Lord-Chaos Posted March 31, 2007 Share Posted March 31, 2007 (edited) Is it possible to use a parallel ZIP drive with an ST or will they work with PC's parallel ports only? LC Edited March 31, 2007 by Lord-Chaos Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted March 31, 2007 Share Posted March 31, 2007 Is it possible to use a parallel ZIP drive with an ST or will they work with PC's parallel ports only? LC Not possible, the ST can't drive the parallel ZIPdrives. But it can use the SCSI versions (or JAZ) if you have a SCSI interface. You can even format them to PC mode and easily swap data between the two. Quote Link to comment Share on other sites More sharing options...
