Sinphaltimus Posted February 17, 2018 Share Posted February 17, 2018 (edited) Classic99.exe is not a valid Win32 application. I get the same error trying to run c99 in an XP vm. Edited February 17, 2018 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 17, 2018 Share Posted February 17, 2018 Corrupted file maybe ? Quote Link to comment Share on other sites More sharing options...
Keatah Posted February 17, 2018 Share Posted February 17, 2018 I believe it has to do with the change to Visual 2017 library and/or the compiler switch options. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted February 17, 2018 Share Posted February 17, 2018 Corrupted file maybe ? Same file I'm running under Windows 10. Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 17, 2018 Author Share Posted February 17, 2018 Yeah, it's a linker option.. I guess Microsoft really wants to kill XP if the default build is actually incompatible. I installed an XP VM so I can do testing. 399a now posted, confirmed to work on 32-bit XP. Version 399a now posted - http://harmlesslion.com/software/classic99 5 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 18, 2018 Share Posted February 18, 2018 Hi, I have pulled this .WAV file from my cassette player and don´t get it handled. (I want to convert a tape to a .DSK on my Windows 7 laptop) Dilithium-WAV01.wav (After checking the new manual) I start Classic99, choose Extended Basic, boot, then say -> Disk ->Load/Rewind Tape and point to the WAV file. Then I say -> OLD CS1, and confirm with 2x Enter on the dialog. I can hear the very first rustle(?) from the recording, but then this disappears, before the sound starts. After some seconds I get "ERROR - NO DATA FOUND" What am I doing wrong, any thoughts ? (I uploaded it to JS99er, there this .WAV file works, but I don´t understand how to manage DSKs, and how to download the finished .DSK to my computer) thanks xXx EDIT: I got my DSK from JS99er so this is the result and this works. Dilithium-WAV01.wav Maybe I have to setup something special for sound in Classic99 ? I am on standard setting in the options there (-> Options -> Audio: 22050 Hz, Volume about 80%) Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 18, 2018 Share Posted February 18, 2018 (I uploaded it to JS99er, there this .WAV file works, but I don´t understand how to manage DSKs, and how to download the finished .DSK to my computer) It's a very noisy recording, and the waveform is quite different from most of the other WAVs, some of which have never seen an analog device. I'm pleased that it works in JS99'er because this shows that my attempt to deal with noise has borne fruit. After you have saved a file to a disk you can simply go to the Disk tab, select the disk from the drop down, and click Save DSK File. 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 18, 2018 Share Posted February 18, 2018 ok thanks for the info. I´ll try to check my Aiwa walkman, or the volume I just have ripped all of them off the cassette right now, now trying to convert. Hope the noise works again thanks Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 18, 2018 Share Posted February 18, 2018 PS: This is the initial WMA-RIP from my windows audio recorder, what I have converted via Nero Wave Editor to this .WAV above. Dilithium-32-Progs-XB--01.WMA.zip As I am a totally experienced audio specialist, I had to make no changes on any options in Nero ( I fell off the chair when I saw all the options and menues from Nero, so I just exported it to .WAV ) Maybe I start another topic, like "Tape List Ripping for Berserkers" 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 18, 2018 Share Posted February 18, 2018 Hi, I am trying to optimize that later, but is this a part of the problem where I can have a look on ? If so, maybe it is too loud.... Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted February 18, 2018 Share Posted February 18, 2018 When I go to TURBOFORTH in 80-columns in the latest version(s) v399 and v399a, I get a flickering or jiggling effect in the screen text. It appears to be pulsing from side to side. It wasn't there in earlier versions. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 18, 2018 Share Posted February 18, 2018 It's a very noisy recording, and the waveform is quite different from most of the other WAVs, some of which have never seen an analog device. I'm pleased that it works in JS99'er because this shows that my attempt to deal with noise has borne fruit. After you have saved a file to a disk you can simply go to the Disk tab, select the disk from the drop down, and click Save DSK File. Hi, does this noise sound a bit better ? I turned volume down to 7. (Classsic99 does not "show" any sound on playing the file yet) Dilithium-32-Progs-XB--01-Biorythm-VOLUME-7.wav thx Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 18, 2018 Author Share Posted February 18, 2018 Cassette will remain a low priority for me until someone proves that they actually require it for development. I'll take a quick look but if it doesn't work, I don't know enough about the cassette circuitry to troubleshoot it. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 18, 2018 Author Share Posted February 18, 2018 When I go to TURBOFORTH in 80-columns in the latest version(s) v399 and v399a, I get a flickering or jiggling effect in the screen text. It appears to be pulsing from side to side. It wasn't there in earlier versions. I'm just going to put Windowshade mode back in for you... Is stable here.. only theory I have is maybe you're using a non-fixed screen multiplier and your video system is doing something funny with the updates. Try Video->Change Size->1x (or 2x or 3x or 4x) and see if that makes it more stable. There's nothing in the rendering side that should be able to do that... nothing is drawn at a pixel level, for instance. Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 18, 2018 Author Share Posted February 18, 2018 Hi, does this noise sound a bit better ? I turned volume down to 7. (Classsic99 does not "show" any sound on playing the file yet) Dilithium-32-Progs-XB--01-Biorythm-VOLUME-7.wav thx It is very staticy but I can see the data... it gives me a little better idea what the system is trying for. Classic99 is seeing too much of the noise, I think - kudos to JS99er for getting it! 3 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted February 18, 2018 Share Posted February 18, 2018 Fixed size corrected it. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Retrospect Posted February 19, 2018 Share Posted February 19, 2018 Just read all your updates in that txt file. God that took a long time. Classic99 supported text pasting in Nov 2001 and was only called Classic99 by 2002. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted February 28, 2018 Share Posted February 28, 2018 Hello, there is a way to simulate the PIO in Classic99 ? Cataloging software and test hundreds of programs i often have this error I always have to delete all lines with PIO commands but it would be nice if instead could be a software simulation at least. Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 28, 2018 Author Share Posted February 28, 2018 If you just want to ignore the PIO access I guess a blank DSR could be loaded. You'd have to set up a cartridge in Classic99.ini with the module you want and the DSR file. This will work for BASIC or XB (by selecting the Extended BASIC module plus the dummy DSR). Drop the attached file into the MODS folder, and add this to your Classic99.ini. Then select it from the Cartridge->User menu instead of normal Extended BASIC. [usercart1] name=PIO with XB rom1=O|0000|0004|Select XB rom2=D|1200|0040|.\MODS\C99FakePIO.BIN C99FakePIO.BIN 2 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted March 1, 2018 Share Posted March 1, 2018 (edited) Ok, thanks Tursi, Programs are from floppy disks in EA3, EA5 or XB until now, anyway i'll try this EDIT:Oh yeah... i tried and it working nice at least in XB i solved the problem ! Edited March 1, 2018 by ti99iuc Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted March 1, 2018 Share Posted March 1, 2018 (edited) Hi Mike.Just wanted to poke you about the "profiles" request. So many new games and programs coming out, so many times I have to changes DSK1 to something else either FIAD or DSK when I'm not done using the previous configuration.I keep wishing for profiles, but not yet...Or did I miss them being added somewhere along the line? I don't want to be a pain in the arse lol. I wish I had the skill necessary to help or create a third party utility to fill this empty hole in my heart. So along those lines, I know there is a way for folks to capture and save the VDP/ram/rom/grom etc.. in the TI emulation or something like that using the debugger. A sort of "Save State" function is what I'm thinking. But does that or could that also save DSKx assignments in c99? And what cart is inserted? And what system is selected? and what features (in c99) are enabled? Because if so, then I already have what I need. I just need to learn how to use it and save each State, with a descriptive filename. In other words, can it save the state of classic99 or does it only save the state of the emulated TI internals? Edited March 1, 2018 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 1, 2018 Share Posted March 1, 2018 (edited) Just wanted to poke you about the "profiles" request. So many new games and programs coming out, so many times I have to changes DSK1 to something else either FIAD or DSK when I'm not done using the previous configuration. I keep wishing for profiles, but not yet... Or did I miss them being added somewhere along the line? I don't want to be a pain in the arse lol. I wish I had the skill necessary to help or create a third party utility to fill this empty hole in my heart. You could have different classic99.ini files. Rename as you need them. Or you could have different directories, each with a Classic99 installation (footprint is (can be) relatively small). So along those lines, I know there is a way for folks to capture and save the VDP/ram/rom/grom etc.. in the TI emulation or something like that using the debugger. A sort of "Save State" function is what I'm thinking. But does that or could that also save DSKx assignments in c99? And what cart is inserted? And what system is selected? and what features (in c99) are enabled? Because if so, then I already have what I need. I just need to learn how to use it and save each State, with a descriptive filename. In other words, can it save the state of classic99 or does it only save the state of the emulated TI internals? Rasmus' JS99'er has save states. Take a look here. Edited March 1, 2018 by sometimes99er 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted March 1, 2018 Share Posted March 1, 2018 You could have different classic99.ini files. Rename as you need them. Or you could have different directories, each with a Classic99 installation (footprint is (can be) relatively small). Rasmus' JS99'er has save states. Take a look here. Thanks, those are great ideas. I can say I never once opened up the c99 ini. I should probably read the docs for it as well. That might very well be all I need. JS99er is an option too but I don't see any download links for the newest version. They must have been downloadable at some point because I have a local copy (old) here on my system, but AFAIK, the topic thread isn't updated with the latest version to DL. Maybe I'm mistaken? Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted March 1, 2018 Share Posted March 1, 2018 (edited) JS99er is an option too but I don't see any download links for the newest version. They must have been downloadable at some point because I have a local copy (old) here on my system, but AFAIK, the topic thread isn't updated with the latest version to DL. Maybe I'm mistaken? JS99'er basically runs in the browser and stuff is probably updated/reloaded if your cache holds an older copy of a resource - or was it press F5 to refresh. Yes, I guess one can still download (GitHub) and have most if not all stuff functional, locally and offline. Edited March 1, 2018 by sometimes99er 2 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted March 1, 2018 Share Posted March 1, 2018 FYI, I took yesterday and downloaded and installed Wine on my Macbook Air and ran Classic99 on the Macbook--- Cool beans!! 2 Quote Link to comment Share on other sites More sharing options...
