Wrathchild Posted October 31, 2007 Share Posted October 31, 2007 After discussions in the normal A8 forum, I've put together a little example of using C code and arranging it across banks in a cartridge (in this example XEGS) such that functions can be called via a Jump Table that handles the bank switching. We can use this thread to expand upon (or completely replace) ideas about how to go about this. One thing I'm not too happy about is the dependencies that I should really setup in the makefile as a change (such as a newly exported function) would mean that the jmptable files change. Also you have to declare the bank that the function resides in - not too much effort required there - but maybe a dynamic way of doing this can be done. It requires modifications to the atari.o (effectively crt0.s) in order to prep some of the data (r/w and read-only segements), copying them to RAM, but I did leave in an example where the RODATA section of one codebank was left in that bank (and so available to the bank when it was switched in). The atari.lib however can be used 'as-is' and for now I've left that in the always loaded bank at $A000->$BFFF. I hope this can help someone get going on ideas they have. Post here or PM me if you have something specific you are trying but can't quite pull off under CC65. Regards, Mark XegsBanking.zip 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 31, 2007 Author Share Posted October 31, 2007 Here's a better main(), I'd forgotten to include the return value of Bank0Test: void main(void) { char c; clrscr(); c = Bank0Test(g_nGlobalInt); printf("Bank0Test returned '%c'\n", c); CodeSegMsg(); Bank1Test(&g_nGlobalInt); printf("Tests done\n"); } Quote Link to comment Share on other sites More sharing options...
Tickled_Pink Posted November 7, 2007 Share Posted November 7, 2007 Does CC65 store compiled code in contiguous memory addresses without interruption? Or does it create compound files? Quote Link to comment Share on other sites More sharing options...
kenfused Posted November 8, 2007 Share Posted November 8, 2007 Does CC65 store compiled code in contiguous memory addresses without interruption? Or does it create compound files? In the linker config file you can pretty much configure how you want it (how you want everything laid out in the output file). In fact, if you need headers like on 8-bit binary load files, it is up to you to define those too. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted November 8, 2007 Author Share Posted November 8, 2007 To add to that, the compiled (from C) object file (.o) doesn't hold the destination address, that is assigned during linking. This is true too of the objects created from assembler sources (.s), hence you can inter-mix them in your final program. The .c to .o compilation actually goes via a temporary .s file which is assembled. Quote Link to comment Share on other sites More sharing options...
