godzillajoe Posted March 27, 2007 Share Posted March 27, 2007 OK so I typed in the source for the first kernal in the programming fo newbies guide and I'm trying to compile it I get a million errors but everything appears to be in the right place Directory of C:\DASM 03/27/2007 09:11 AM <DIR> . 03/27/2007 09:11 AM <DIR> .. 08/12/2005 05:20 PM <DIR> BeOS 02/19/2007 07:33 PM <DIR> bin 02/19/2007 07:33 PM <DIR> DASM 02/19/2007 07:33 PM 163,840 dasm.exe 03/27/2007 09:15 AM 1,316 first.asm 03/27/2007 09:16 AM 0 first.bin 08/12/2005 05:20 PM <DIR> Linux 02/19/2007 07:34 PM 5,747 macro.h 08/12/2005 05:29 PM <DIR> src 02/19/2007 07:34 PM 9,397 VCS.H 5 File(s) 180,300 bytes 7 Dir(s) 86,003,466,240 bytes free C:\DASM>dasm first.asm -f3 -v5 -ofirst.bin DASM V2.20.10, Macro Assembler ©1988-2004 START OF PASS: 1 first.asm (1): error: Unknown Mnemonic '6502'. first.asm (2): error: Unknown Mnemonic '"vcs'. first.asm (3): error: Unknown Mnemonic '"macro'. first.asm (6): error: Unknown Mnemonic '$F000'. first.asm (13): error: Unknown Mnemonic '#2'. first.asm (14): error: Unknown Mnemonic 'VBLANK'. first.asm (16): error: Unknown Mnemonic '#2'. first.asm (17): error: Unknown Mnemonic 'VSYNC'. first.asm (21): error: Unknown Mnemonic 'WSYNC'. first.asm (22): error: Unknown Mnemonic 'WSYNC'. etc. It's all in the same path so what is the problem here. Off to a flying start! Here's what the start of the source looks like which is exactly what it is in the tutorial processor 6502 include "vcs.h" include "macro.h" SEG ORG $F000 Reset StartOfFrame ;Start vblank processing lda #2 sta VBLANK lda #2 sta VSYNC ;3 scanlines of VSYNC signal sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC ;37 scanlines of vertical blank sta WSYNC So what am I not getting here?! Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted March 27, 2007 Author Share Posted March 27, 2007 OK I figured out that it doesn't like instructions starting at beginning of a line. I cut and paste the code from the Programming for Newbies section and it compiles just fine. Is there a certain number of spaces or a tab or something DASM expects? Like I'm not gonna have enough problems without worry about a cranky compiler Anyone recommend a good dev environment aside from crappy notepad? I tried downloading the IDE from the DASM site but it just gives you a page not found error. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 27, 2007 Share Posted March 27, 2007 OK I figured out that it doesn't like instructions starting at beginning of a line. I cut and paste the code from the Programming for Newbies section and it compiles just fine. Is there a certain number of spaces or a tab or something DASM expects? Like I'm not gonna have enough problems without worry about a cranky compiler Anyone recommend a good dev environment aside from crappy notepad? I tried downloading the IDE from the DASM site but it just gives you a page not found error. Indenting 1 space is all that's required, but I personally find it unnecessarily difficult to tell the difference between the indented and non-indented lines when only 1 space is used, so I like to use at least 3 spaces. I'm using Crimson Editor, a free IDE for Windows (http://www.crimsoneditor.com). The IDE that you saw the broken link for on the DASM web site is based on the old DOS-based EDIT.COM editor. It's actually pretty good-- it supports editing multiple files at once, search-and-replace, cut-and-paste or copy-and-paste, etc., as well as compiling from within the IDE using DASM, or running compiled games from within the IDE using z26 or Stella. It's the IDE that I was using when I first started learning to program the Atari 2600 a few years ago, and I still have a copy of it if you're really and truly interested-- but honestly, you'll probably want to use Crimson Editor instead. By the way, there is a thread or pinned topic in one of the AtariAge forums that includes links for programmers, so you might want to check it out to see what other IDEs or programming tools people are using. Michael Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted March 27, 2007 Author Share Posted March 27, 2007 Thanks, I don't really need anything fancy, I just downloaded Crimson Editor and see how that works for me Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 28, 2007 Share Posted March 28, 2007 I just downloaded Crimson Editor Oops, I just tried to check Crimson Editor's site (http://www.crimsoneditor.com) to see if a newer version is available, and the site is gone! A quick search on Google turned up the interesting information that Crimson Editor is being replaced by Emerald Editor (http://www.emeraldeditor.com). The bad news is, Emerald Editor isn't available yet. The good news is, Crimson Editor is still available (http://www.emeraldeditor.com/downloads/). And the better news is, Emerald Editor will (eventually) be available for Windows, Linux, BSD, and Mac-OSX (whereas Crimson Editor is strictly for Windows). Michael Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted March 28, 2007 Author Share Posted March 28, 2007 The site is still there. I downloaded it yesterday and just visited the site again now Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 28, 2007 Share Posted March 28, 2007 The site is still there. I downloaded it yesterday and just visited the site again now Okay, it must have been down temporarily. I tried several times to get to it last night, for nearly five minutes, and it could not be found. Anyway, it's also available at the Emerald Editor site. Michael Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 28, 2007 Share Posted March 28, 2007 BTW the reason you need to indent is because Dasm would misinterpret statements/instructions to be labels (address locations). Quote Link to comment Share on other sites More sharing options...
