope you can help.
Regards
Hi Mclaneinc,
condolences to you and all of Bob's family and friends.
RIP Bob.
Hi Nezgar, I'm interested.
Regards
I've built my first board up and is now working in my US Doubler upgraded 1050. It certainly looks more professional than piggybacking the two ram chips and having two pieces of wire soldered across the top.
Great work Nezgar.
- 1
H2 - full version in December on SV
Hi xxl,
looking forward to the finished game.
Regards
