Everett1954
Posts
355 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by Everett1954
Ok, there is a brief mention in nano manual of a Basic program called Catalog.
Where can I find it and how is it used?
1) So it appears the Flashrom 99 does not support any file management (like folders) as I have tried to organize my .bin files but they are not recognized in folders during boot. Is this correct? My understanding is FinalGROM does support folders, is that correct?
2) What exactly does the reset button on the Flashrom99 do? My LED flashes but doesn't appear to do anything else. When do I need to use it.
3) There are .BIN files like Alpiner that were TI GROMS. Are they EA5 conversions and do I need a EA cartridge to play them? They give me a blank or colored screen on my Flashrom99.
4) Now regarding the NanoPEB: What is the easiest way to make sure the additional 32k is working (or seen) by system. I have an extended basic cartridge.
5) Thanks to Ti9962a program I am able to use my Windows 7 laptop and format volumes and add .DSK files to them. However, once the NanoPEB with CF card is back on the TI, is there anyway to see the volume names on the CF? It is easy to forget what Disk is in which volume.
6) Of the disk files I have downloaded, is there anyway to tell if they require Basic or ASM cart or load on there own? Or just trial and error?
Thanks to all those that have helped me so far!
Thanks that was what I had seen, looks like it is for 32K sidecar
Sign me up, ill take one.
Somewhere in my browsing I came upon a jumper modification for the speech synthesizer. I do not remember where I found it but it was a wire that jumped across the ground or 5 volt to be used for what ever gets plugged into the other side of it (NanoPEB or 32K sidecar?)
Does anyone remember what this is for and where to find it again?
Thanks
Yep, tried it on a Sony CRT and a Westinghouse LCD flat screen, only differences is on the the flat screen it does not roll. Still torn and distorted.
So, I have a Sears Video arcade II that originally had no video and audio.
I replaced both the TIA and RIOT and got sound and video back.
However, the video is out of sync and rolling.
The +5VDC is 4.97VDC and there are no shorts or opens on the circuit board.
I have tried a dozen known working cartridges and they all do the same thing. Wiggling the cart does nothing.
Yes I have cleaned the cartridge slot with contact cleaner.
Any ideas? bad cap somewhere or??
Boy, after reading the official documentation and the answers above, I am completely confused on how to run disk images. This is because I am not a PC user and new to TI99/4a
1) What do I need to get the .dsk images onto the NanoPEB CF card? A PC with a CF card reader and the DSK2CF.exe? Please give me an example of what to do.
How do i add this DSK file to one of the volumes or DSK1?
2) Once that is done do I need to CALL FORMAT ( from Basic) and format the volume on the TI? Then CALL MOUNT to mount the .DSK image? Then what to run image?
Also non-related but does the NanoPEB need the external power supply to use the 32K memory expansion?
Hi,
I will be receiving my NanoPEB very shortly and have some questions about it and disk images.
1) what is the proper extensions for TI99/4A disk images and where is a good place to find some?
2) I have a CF reader/writer for my Mac, can I remove the CF card from the NanoPEB and copy them directly to some directory on the card or do i have to set up for serial comms with the board and use a PC?
3) I understand the CF card is a special format. Is this correct? Can it be seen by a PC or Mac? If I ever want to upgrade the CF card, how do I go about formatting it?
4) I understand it supports 3 disk drives, how do i tell the file which drive to use and in multiple game disk/files do i have to do anything special in order for me to use them (Naming?)?
Thanks!
I have both the 233-1 multicart and Rene's C7051 recorder cartridge and I love them both.
The multi cart you don't have to chase down the rom file and just flick some DIP switches to get to game. The disadvantage is you cannot add new game. Price is a lot less than recorder cart also.
Switch is vey durable and should the odd chance that you break it it is common part and easy to replace.
Recorder cart holds 31 binary files and must be hooked up to PC to load files and edit title name. It is menu driven and easy to go to other games.
If this is your first cart, I would go with 233-1 multicart from Dave (PackRat)
Thanks for the info.
Are the INTV flashback controllers compatible with a intellivision console?
Also, can you use original intellivision controllers on a intellivision flashback?
Thank you for that great explanation.
- 1
I just picked up a FlashRom99 and there is a mention of EA5 conversion.
What does it mean and what is it?
Ok,
So what exactly is a GROM cartridge? Does it contain a special graphics chip or just more graphics memory?
How many GROM cartridges are there? Is there a list of them?
Also is there a list of programs and cartridges that require the the 32K memory?
Will Atarisoft files run on the FlashRom99? Other homebrew?
Is there a list of programs/cartridges that use the speech synthesizer? I only know of Parsec and Alpiner
Thanks!
Thanks, that helps quite a bit, i have a bunch of blank key strips but none like above.
So i guess I lucked out and got a non-QI model, date at bottom of startup screen said 1981.
Adamantyr sent me a nice get started package so i could at least try it out.
Everything seems to work just fine, The TI joysticks are not bad but they do not like to stay plugged into the side DB-9. Side mount is not a great place for joystick port.
Have others encountered joysticks coming out of connector?
So now Im waiting for a FlashROM99/FinalGROM 99 and a nanoPEB.
Ok, is there a way to restart a cartridge game without powering on/off system?
I believe Parsec mentions REDO or back key. Which key is REDO and back arrow did not seem to work.
As I am new to the TI-99/4a It was recommended by many to get a FlashROM 99 and I agree. However there is a new version FinalGROM 99.
Should I get the FLashROM 99 or wait for the FinalGROM 99.
When will the FinalGrom 99 be available and will it be price compatible?
I still do not know what cartridges are considered GROM.
Your opinion is appreciated.
Sorry Greg......don't know why I called you Dave
- 1
I am going to check my beige unit to see if it is QI also. My expansion port has copper finger so I am hoping it is not QI.
Dave (arcadeshopper) Now that I know what I am looking at I found great items on your website. I should have inquired to you before assuming out-of-stock was permanent. I like the low profile atari adaptor and I now see the need for the NANOPEB instead of just the 32K memory board.
Are there a lot of cassette and disk software available? what format are they in? All i see are .bin files.
- 1
Wow, all I can say is what a bunch of friendly and helpful group this is!!!!!
Another question: What is the difference between the silver/black and the white one? Mine is white.
I am going to get the composite cable and Flashrom to start with. I see arcardeshopper is sold out of Flashrom and I could not find the eBay listing. Is there another source? Who actually makes the FlashROM99?
Who makes the Atari to TI joystick adaptor?
Not sure if I want the large Expansion box but the mini expansion may be good.
Any info on the transfer cable to use PC as printer? I would need serial on pc and TI correct?
- 1
Thank you both for answering my questions. It also brings up some more questions.
1) Is there audio (stereo?) available on the composite cable? Like other systems.
2) Do the Sidecar attachments daisy-chain?Can I have both speech synthesizer and 32K memory attached?
3) What is GROM cartridge and why is it special?Which carts are GROM?
4) There are two DB-9 connectors one on side and one on back. Both for joysticks?
5) While i realize most use the computer now for games, is there any modern printer solution for the TI-994/a?
Thanks!
Hi,
I just picked up a great working TI-99/4a with the double joysticks, power supply and that huge RF modulator/Switchbox.
There were no game cartridges so right now all I can do is select Basic.
1) Is there a composite cable available or any type of AV mod?
2) Is there a Flash cartridge or Multi-cartridge available?
3) What games/programs work with speech synthesizer? Does it have a built in speaker or does it work with modulator? They seem inexpensive, it is worth getting one?
4) What are the good games and what to avoid?
5) any must have accessories? New items?
6) Lastly, how is TI Homebrew scene, any stellar home-brews available?
Thanks!
- 2
Item has been sold and shipped.
Disk Format questions
in TI-99/4A Computers
Hi,
So I understand that there are different Disk formats Like PC99 (made for emulator) and v9T9. Are there more?
Will these all work with the NanoPEB without any kind of conversion? If I need to convert, which program can I use?
Are there any other restrictions on a .DSK file before copy it to a NanoPEB volume?
Thanks,
