Gury Posted June 3, 2014 Author Share Posted June 3, 2014 Version R1 Quote Link to comment Share on other sites More sharing options...
greblus Posted June 3, 2014 Share Posted June 3, 2014 With pleasure! Quote Link to comment Share on other sites More sharing options...
greblus Posted June 3, 2014 Share Posted June 3, 2014 Second test: 1. I did a few tests with my Action! experiments and noticed that embedded ifs are not working, eg: if i=0 then [some code here] if j=1 then [some other code here] fi fi asm file is generated, but won't compile (labels declared twice) Effectus does not report any errors and the only sign that something was wrong is the lack of xex file 2. var==+1 returns lots of Access violation errors. 3. When i try to compile some asm files generated by effectus when there is no xex i get for example: mwa #0PC^ j uscrl.asm (31) ERROR: Extra characters on line then if I correct mwa line, lots of undefined labels are reported, as if something went wrong for the effectus itself. I don't know if it's a good place to post such lousy non-working examples, let me know Quote Link to comment Share on other sites More sharing options...
Gury Posted June 3, 2014 Author Share Posted June 3, 2014 Hej greblus, it's ok, post here anything you like, no barriers It is better to know the issues than to ignore them. I will update Effectus in version branches, depending on fixes made. You found one of no-yet-fixed issues in Effectus: nested ifs. I will deal will them soon. "uscrl.asm (31) ERROR: Extra characters on line" Extra line is probably the issue involving different ending characters in used OS (Linux has different line ending then WIN32), This also has to be checked through the program. Quote Link to comment Share on other sites More sharing options...
Gury Posted June 4, 2014 Author Share Posted June 4, 2014 You can check forum on Effectus website, which is still in development phase with very poor security. You are welcome to post there anything you like about Effectus or anything else. Bugs, ideas, testing, help or anything else is very welcome. http://gury.atari8.info/effectus/forum/ Quote Link to comment Share on other sites More sharing options...
greblus Posted June 4, 2014 Share Posted June 4, 2014 (edited) Hi. First I'm trying to get it compiled on Windows. In fact, setting encoding to dos (in vim) instead of utf8 eliminates the "extra characters in line" problems. But I've the following problems: 1. Pointers. Action code: card pointer pc ... pc^=pc^-2 Results in mwa #pc^-2 pc_ptr uscrl.asm (32) ERROR: Undeclared label PC (BANK=0) 2. while loop. I'm setting vblkd after clock's tick this way (dunno if that's necessary, but some books say it should be done with this in mind): i=clock while clock=i do od nmi=0 vvblkd=scroll nmi=$40 and the errors I get are: #while .byte clock=i uscrl.asm (76) ERROR: Undeclared label I (BANK=0) uscrl.asm (76) ERROR: Undeclared label I (BANK=0) mads code generated here is: #while .byte clock=i inc array_index_ndl #end Edited June 4, 2014 by greblus Quote Link to comment Share on other sites More sharing options...
Gury Posted June 4, 2014 Author Share Posted June 4, 2014 (edited) Hi greblus, super find. So obviously extra characters in line will be fixed in next versions. Pointers are not fully supported yet unfortunatelly, there are still issues. The last error comes by the fact that Effectus is still limited in the way it processes statements and commands, which must be written each in separate lines. There are some good exceptions (noted in News section) fortunatelly. In your case, it must be written: Not ok: while clock=i do od Ok: while clock=i do od I am sorry for such incompatibilities and uncomfort. These issues will be fixed in next branches, but of course it is good to test them for the note. I am interested if you tried to compile (in Linux) any of the examples in examples directory. Here is the link (you must change \ to / of course): http://gury.atari8.info/effectus/examples/code/dirlist.txt Keep in touch and thanks for stress tests Edited June 4, 2014 by Gury Quote Link to comment Share on other sites More sharing options...
greblus Posted June 4, 2014 Share Posted June 4, 2014 (edited) It's fairly easy to test "automatically" on linux. First, let's see how many files we have for testing: greblus@localhost:~/Effectus$ ls *.eff | wc -l 53 Then let's compile and count xex files: greblus@localhost:~/Effectus$ for file in `ls *.eff`; do echo $file; ./effectusR1 $file; done greblus@localhost:~/Effectus$ ls *.xex | wc -l 51 so, only two files are not compiled, let's see which ones: greblus@localhost:~/Effectus$ for file in `ls *.eff`; do ls `basename $file eff`xex; done | grep "No such file" ls: cannot access lib_test.xex: No such file or directory ls: cannot access multi.xex: No such file or directory I tried to run the xex files and they all seem to work, although I haven't checked if what's on screen is absolutely correct. Edited June 4, 2014 by greblus Quote Link to comment Share on other sites More sharing options...
Gury Posted June 4, 2014 Author Share Posted June 4, 2014 Bloody hell, thanks for the test and useful scripts, greblus! This scripts will come handy in future versions including even more examples. Quick errata correction... IF nesting DOES work, I just messed it up with inclusion of ELSEIF implementation. Now it is corrected and it will be distributed in the next version. You earned a beer. Actually beers Quote Link to comment Share on other sites More sharing options...
greblus Posted June 4, 2014 Share Posted June 4, 2014 Gury, if somebody here deserves big supply of beers, it's YOU! I really like Action! and it'd be wonderful to have modern, complete cross-compiler, free of all unpredictable behaviours of the original cart version. Quote Link to comment Share on other sites More sharing options...
greblus Posted June 4, 2014 Share Posted June 4, 2014 (edited) Ok, I give up on one of my experiments. 1. Got rid of nested ifs. 2. Got rid of pointers. 3. One declaration/statement per line. but still I get: #if uscrl.asm (29) ERROR: Improper syntax Here's the code: int j=[0] int k=[0] byte hsc=54276 int tmpl int tmph byte array ndl = [112 112 112 66 64 156 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 86 216 159 65 32 156] proc chndl() if ndl(28)<2 then ndl(28)=255 ndl(29)=ndl(29)-1 else ndl(28)=ndl(28)-2 fi return proc scrol() hsc=j j=j+1 if j=17 then chndl() j=0 k=k+1 fi if k=14 then ndl(28)=tmpl ndl(29)=tmph k=0 fi [$4C$E462] return proc main() int i card sav=88 byte clock=$14 byte nmi=$D40E card dlist=560 card vvblkd=$0224 byte col0=708 byte col1=709 graphics(0) dlist=ndl sav=40000 col0=14 col1=14 for i=1 to 23 do printf("line: %i%E", i) od print("Action!") tmpl=ndl(28) tmph=ndl(29) i=clock while clock=i do od nmi=0 vvblkd=scrol nmi=$40 do od return It's from my first attempts at Action! original idea is here: http://blog.greblus.net/2013/05/17/action-finescroll-w-ramach-vbi/ and this is the next one I'd like to try with effectus: http://blog.greblus.net/2013/06/02/finescroll-w-vbi-tecza-w-dli/ Edited June 4, 2014 by greblus Quote Link to comment Share on other sites More sharing options...
Gury Posted June 5, 2014 Author Share Posted June 5, 2014 Ok, nice examples to show Action! capabilities. IF statement above obviously does not manage array variable correctly, I will deal with it more closely. Nested IFs should work in next version. I will play with this listing as good example of what is still missing from Effectus. Quote Link to comment Share on other sites More sharing options...
greblus Posted June 5, 2014 Share Posted June 5, 2014 (edited) Gury. Honestly, initially I thought that a lot more is missing This code compiles and xex is created, but crashes the emulator: int j=[0] int k=[0] byte hsc=54276 byte tmpl byte tmph byte tmp byte array ndl = [112 112 112 66 64 156 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 86 216 159 65 32 156] proc chndl() tmp = ndl(28) if tmp < 2 then ndl(28)=255 tmp=ndl(29)-1 ndl(29)=tmp else tmp=ndl(28)-2 ndl(28)=tmp fi return proc scrol() hsc=j j=j+1 if j=17 then chndl() j=0 k=k+1 fi if k=14 then ndl(28)=tmpl ndl(29)=tmph k=0 fi [$4C$E462] return proc main() int i card sav=88 byte clock=$14 byte nmi=$D40E card dlist=560 card vvblkd=$0224 byte col0=708 byte col1=709 graphics(0) dlist=ndl sav=40000 col0=14 col1=14 for i=1 to 23 do printf("line: %i%E", i) od print("Action!") tmpl=ndl(28) tmph=ndl(29) i=clock while clock=i do od nmi=0 vvblkd=scrol nmi=$40 do od return Edited June 5, 2014 by greblus Quote Link to comment Share on other sites More sharing options...
Gury Posted June 5, 2014 Author Share Posted June 5, 2014 Yes, the solution for array variables would be substitution with scalar variables, but in this example something is still bugging it I will examine it, maybe solution is easier than we think. Quote Link to comment Share on other sites More sharing options...
greblus Posted June 5, 2014 Share Posted June 5, 2014 I only have atari800 right now (and I never know how to use the monitor in it), but it says: 294 96 A=01 X=FE Y=FF S=F5 P=NV*----- PC=8001: 62 CIM isn't it crashing somwhere after jsr $8000? ($4C $E462 = jmp xitvbv) Quote Link to comment Share on other sites More sharing options...
Gury Posted June 5, 2014 Author Share Posted June 5, 2014 Hmm, the problem is the call to [$4C$E462] machine language routine in scroll() procedure. It is supposed to work, but when it jumps to org $8000 (which is automatically defined in Effectus), error raises. I don't know, maybe RTS mnemonic is missing or call to xitvbv? Quote Link to comment Share on other sites More sharing options...
Gury Posted June 5, 2014 Author Share Posted June 5, 2014 Reposted previous message. because I didn't have permissions to edit: The problem is the call to [$4C$E462] machine language routine in scrol() procedure. It is supposed to work, but when it jumps to org $8000 (which is automatically defined in Effectus), error raises. I don't know, maybe RTS mnemonic is missing or call to xitvbv raises the error! I think RTS is not needed because it is called by return statement: [$4C$E462] return In meantime, I fixed some other issues and some more features will show up in new version. I also updated equates.asm in lib directory by including some more labels compiled by JAC! Quote Link to comment Share on other sites More sharing options...
Gury Posted June 12, 2014 Author Share Posted June 12, 2014 Hi, Here is new version of Effectus (0.1), with some new features and bug fixes. You are welcome to try it and post any issues and other notes. Greblus, can you be so kind to compile it on Linux and run your tests, so I can put new Linux version on Download link? If you do so, you can amend effectus.pas and put your name and write something like 'Compiled for Linux by greblus' or something to fit you. Also, give me a note on which version of Free Pascal you will compile the program. I think I found the issue compiling your scroll example with Effectus. Currently, procedure calls can't be assigned to the address, but this will be fixed in one of the next versions. I also fixed the usage of Fill command, which works in general, but few problems remain, like borders and gliches on the screen when using Print routine. Effectus version: Action! version: Also, major update in equates.asm library code was done, new system variable names and memory addresses (hex and dec) were added (from the list compiled by JAC!). Other issue involving equates was fixed, in particular, the conflict with system label names when used as variables in Effectus source code. This is now fixed, with major recoding of the program. Greetings! Quote Link to comment Share on other sites More sharing options...
greblus Posted June 12, 2014 Share Posted June 12, 2014 Gury. Great! I'll compile it and test it this evening Quote Link to comment Share on other sites More sharing options...
Gury Posted June 12, 2014 Author Share Posted June 12, 2014 Great! Please, also try your tests with nested IFs, which you did some posts back. If there is someone prepared to compile Effectus for MacOS, that would be great, because that would help us to see how much it is done (or not) for that platform. Quote Link to comment Share on other sites More sharing options...
greblus Posted June 12, 2014 Share Posted June 12, 2014 (edited) Here is the tgz with Effectus compiled using fpc 2.6.4 on Arch Linux. It contains modified config.ini and mads-1.9.8 binary. I attach also the log with errors encountered during compilation of the examples. Nested ifs do work fine (just a simple test). Later today I'll test some more. effectus-0.1.tar.gz errors.txt Edited June 12, 2014 by greblus Quote Link to comment Share on other sites More sharing options...
greblus Posted June 12, 2014 Share Posted June 12, 2014 Gury, I can't compile my example from #88, I get these errors: greblus@localhost:~/Desktop/Effectus$ ./effectus uscrl1.eff mwa SCROL_eff_ vvblkd_eff_ uscrl1.asm (87) ERROR: Undeclared label SCROL_EFF_ (BANK=0) uscrl1.asm (87) ERROR: Undeclared label SCROL_EFF_ (BANK=0) Quote Link to comment Share on other sites More sharing options...
Gury Posted June 12, 2014 Author Share Posted June 12, 2014 Hej greblus, don't worry about your example, because I tracked down the issue. It will be fixed as soon as possible and you will be informed about it to test again. Many, many thanks for compilation of Linux version, it is now included in download repository here. Also, News section is updated thanks to you. The errors you tracked down are examined too. include_test.eff example does not work well, because for some reason in Linux environment paths are treated differently, so I have to check the code, which is currently optimized for WIn32 environment. multi.eff example causes troubles because there is a limitation in current version, in which you can't mix different logical operators, they have to be the same. Funny thing, you say, but it will be fixed, of course Quote Link to comment Share on other sites More sharing options...
greblus Posted June 12, 2014 Share Posted June 12, 2014 Gury, thank you for the development of Effectus. If only I could help some more. Quote Link to comment Share on other sites More sharing options...
Gury Posted June 13, 2014 Author Share Posted June 13, 2014 Hej, that's ok, you did more than enough, just bring new examples and tests. I like Action! also and I wanted to do this. If there is time, I always enjoy developing some more. Quote Link to comment Share on other sites More sharing options...
