svenski Posted September 28, 2010 Share Posted September 28, 2010 Being in the US I doubt the difference between PAL B and I will bother you but quite a lot of the new flatscreen TVs sold in Europe tend to support the common PAL formats, out of the box. Quote Link to comment Share on other sites More sharing options...
Bryan Posted September 28, 2010 Share Posted September 28, 2010 You can alwayse find the commonly available TTL logic ICs that the non-freddy XLs use for these circuits. There's one exception, and that's the delay line part. Fortunately, I don't think they're easy to kill. Freddie uses a ~14MHz clock and doesn't need a delay line to make sub-cycle RAS and CAS transitions. Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted September 28, 2010 Share Posted September 28, 2010 You could even build the delay line out of analog components if you had to.. The MIo uses a similar design for it's on-board PHI2 generation when the atari is off.. Its just 2 chokes and 3 caps.. Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 28, 2010 Share Posted September 28, 2010 Looking at the 1064 schematics, it appears to just run /RAS through LS04 invertors 4 times in order to get a delay. Quote Link to comment Share on other sites More sharing options...
