marcokitt2000 Posted November 10, 2010 Share Posted November 10, 2010 Hello Peter Dell, Check this site out http://www.richard-jackman.de/Atari_XL/index.htm Richard finaly made a Atari 6502 cross-macroassembler for PC The Atmas-II macro assembler for Atari 8-bit computers. Maybe you can use it for wudsn ide very nice program. Greetings Marco. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 10, 2010 Share Posted November 10, 2010 Just to confirm: find bug was apparently user error ("Whole word" was checked when searching for part strings). LOL - I do that at least once a week at work. Usually starts with me cursing out VS2010, then feeling dumb and cursing the dummy behind the keyboard. Quote Link to comment Share on other sites More sharing options...
rchennau Posted November 11, 2010 Share Posted November 11, 2010 As a test I attempted to type in the sample program on page 161 of the Atari Operating Systems User Manual. I didn't get very far. I was able to compile and run the example.asm file provided on the WUSDN website so I know at least that much works. However when I attempted to compile this I get an error. The error is "Unknown symbol 'MEMLO boot.asm /ATASM line 11 Problem" My initial guess is I need to add some include path in WUDSN that pulls up the Atari specific labels for OS routines? [indent]; This is a sample boot application PST = $0700 ; Program Start Address (PST) *= PST ; Not sure what this means ; Diskette boot control code follows .BYTE 0 ; .BYTE PND-PST+127/128 ; Number of records for floppy disk .WORD PST ; Memory address to start load .WORD PINIT ; Program initialization LDA #PND ; Low memory limit STA MEMLO STA APPMHI LDA #PND/256 STA MEMLO+1 STA APPMHI+1 LDA #RESTRT STA DOSVEC LDA #RESTRT/256 STA DOSVEC+1 CLC RTS PINIT RTS RESTRT=* PND= * .END [/indent] Quote Link to comment Share on other sites More sharing options...
+JAC! Posted November 11, 2010 Author Share Posted November 11, 2010 My initial guess is I need to add some include path in WUDSN that pulls up the Atari specific labels for OS routines? Your guess is correct. I have created an include file in ATASM format with all definitions according to http://evilbill.org/old/orig/Atari/8-Bit/Refman/appendixB.html. But: The code sample is a boot code. To run it you would have to put it into sector 1 of a disk using a disk editor and boot the disk. While this is technically possible, I recommend to use normal executable files like those ATASM creates by default and which can be loaded from any DOS. Also: The source uses some syntax which is not valid for ATASM. LDA #RESTRT STA DOSVEC LDA #RESTRT/256 STA DOSVEC+1 must be changed to LDA #<RESTRT ;Low byte STA DOSVEC LDA #>RESTRT ;High byte STA DOSVEC+1 SystemEquates.zip Quote Link to comment Share on other sites More sharing options...
+JAC! Posted November 11, 2010 Author Share Posted November 11, 2010 Check this site out http://www.richard-jackman.de/Atari_XL/index.htm Richard finaly made a Atari 6502 cross-macroassembler for PC The Atmas-II macro assembler for Atari 8-bit computers. Maybe you can use it for wudsn ide very nice program. Hi Marco! Thanks for the hint. But supporting yet another assembler would mean too much work for me. I started with ATAMAS on my real Atari (and still use it there). But ATASM and MADS are much better and more flexible, so I don't see the need to add ATASM. I started to use ."PROC" in MADS last week and I immediately became addicted (structured ASM code, after 20 years ) Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 11, 2010 Share Posted November 11, 2010 I have created an include file in ATASM format with all definitions according to http://evilbill.org/...appendixB.html. Ta very much! "PROC" in MADS last week and I immediately became addicted (structured ASM code, after 20 years ) I'm a MADS convert too. I didn't like the idisyncratic syntax at first, but after writing a couple of big relocatable SDX programs, I've realized what a superb assembler it is. I started using STRUCTs the other week and I've never seen such readable assembler code. I'd like to convert The Last Word from ATASM to MADS, but it would be a huge undertaking. Quote Link to comment Share on other sites More sharing options...
rchennau Posted November 12, 2010 Share Posted November 12, 2010 (edited) Peter, Firstly, thank you for a wonderful tool. Second thanks for the additions. You guessed correctly that I am attempting to write boot sector code. I am fooling around and wanted to write my own OS. Really I just want to write an Atari version of the unix command of ls . I hate the command dir. Edited November 12, 2010 by rchennau Quote Link to comment Share on other sites More sharing options...
+JAC! Posted November 12, 2010 Author Share Posted November 12, 2010 I am fooling around and wanted to write my own OS. Really I just want to write an Atari version of the unix command of ls . I hate the command dir. Do you mean "D"OS? Which DOS are you using? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 12, 2010 Share Posted November 12, 2010 Really I just want to write an Atari version of the unix command of ls . I hate the command dir. Just use an alias in SDX... Quote Link to comment Share on other sites More sharing options...
HiassofT Posted November 12, 2010 Share Posted November 12, 2010 But: The code sample is a boot code. To run it you would have to put it into sector 1 of a disk using a disk editor and boot the disk. While this is technically possible, I recommend to use normal executable files like those ATASM creates by default and which can be loaded from any DOS. Actually creating a bootable ATR is very simple in ATasm, I use it quite a lot :-) Here's the adapted source code: PST = $0700 ; Program Start Address (PST) ; ATR header * = PST - 16 .WORD $0296 ; magic .WORD [PEND-PST+15]/16 ; size of ATR in 16-byte blocks .WORD 128 .WORD 0,0,0,0,0 .include "SystemEquates.asm" ; Diskette boot control code follows .BYTE 0 ; .BYTE [PEND-PST+127]/128 ; Number of records for floppy disk .WORD PST ; Memory address to start load .WORD PINIT ; Program initialization LDA #<PND ; Low memory limit STA MEMLO STA APPMHI LDA #>PND STA MEMLO+1 STA APPMHI+1 LDA #<RESTRT STA DOSVEC LDA #>RESTRT STA DOSVEC+1 CLC RTS PINIT RTS RESTRT=* PND= * ; pad to full 128-byte sector size, only works for code starting at a 128-byte boundary .IF (*&127)<>0 .DC (128-(*&127)) 0 .ENDIF PEND = * Note the ATR header at the beginning and the "padding to sector size" block at the end of the code. Also note that I put brackets in the "[PEND-PST+127]/128" statement, otherwise this means "[PEND-PST] + [127/128]", i.e. "[PEND-PST] + 0" - certainly not what it's intended to mean :-) You can then assemble the code to an ATR file using these ATasm options: atasm -r -oboot.atr boot.asm so long, Hias Quote Link to comment Share on other sites More sharing options...
rchennau Posted November 14, 2010 Share Posted November 14, 2010 I could but that wouldn't really teach me much about programming in assembly or writing raw binary files to sector 0 of a floppy disk. I mean assembly programming and boot sector writing are must have skill in in the 8-bit word and thus far I can barely spell 'c' in programming terms. Regards, Really I just want to write an Atari version of the unix command of ls . I hate the command dir. Just use an alias in SDX... Quote Link to comment Share on other sites More sharing options...
rchennau Posted November 14, 2010 Share Posted November 14, 2010 (edited) Question: Please forgive me for being dense but exactly how do I configure WUSDN (Eclipse) to read this file into my project so ATASM may compile without error? Answer: add the following line at the beginning of your assembler code .include "SystemEquates.asm" My initial guess is I need to add some include path in WUDSN that pulls up the Atari specific labels for OS routines? Your guess is correct. I have created an include file in ATASM format with all definitions according to http://evilbill.org/...appendixB.html. But: The code sample is a boot code. To run it you would have to put it into sector 1 of a disk using a disk editor and boot the disk. While this is technically possible, I recommend to use normal executable files like those ATASM creates by default and which can be loaded from any DOS. Also: The source uses some syntax which is not valid for ATASM. LDA #RESTRT STA DOSVEC LDA #RESTRT/256 STA DOSVEC+1 must be changed to LDA #<RESTRT ;Low byte STA DOSVEC LDA #>RESTRT ;High byte STA DOSVEC+1 Edited November 14, 2010 by rchennau Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 1, 2010 Share Posted December 1, 2010 Peter, Is it possible to include a list of words for syntax coloring? It would be nice to see register names like COLPF0, DMACTL, etc.. in a different color. -Bry Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 1, 2010 Author Share Posted December 1, 2010 Peter, Is it possible to include a list of words for syntax coloring? It would be nice to see register names like COLPF0, DMACTL, etc.. in a different color. -Bry Hi Bry, I have to impove serveral other things first to make something like this possible (esp. the identifier parsing) but then this is just a special case of content assist for different types of identifiers. That means you will have separate colors for system/user labels/equates/procedures/macros plus content assist (CTRL-Space) for them. I.e. you type "COLP" and the IDE suggests "COLPF0/1/2/3" including their description. That's a very long way to go, but it is possible,so I put it on the todo list. Note: Even in the first version of WUDSN IDE I had forseen the coloring for macros until I realized that it takes much more to work Quote Link to comment Share on other sites More sharing options...
pps Posted December 12, 2010 Share Posted December 12, 2010 Hi Peter, I tried several times to use eclipse and your ide with my win7 64 bit configuration. No chance to try it out, since I didn´t find any way to run even eclipse. There is a problem that causes eclipse not to find the java here Even copying the whole jre6 directory to eclipse dir (as the error message tell´s that jre is not found there) won´t work. Quote Link to comment Share on other sites More sharing options...
pps Posted December 14, 2010 Share Posted December 14, 2010 Thanks to a pm Peter sent me, I took a look above this problem again and finaly got that: Don´t know why, but Java is an 32 bit application here - installed it many times, always the same result. My Eclipse was 64 bit - I always try 64 bit applications at my 64 bit OS. Now I tried the 32 bit version of Eclipse and it runs without problems Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 15, 2010 Author Share Posted December 15, 2010 Hi there. Yesterday I played around a bit an tried to add detection for the different types of identifiers and for numbers. Now I'd like to know if you thinks that this is overkill or .. well great. Regarding Bryan request, I implemented also that you can specify the color for an indentifier in the comment using "@style=(r,b,g,r,g,b,bold/italic)". This way you could specify the styles for the system labels simply in the "SystemEquates.asm". Note: The code sample is from a MADS source. Due to its name nesting, the coloring is not always 100% correct, esp. if a name is used twice (here: fader for .local and .proc). Once it works in general I'll think about how to handle all that nesting stuff (which I great, but really complex to handle for the IDE). Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 15, 2010 Share Posted December 15, 2010 Thanks Peter! Quote Link to comment Share on other sites More sharing options...
NRV Posted December 15, 2010 Share Posted December 15, 2010 doesn't seem overkill (what? you are working instead of doing your next demo? can we have everything?? ) Quote Link to comment Share on other sites More sharing options...
pps Posted December 16, 2010 Share Posted December 16, 2010 (what? you are working instead of doing your next demo? can we have everything?? )Yes, Peter, just sit down and do something for NYD I like the numbers, as you often have a hint that on line numer xx is something wrong - then you are counting or searching for a long time. Quote Link to comment Share on other sites More sharing options...
pps Posted December 16, 2010 Share Posted December 16, 2010 (edited) oops double post, since there was a server error shown ;( Edited December 16, 2010 by pps Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 16, 2010 Author Share Posted December 16, 2010 I like the numbers, as you often have a hint that on line numer xx is something wrong - then you are counting or searching for a long time. I'm not referring to the line number on the left (they are a basic feature, nothing special in WUDSN IDE), but to the syntax highlighting for numbers. Quote Link to comment Share on other sites More sharing options...
pps Posted December 16, 2010 Share Posted December 16, 2010 I like the numbers, as you often have a hint that on line numer xx is something wrong - then you are counting or searching for a long time. I'm not referring to the line number on the left (they are a basic feature, nothing special in WUDSN IDE), but to the syntax highlighting for numbers. Oh sorry, I surely have not looked to deep into all that eclipse and your ide Thought that you meant the numbers on the left But in near future I have more time to get a "profession" with your nice thing. It is for sure better than using the editor of win and the Salamander (NC-clone) for creating new software Quote Link to comment Share on other sites More sharing options...
+JAC! Posted January 20, 2011 Author Share Posted January 20, 2011 Hi, just a short teaser When I coded Silly Things, I really had some trouble with converting images and graphics to various Atari formats. Now I found the time to clean up all my hacks and after many years I see a solution at the horizion. I have extended the Graphics Editor in the following ways: - The easy part: The converter from (Atari) file to image now supports almost everything that is also supported by Fail (incl. HIP, APAC, ...) with good heuristics to guess the file type - the ard part: The converter from PC Image to (Atari) files has come to life finally. I have included the Rhino JavaScript engine and it is great. No need to install the Java SDK, no need for compiling - just edit and run. Now you can simply write a few lines for the conversion as part of the conversion file. You can create up to 10 different Atari files from the image. You can use loop in the code to arrange the bytes in the files just as you like. Here's the sample for converting a PC picture to a Graphics 8 picture. The image size is taken 1:1 in this case. function convertToFileData(data) { var bpsl = (data.getImageDataWidth() + 7) / 8; var bytes = [] var offset = 0; for (var y = 0; y < data.getImageDataHeight(); y++) { for (var x = 0; x < data.getImageDataWidth(); x = x + { var b = 0; for (var p = 0; p < 8; p++) { var color; color = data.getPixel(x + p, y); if (color != 0) { b = b | 1 << 7 - p; } } bytes[offset++] = b; } } data.setTargetFileObject(0, bytes); } Quote Link to comment Share on other sites More sharing options...
+JAC! Posted February 10, 2011 Author Share Posted February 10, 2011 Did you know: Doing it right is alwyas more work than a quick hack? Yesterday I invested some time into the graphics conversion again and gradually my port of the Fail library is becoming complete. Almost all formats (incl. the 2nd HIP format I never knew of ) are now done, only TIP,ILC,INT,AP3 and CIN are missing yet. Quote Link to comment Share on other sites More sharing options...
