b1sh0p Posted April 4, 2010 Share Posted April 4, 2010 Hi, I have a 5200 that won't let standard sticks move all the way right. (e.g. In Super Breakout, you stop before touching the wall, even though the stick is pressed as far as it will go.) It seems to be a calibration issue, and occurs on several different sticks. I also have tried a Wico stick (same problem) and a digital adapter, which sort of works but the stick is still not properly centered. This video explains the problem in detail: Any advice on how these issues can be fixed? Thanks! Quote Link to comment Share on other sites More sharing options...
tz101 Posted April 5, 2010 Share Posted April 5, 2010 If it were a single controller experiencing the problem, then I would say it is the pot that controls horizontal movement being out of adjustment. Since you are seeing this on multiple controllers, it is evidently something inside the console. Someone more expert than I will have to be of assistance. Adjusting the pots is really quite simple if you decide to go that route. Quote Link to comment Share on other sites More sharing options...
Ransom Posted April 5, 2010 Share Posted April 5, 2010 It sounds like the pot inside the console is the place to start. Here's a PDF that may help: 5200 Field Service Manual Quote Link to comment Share on other sites More sharing options...
zylon Posted April 7, 2010 Share Posted April 7, 2010 With that many controllers affected, I'd agree with the console being out of adjustment. Fortunately, it's an easy job. Quote Link to comment Share on other sites More sharing options...
