Thomas Jentzsch Posted February 21, 2009 Share Posted February 21, 2009 I have no idea what the other routine is for though. It converts a hex-code into an ASCII code. Quote Link to comment Share on other sites More sharing options...
bogax Posted February 22, 2009 Share Posted February 22, 2009 How'd you come up with that? Someone posted a question about bit twiddling in one of the 6502.org forums that was part of the answer some interesting stuff there (one of the interesting things is a pointer in one of the forums to this forum ) That ranks right up there with the following routine someone came up with (on another platform, but adaptable to 6502): ; Magical mystery routine (hint: use with acc = 0-15) sed adc #$90 adc #$40 cld Anyone ever seen anything like that one before? I believe I saw that posted to comp.sys.cbm some years ago, don't remember where it was said to have come from. Don't you need a clc in there? Quote Link to comment Share on other sites More sharing options...
bogax Posted February 22, 2009 Share Posted February 22, 2009 (edited) Wonder if you could impliment a similar process for other numbers too. (still preserving the x and y) Sure it's basically just reciprocal multiplication divide by 7 1/7 = .001001001001001... sta temp 1. lsr .1 lsr .01 lsr .001 adc temp 1.001 leave the carry alone to round ror .1001 lsr .01001 lsr .001001 adc temp 1.001001 ror .1001001 lsr .01001001 lsr .001001001 what I find intriguing is that, since they're all repeating decimals, you can (sort of) accumulate accuracy sta temp 1. lsr .1 lsr .01 lsr .001 adc temp 1.001 sta temp 1.001 ror .1001 lsr .01001 lsr .001001 lsr .0001001 < I've skipped an addition here lsr .00001001 lsr .000001001 adc temp 1.001001001 ror .1001001001 lsr .01001001001 lsr .001001001001 obviously doesn't help any in the case of dividing an 8 bit number by 7 but I've gotten to the point where it's less work to rol sta temp xxxxxxxx 1. lsr xxxxxxxx .1 lsr 0xxxxxxx .01 lsr 00xxxxxx .001 adc temp xxxxxxxx 1.001 sta temp xxxxxxxx 1.001 rol jjjjjjjx .00000001001 I've (in effect) jumped a byte to the right rol jjjjjjxx .0000001001 the j's are junk that would have been rol jjjjjxxx .000001001 shifted out now I have to mask them off and #$F8 00000xxx .000001001 still slightly faster adc temp xxxxxxxx 1.001001001 ror xxxxxxxx .1001001001 lsr 0xxxxxxx .01001001001 lsr 00xxxxxx .001001001001 OK, that doesn't help much either but it might if you were dividing more than 8 bits by a constant and in the cases where the repeating part is some integral fraction of a byte as is the case for eg division by 10 or 15 I could acummulate a full bytes worth and not have do any actual shifting at all But I don't know if it's likely to be useful for any case of an 8 bit dividend. (or usefull at all for that matter, but I'm thinking 16 bit binary to decimal) For example Omegamatrix managed to do a pretty good job on division by 15 with just some rounding. Edit:changed some lsr's to the rol's they should have been (second and third rol) Edited February 22, 2009 by bogax Quote Link to comment Share on other sites More sharing options...
gauntman Posted February 22, 2009 Share Posted February 22, 2009 How'd you come up with that? Someone posted a question about bit twiddling in one of the 6502.org forums that was part of the answer some interesting stuff there (one of the interesting things is a pointer in one of the forums to this forum ) That ranks right up there with the following routine someone came up with (on another platform, but adaptable to 6502): ; Magical mystery routine (hint: use with acc = 0-15) sed adc #$90 adc #$40 cld Anyone ever seen anything like that one before? I believe I saw that posted to comp.sys.cbm some years ago, don't remember where it was said to have come from. Don't you need a clc in there? I think I have seen this as: sed cmp #$a adc #$30 cld Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 22, 2009 Share Posted February 22, 2009 Bogax, were you just showning the reciprocal extension, or dividing by 7? I tried the first routine and it failed from numbers 228 up. At 228 they started back at zero. The second routine broke very early. It gave me a one when dividing 6 by seven. I didn't check anymore after that. Quote Link to comment Share on other sites More sharing options...
bogax Posted February 22, 2009 Share Posted February 22, 2009 Bogax, were you just showning the reciprocal extension, or dividing by 7? I tried the first routine and it failed from numbers 228 up. At 228 they started back at zero. The second routine broke very early. It gave me a one when dividing 6 by seven. I didn't check anymore after that. My bad I should have said the code was untested and just for illustration I was trying to point out that most of these routines (obviously not the LUTs) are multiplication by reciprocals and that the reciprocals are repeating decimals (binimals? ) and the fact that they're repeating could probably be used to advantage. The first routine is meant to be essentially the divide by 7 routine previously posted by djmips except that I have it with the dividend starting out in A instead of in memory (which I also failed to mention). I figured it was so simple and straight forward it would be good for illustration Sounds like you used an lsr where you should have an ror? The second and third routines will fail for values over 227. I believe that could be fixed by moving the last sta and adc down one shift so you get the carry into A before you save it to temp like so: sta temp lsr lsr lsr adc temp ror sta temp lsr lsr lsr lsr lsr lsr adc temp ror lsr hmm dividing 6 by 7 should be like this sta temp 00000110. 00000110 lsr 00000011.0 lsr 00000001.1 lsr 00000000.1 adc temp 00000111.0 sta temp 00000111.0 00000111 ror 00000011.1 lsr 00000001.1 lsr 00000000.1 lsr 00000000.0 lsr 00000000.0 lsr 00000000.0 adc temp 00000111.0 ror 00000011.1 lsr 00000001.1 lsr 00000000.1 For the third routine I'll have to look at it again, I might well have screwed something up Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 22, 2009 Share Posted February 22, 2009 (edited) Sorry, I didn't post that very clear. I knew the first routine was the /7 djmips posted. It works fine. I meant your first routine as the middle one, and the last routine as your second. The value starting out in the accumulator was fine. I've been testing the routines with a simple loop that takes increments a temp register every time it goes through, and looking at the values through the Stella emulator. Edit: Also is there a way to go faster (and maybe save more bytes) then the previous /5 I did? If we can find a faster /5 then we can get a faster /10 too. Edited February 22, 2009 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
bogax Posted February 22, 2009 Share Posted February 22, 2009 I edited that third routine. It will still fail at 228 and there's no good way to fix that with it rotating left instead of right (that I can think of at least) Oh well, it was only ment to be an illustration, I guess that's as good an illustration as any Edit: Also is there a way to go faster (and maybe save more bytes) then the previous /5 I did? If we can find a faster /5 then we can get a faster /10 too. I think with division into eight bits the simple straight forward way is going to be the best we can do here's a division by 10 similar to your division by 15 UNTESTED! sta temp lsr sec adc temp sta temp lsr lsr lsr lsr adc temp lsr lsr lsr lsr I expect, if you care to test it, you'll get around to that before I do hmm wonder it something similar can be done for division by 7 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 22, 2009 Share Posted February 22, 2009 I tried it, but it didn't work. It's the same issue that Batari resolved; how to account for numbers overflowing when times the original number by 1.5. Your routine will work if you replace the 2 LSR's with ROR's here: sta temp lsr sec adc temp sta temp lsr < ror lsr lsr lsr adc temp lsr < ror lsr lsr lsr but the second ror has to account for the original overflow. Post 44 is very similar to the approach here, where I kept the original value in the X register, and then compared it before the rotate. Getting around the time of not doing the compare, TAX, or SEC was always the problem. I managed to go a little faster after that, but could never find a way to do without SEC and save the 2 cycles there. Quote Link to comment Share on other sites More sharing options...
bogax Posted February 23, 2009 Share Posted February 23, 2009 Your routine will work if you replace the 2 LSR's with ROR's here: sta temp lsr sec adc temp sta temp lsr < ror lsr lsr lsr adc temp lsr < ror lsr lsr lsr ACK! Yes, right, those were supposed to be ror's Quote Link to comment Share on other sites More sharing options...
bogax Posted February 23, 2009 Share Posted February 23, 2009 OK, back to divide by seven Again, untested (yes, I should set up to do that) sta temp lsr lsr lsr adc temp ror lsr cmp #$3F adc #$00 lsr Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 23, 2009 Share Posted February 23, 2009 I tried it, but it didn't work. The numbers started failing in the middle of range. The beginning and end were good. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 (edited) A recent post by Bogax made me think about this old topic once again. I wrote a small Atari 200 program to help me find solutions to these division problems some time ago: DivideTest.zip I came up with a framework to division by 5 sometime ago, earlier in this thread. Thinking about it today I realized I was doing (2^n)+1 division, and I wondered if the algorithm could be extended to other (2^n)+1 divisions (such as the December '84 Apple Assembly Line routine could be extended to other (2^n)-1 divisions). So I tried it with divide by nine, and the very first try worked! At 29 bytes and 48 cycles it is a beast of a routine, but I'm sure could be optimized with some permutations such as I've done with divide by 5, 10, and 15. I'm not sure if divide by nine has a good use though. I've put the routine in the assembly file above, and I'll include it just below as well. sta temp lsr lsr lsr eor #$FF sec adc temp lsr lsr lsr eor #$FF sec adc temp lsr lsr lsr eor #$FF sec adc temp lsr lsr lsr Edited January 26, 2013 by Omegamatrix 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 I found a more optimized solution in about 10 minutes by letting the program run. I truncated one of these sections: eor #$FF sec adc temp lsr lsr lsr Then I inserted an "ADC testVariable" with MODE = 0. I let the program run and Whamo! It found a solution with adc #252. So we are now down 23 bytes and 37 cycles. sta temp lsr lsr lsr adc #252 eor #$FF sec adc temp lsr lsr lsr eor #$FF sec adc temp lsr lsr lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 Removed the SEC, it passed. 22 bytes, 35 cycles: sta temp lsr lsr lsr adc #252 eor #$FF adc temp lsr lsr lsr eor #$FF sec adc temp lsr lsr lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 (edited) Faster, better... 21 bytes, 33 cycles. ;divide by 9 sta temp lsr lsr lsr adc #252 eor #$FF adc temp lsr lsr lsr sbc temp eor #$FF lsr lsr lsr Edited January 26, 2013 by Omegamatrix 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 26, 2013 Share Posted January 26, 2013 I'm making a batariBasic game that leans pretty heavily on pseudo random numbers and bit shiting. I know this is beyond the scope of your topic here, but, how would one incorporate your divde by 9 code inline (in bB)? Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 (edited) I'm making a batariBasic game that leans pretty heavily on pseudo random numbers and bit shiting. I know this is beyond the scope of your topic here, but, how would one incorporate your divde by 9 code inline (in bB)? I know you know how to insert assembly into your BB file, so all that is left to do load the the value before the routine. The "temp" register above is just that... some temporary register you need for a few lines of code. So first determine which zero page register is holding your value, and insert the routine. I'll give an example with register $A9 holding your value, and $BE a register I can trash (my temp register): asm lda $A9 sta $BE lsr lsr lsr sbc #1 eor #$FF adc $BE lsr lsr lsr sbc $BE eor #$FF lsr lsr lsr ;at this point the accumulator holds the result ;of the divide by nine, store the result somewhere, ;or add more assembly voodoo... end I've also changed the adc #252 to sbc #1 above. It works, and seems a little cleaner. Edited January 26, 2013 by Omegamatrix 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 Same cycles, 1 less byte: ;divide by 9 ;20 bytes, 33 cycles sta temp lsr lsr lsr sec eor #$FF adc temp lsr lsr lsr sbc temp eor #$FF lsr lsr lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 More... 19 bytes, 31 cycles sta temp lsr lsr lsr sbc temp eor #$FF lsr lsr lsr sbc temp eor #$FF lsr lsr lsr And as this is my 5000th post... I just wanted to say thank you, AtariAge! It's been quite a ride over the last eight years. Has it really been that long? 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 To switch gears a little bit, and step back from the divide by nine routines, I revisited the the divide by 10 routine. I came up with this. Although it is worse then my other routine by 3 bytes and 1 cycle, it seems to have a simplicity which I love. ;divide by 10 ;23 bytes, 36 cycles lsr sta temp lsr lsr sbc temp eor #$FF lsr lsr sbc temp eor #$FF lsr lsr sbc temp eor #$FF lsr lsr And by contrast, the more optimized divide by 10: ;divide by 10 ;20 bytes, 35 cycles lsr sta temp lsr sec adc temp sta temp lsr lsr lsr adc temp adc temp ror lsr lsr lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 Woke up this morning and tried divide by 3. I found a quicker solution right away. Old December '84 Apple Assembly Line solution: ;Divide by 3 ;20 bytes, 35 cycles sta temp lsr lsr adc temp ror lsr adc temp ror lsr adc temp ror lsr adc temp ror lsr New routine: ;Divide by 3 ;18 bytes, 30 cycles sta temp lsr adc #21 lsr adc temp ror lsr adc temp ror lsr adc temp ror lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 Divide by 12, which of course equals (1/4) * (1/3). ;Divide by 12 ;20 bytes, 34 cycles lsr lsr sta temp lsr adc #21 lsr adc temp ror lsr adc temp ror lsr adc temp ror lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 By the same logic, divide by 14, which equals (1/2) * (1/7). The divide by seven routine is straight out of the December '84 Apple Assembly Line Magazine. ;Divide by 14 ;16 bytes, 29 cycles lsr sta temp lsr lsr lsr adc temp ror lsr lsr adc temp ror lsr lsr 1 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted January 26, 2013 Share Posted January 26, 2013 (edited) Found a page with reciprocal multiplication routines for small approximation numbers. http://homepage.cs.u...bcd/divide.html I started with the divide by 13 algorithm they had, and at a certain point truncated it and added the divide by 12 routine. It works, but at 36 bytes and 61 cycles it is bulky and slow. I'm not too sure divide by 13 has a real use anyhow. ;divide by 13 ;36 bytes, 61 cycles sta temp lsr adc temp ror lsr adc temp ror adc temp ror adc temp ror ;divide by 12 lsr lsr sta temp lsr adc #21 lsr adc temp ror lsr adc temp ror lsr adc temp ror lsr Edited January 26, 2013 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
