Shawn Jefferson Posted November 3, 2009 Share Posted November 3, 2009 (edited) I still do not understand what happens after the blocks have been decrypted and placed in memory. There is probably some jsr calls from the rom. Or perhaps a jmp to some address in ram. If Harrys code call stuff in rom then it may have something more in it than just the math. There is a simple jmp $200 in the ROM after decryption. In the loader, from what I saw (and I think the loader I grabbed out of the enctest.c program was truncated-ah, yes it was since it contained the blank section between $296 and $2FF), there are two calls to the ROM, a call to $FE00 to setup the cart block to read, and another to $FE4A which I don't know what this does... it appears to be within the main lynx ROM code and may be within the decryption code itself (i don't understand this code and I didn't try to work it out.) Edited November 3, 2009 by Shawn Jefferson Quote Link to comment Share on other sites More sharing options...
Wookie Posted November 3, 2009 Share Posted November 3, 2009 (edited) ...(and I think the loader I grabbed out of the enctest.c program was truncated-ah, yes it was since it contained the blank section between $296 and $2FF)... I explained earlier in the thread that the HarrysPlaintextLoader definition in the enctest.c file is trucated. I discovered that when I figured out the block count framing bytes in the decryption process. I also then posted the full plaintext decryption of Harry's Loader. Make sure you are using that one. --Wookie Edited November 3, 2009 by Wookie Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted December 1, 2009 Share Posted December 1, 2009 Not sure what this all means... but I am wondering if this will help me figure out what my headerless roms are from the protos I have. Karri... were you able to get anywhere with that? Quote Link to comment Share on other sites More sharing options...
Wookie Posted March 16, 2010 Share Posted March 16, 2010 I just received my LynxMan flash cart. My first priority is to finally test my encryption tool and to integrate it into the cc65 toolchain. --Wookie Quote Link to comment Share on other sites More sharing options...
