+atari2600land Posted May 4, 2011 Author Share Posted May 4, 2011 I thought to myself, maybe I should play Toobin' on the NES because it's been a while. So I popped in the Tengen Toobin' and got some more inspiration. In this version, you can now move around the screen, you're no longer confined to at the top. Because of this, if you get stuck at the top, you lose a life. Otherwise, be careful not to scroll down too fast, you might not see what's ahead of you and die! Once again, you start on level 3. toobin050311.bas.bin toobin050311.bas Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted May 4, 2011 Author Share Posted May 4, 2011 Is there a way to simplify the following (byte3=score+2): if byte3>$09 then byte3=$10 if byte3>$19 then byte3=$20 if byte3>$29 then byte3=$30 and so on. Quote Link to comment Share on other sites More sharing options...
