dwhyte #1 Posted July 27, 2008 To get the RMT player source working on NTSC systems, is it just a matter of using different sync counter spacings? If that's the case, is there anywhere out there where it's listed? I couldn't find anything relating to this question on AA here, though I may not have refined my search enough... Quote Share this post Link to post Share on other sites
Heaven/TQA #2 Posted July 27, 2008 maybe Sal can answer the question how they managed the 50/60 issue in Tempest regarding the msx? Quote Share this post Link to post Share on other sites
raster/c.p.u. #3 Posted July 28, 2008 To get the RMT player source working on NTSC systems, is it just a matter of using different sync counter spacings? If that's the case, is there anywhere out there where it's listed? I couldn't find anything relating to this question on AA here, though I may not have refined my search enough... Yes, you can see this constants in example source code asm_src/music.a65 at line 69 there is: tabpp dta 156,78,52,39 ;line counter spacing table for instrument speed from 1 to 4 It goes from 156/1=156,156/2=78,156/3=52,156/4=39 and part acpapx1 lda #$ff ;parameter overwrite (sync line counter value) clc acpapx2 adc #$ff ;parameter overwrite (sync line counter spacing) cmp #156 bcc lop4 sbc #156 #156 goes from 156 screen lines in total. So, for NTSC there should be another values. But beware of CPU performance (With instrument speed 4 there can be problem) and VBI interrupt (which can engage CPU and VCOUNT comparation will not work): waipap cmp VCOUNT ;vertical line counter synchro bne waipap Greetings, raster/c.p.u. Quote Share this post Link to post Share on other sites
