Everett1954
Posts
355 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by Everett1954
Trebor,
Wholeheartedly agree on ElectronicSentimentalities. I had my 5200 modded by Joe and he did a great job. Fast turnaround, stayed in email contact.
He does 2600 and 7800 also.
Hi,
Just got two Genesis to 7800 adapters from grips03 (see earlier post) and they are great!! Using the Genesis game pad instead of the the CX-24 controllers makes playing both 7800 and 2600 games so much more enjoyable. I highly recommend them.
Does the Atarivox work with the Retrobits brand genesis extension cable? I thought I read something about it.
Richard H., With all your great flash cartridge products for Vectrex and more, have you given any thought to doing one for the 7800?
Thanks
- 1
Wow some great information and Screen Shots Crossbow. My Gaming TV is an LED Flat screen and the only vintage input is composite (No S-Video). My larger set in Living room has S-Video (it was purchased about 3 years ago).
There may be a slight edge on the s-video but I' m going with a composite.
Has anyone actually did the Best Mod? I tried to get a copy of the procedure from Bradley but he no it comes with the kit. Just wanted to see what it all entails.
There are also some kits on ebay that can be used for both the 7800 and 2600. They are simple boards with one transistor and a couple resistors, anyone installed any of these mods? According to feedback, hundreds have and give it high praise. I trust you guys on AA.
Also i have not seen any 7800 audio mod that has true stereo output when playing 2600 carts that support it. Am i wrong or is it not possible?
Thanks
Yep, I am noticing the carts have to pushed in straight and and with a good push. Seems to be the deepest slot ever unlike my 5200 or 2600 jr.
Well that's two so far for the Best Electronics Mod................
Kosmic Stardust, Thanks for the great review of the Best Electronics video/audio mod. You were lucky to get one of the complete units as i see he is sold out. Everything I have ever gotten from Best Electronics (Parts, rebuilt 5200 controllers, rebuilt kits have been top notch) and Bradley is very helpful.
I see he still sells the Mod kit and it is very inexpensive compared to others.
I was unaware that there was a built in Asteroid game, is it part of the PAL Bios chip?
I agree, jacks would have been better than a fixed 6 foot cable , but it would work for me.
The Pokey/TIA thing is a bit confusing (some games?) use the sound of both chips? Do some carts have a built in Pokey Chip? I've heard of a mod that mounts a Pokey chip on the main board..what game would use that?
Hi,
I also picked up a 2600 jr....I guess Ill keep it due to the slot problem with the 7800. I ve heard you can dremel the opening, but that can't be pretty no matter how good you are at using the dremel.
i seen the cartridge extender cart but not sure who or if still made, plus that is adding more connections onto the cartridge connector
I have never seen the double ended cartridges..who made them?
Cjameslv, where did I say I wanted an inferior mod? Nothing above says any of that. Is it because I don't have a TV with S-Video? I know a a lot of the mods have S-Video also (like my 5200) but I do not use it.
Just trying to determine what the the best mod is by finding out what other other people are using and have done and and asking some questions.
What mod are you using? would you recommend it?
Hi,
Just got a great 7800 but now looking at have the AV mod done.
Only need the composite video and analog audio out (Do not need S-Video)
There are different mods available.
Best Electronics Mod-consists of removing RF modulator adding components and cable.
The LongHorn Engineer board- a small board that gets tied into TIA, I believe this is what ElectronicSentimentalities use and well as others.
Please chime in with your AV mod experience, did you do it yourself if not who, which mod kit did you use, are you happy with it.
Can someone please explain the TIA switch that can be installed in some kits....Is it useful or needed?
What about the POKEY chip mod that is added to main board..is that useful or needed?
Thanks!
Disregard, Just found a great one locally!
Some more questions,
Can i use the 2600 paddle controllers on the 7800 for those 2600 games that use it?
Do any 7800 games use paddles?
Regarding AV MOD....can the 7800 be modded to output stereo sound for those 2600 games that have it?
Thanks!
Forgot to ask, Is everyone with a CX-55 using the RF output?
Hi,
I have one also, but it does not work with my 2-port 5200 that has the AV mod from Electronic Sentimentalizes. Looking at the 5200 service manual and the CX-55 service manual, the composite video from the CX-55 come out on Pin 24 of the cart connector and audio on pin 31 (or 30 don't remember) so i can try running those along with a ground to separate jacks or install a DPDT switch and using the exiting jacks for when the CX-55 is installed or using regular 5200 carts.
I have not tried it yet so i am hoping the video and audio levels are correct to feed right out to my TV composite input and analog audio input. Both channels of the audio are tied together in the CX-55 so to get stereo out you have to open up CX-55 and cut trace or pull pins and run the 2rd channel to used (?) pins on the CX-55 edge connector.
Has anyone tried this before? I found an Ebay listing from AtariGuy1021 that modified the CX-55 as a standalone with its own output jack but said also works in a 5200. Waiting to hear back. Ill post my results once i get to doing the mod.
I am looking for a nice 7800/ with power supply and a controller or two and any extras you might have.
If it has the AV mod that would be great.
I am more of a player that collector so if it has some scuffs that is OK.
Must be in working condition.
Let me know what you have and the price your asking.
Thanks!
Wow, What a great bunch of responses!! Thanks everyone for taking the time to answer the questions. And so quickly too.
All the answers were what I hoped for so its going to be a 7800 for me!!
Now to find a nice one at a reasonable price. It will be a nice addition to my 5200.
- 3
Hi,
1) Are there any 2600 games that the 7800 will not play? Especially any home brew titles?
2) Does the 7800 work with the 2600 Harmony encore cartridge?
3) Does the 7800 work with Atarivox+ for 2600 carts?
4) Does a flash cart exist for 7800 titles?
5) I understand that most games on 7800 can use 2600 and sega controllers. Also that some 7800 games some use both buttons. Is there a a two button substitute controller that works or a link to modding a controller?
The answers will help me make a decision if i want to spring for a 7800 vs. 2600.
Thanks in advance!
I' m also looking for a joystick cover. Most of the Ebay stuff is missing them.
Hi,
I have AtariXLBox (V3) installed on my on my modded original xbox.
It plays 5200 games just great.
How do I also play 800/800xl games?
I need to know what goes in what directories if that is all that is required.
Do I need the OS rom images and the basic images?
What file format can the 800/XL game roms be in ? .zip, atr , xex ?? all the 5200 roms are in zip.
Any help is greatly appreciated
Thanks!
Wow, that was and unbelievable short time!!! Thanks for making one of my favorite games available on the 5200.
Hi,
Looking for a clean, working Atari Trak Ball at a non eBay price.
I'm a player not a collector so doesn't have to be pristine or have box or manual.
Let me know price. Attach photo if possible.
Regards,
Everett
Wrathchild,
Would love to see Rainbow Walker on the 5200. Care to take on that conversion?
- 1
Very interesting project...I"m all in for a new 5200 or 800 with cartridge and controller support .
Please keep us posted on your development.
Hi,
How do you set up AtariXLBox for both 5200 and 800 roms?
I have the 5200 extra and 800 extra folders that contains the roms etc.
Thanks
I just purchased the 5200 and Vectex cover and they are great!!!!
Excellent fit and well made!
The logos are a real nice touch.
Highly recommended purchase.
- 1
Best Atari 7800 Emulator for Mac OSX?
in Atari 7800
I like OpenEMU very easy to use. Supports lots of systems including the 7800.
