Dopeyman06 #2226 Posted January 24 5 hours ago, rcamp48 said: Hi everyone, thanks to Amis, I now have a good working copy of Forem XE Professional. Now that this part is out of the way , I am going to take the Atari 8 Bit Tosec library and convert it into Forem XE data content that follows the structure for Forem XE Professional, I am actually going to use DIR2ATR to create several 16.7 MB atrs that will serve as data containers to be used with Forem XE Pro. This will take a lot of work as Tosec is sorta semi organized, I intend the use the A,B,C,D,E,F , etc directory structure up to I believe M, subdirectories will be apps, basic, comms, demos, games, graphics, language, music, program, utility and any other suggestion of a good category. The hard part will be taking the Tosec list and dividing it all up into separate atrs that will match the category, but once that is done I will release it here and on Facebook for all sysops to use if they choose to use Forem XE Professional. I will be using Total commander to create , sort, and copy all of the directories, and the use a special command with dir2atr to make up the 16.7 meg atrs. Of course inside these atrs will be more atrs, the newest dir2atr shortens long filenames so I don't have to worry about that. Here is the part for you AMIS, can you take ForemXE PRO and extend the 20 directory limit to handle 26 directories per drive? That will be needed as my directory structure will eventually be from A-Z, I could do it but you are more familiar with Forem XE Pro than I am. Give me 1 day and I will have something ready for all Forem XE Pro sysops. Russ 1 Quote Share this post Link to post Share on other sites
+Tillek #2227 Posted January 25 12 hours ago, rcamp48 said: Hi everyone, thanks to Amis, I now have a good working copy of Forem XE Professional. Now that this part is out of the way , I am going to take the Atari 8 Bit Tosec library and convert it into Forem XE data content that follows the structure for Forem XE Professional, I am actually going to use DIR2ATR to create several 16.7 MB atrs that will serve as data containers to be used with Forem XE Pro. This will take a lot of work as Tosec is sorta semi organized, I intend the use the A,B,C,D,E,F , etc directory structure up to I believe M, subdirectories will be apps, basic, comms, demos, games, graphics, language, music, program, utility and any other suggestion of a good category. The hard part will be taking the Tosec list and dividing it all up into separate atrs that will match the category, but once that is done I will release it here and on Facebook for all sysops to use if they choose to use Forem XE Professional. I will be using Total commander to create , sort, and copy all of the directories, and the use a special command with dir2atr to make up the 16.7 meg atrs. Of course inside these atrs will be more atrs, the newest dir2atr shortens long filenames so I don't have to worry about that. Here is the part for you AMIS, can you take ForemXE PRO and extend the 20 directory limit to handle 26 directories per drive? That will be needed as my directory structure will eventually be from A-Z, I could do it but you are more familiar with Forem XE Pro than I am. Give me 1 day and I will have something ready for all Forem XE Pro sysops. Russ With all due respect... there are no Forem XE Pro Sysops except for the demo. I am considering it, but if I did, I really have no interest in this collection. I'm not trying to discourage you, but I just don't want you wasting your time with something that no one is really interested in. We all have a limited number of hours in the day and a longer list of Atari Projects that we can probably accomplish in our lifetimes. So if you want to do it for you, great. If you want to do it for "someone else" to run with, I suggest waiting until "someone else" lets you know they'll put your efforts to good use. Quote Share this post Link to post Share on other sites
_The Doctor__ #2228 Posted January 25 16.7 meg atr's are not standard fare for Atari Native file systems... we use MyDOS, SpartaDos, etc for real equipment. That means 16 meg, SpartaDOSX does 32 meg but BBS Express won't won't run on X.... Quote Share this post Link to post Share on other sites
rcamp48 #2229 Posted January 25 17 hours ago, Tillek said: With all due respect... there are no Forem XE Pro Sysops except for the demo. I am considering it, but if I did, I really have no interest in this collection. I'm not trying to discourage you, but I just don't want you wasting your time with something that no one is really interested in. We all have a limited number of hours in the day and a longer list of Atari Projects that we can probably accomplish in our lifetimes. So if you want to do it for you, great. If you want to do it for "someone else" to run with, I suggest waiting until "someone else" lets you know they'll put your efforts to good use. I am really doing it for myself, so no offense taken, if others are interested then so be it, but I do have only one project right now and this is it, I would love to see it working again, and I think I have a solution for the problem that is occurring with the Z handler, that is part of the problem ,and yes doctor I have given up on the 16.7 MB files, Spartados will read them but not the sub directories , there is a solution for the z: handler not reading on FN , I am working on combining the FN handler with the Z handler, I can see where it is going amiss , in lines 1000 to 1100 it does an xio to the z: handler, that part does not update properly, I do have a solution in mind actually completely removing all references to that part in lines 1000 to 1100 and putting in a series of pokes to addresses that do the same thing. Anyways that might get it going on my end. Russ Quote Share this post Link to post Share on other sites
+Tillek #2230 Posted January 25 All good then... Good luck with the project and safe travels! 1 Quote Share this post Link to post Share on other sites
rcamp48 #2231 Posted January 26 For those of you who would like to work on the source code for Forem XE Professional 5.4 I managed to get it in printable form on the PC by listing it to P1 on the fujinet from my 800xl, so we have a workable source to modify if you wish, I am going to add the FN Apetime routine somehow into the program. foremxe printout.txt It is best to keep a copy of this unmodified source if you are going to make any changes to it, I was thinking of increasing the baud rate to the highest that the Atari 8 Bit can handle, 9600 may be the fastest, but 56 K may be possible over telnet, Doctor , you can tell me if this is possible? Russ 1 Quote Share this post Link to post Share on other sites
rcamp48 #2232 Posted January 26 3 hours ago, Tillek said: All good then... Good luck with the project and safe travels! Thanks, I will be calling your BBS more often now that I am close to getting my Atari BBS running. I have only had a windows BBS running for a year solid, its at http://christfollowersbbs.ca (supposed to be https but having problems doing that lately, I have a huge Atari file section on it, 8 Bit, ST, Jaguar, Lynx, 2600, Portfolio, and Falcon). Russ Quote Share this post Link to post Share on other sites
+Amis #2233 Posted January 26 On another note, the restoration of the Atari Corporate BBS, Nite Lite has been completed. This was the most challenging (Forem XE pro was 5 hours of work) Nite lite clocks in at 3 weeks of effort to remove the BlackBox requirements which were built into the modem routines along with the device being required for all modem polling and answer. Add to this no screens or menus existed as well as no new user password/account set up and well you get the picture.. Running on nitelite.ddns.net port 9000 This is a real departure from the usual Atari BBS and contains some great features especially in the message bases with find and replace editing, "what" feature for reading reply source message and grouping, database improvements for stability, and low maintenance. Available notes: "Paul Swanson's BBS with RAM disk. Paul Swanson was a programmer from the Boston, Massachusetts, USA, area. I'm not sure whether his BBS for the Atari 8-bit has been placed into the public domain or not. This BBS was the first to support a RAMdisk, which Paul Swanson called a "V:" device for "virtual disk". This BBS was written in Atari BASIC and required a joystick hardware "dongle" device. This was notable as being one of the first Atari 8-BIT BBSes that could actually go for a week without having to be rebooted. Pointers to the message base were kept in an Atari "very long string" (for which Atari BASIC is famous). The BBS would only have problems (for the most part) if this string became corrupted." - Atari FAQ And if you don't want to log into the BBS but get a view: The Southern Amis Projects, restores and preserve Atari BBS history. Rebuilding BBS programs for the Atari 8Bit back to ready-to-use reliability and completeness of documentation, source code and sysop support. All BBS's are run active and shared on southernamis.com upon final user testing and completeness of each version for real-hardware, modem, Fujinet, and Emulators. To-date over 10 BBS's from AMIS, FoReM, ESP, AtariLink, Phonem, NightShift, Hutch BBS,NiteLite, Others have been restored under the project. Southern Amis core bbs is Atascii/Atari Only southernamis.ddns.net port 23 and AMIS XE amis86.ddns.net port 9000 for Atascii and Ascii users 3 Quote Share this post Link to post Share on other sites
+DarkLord #2234 Posted January 26 Nite Lite was the first BBS software used by Atari Corp. with their BBS, followed by Michtron BBS software for the Atari ST, IIRC. I wonder, did they ever use any other BBS software or was that the only 2 they ever used? 1 Quote Share this post Link to post Share on other sites
+bf2k+ #2235 Posted January 26 The Nite Lite looks very cool... 1 Quote Share this post Link to post Share on other sites
+Tillek #2236 Posted January 26 Looking forward to trying this one out. 1 Quote Share this post Link to post Share on other sites
Bikerbob #2237 Posted January 27 gave it a go tonight.. nice... not bad for an early bbs. Bikerbob 1 Quote Share this post Link to post Share on other sites
rcamp48 #2238 Posted January 28 (edited) Finally, I got Forem XE Pro running , now to do some programming work on it, I want to enable 19200 BPS on it , should be doable. Forem XE Pro Updated Disk.atr And the video to go with it: Forem XE Pro in Action Edited January 28 by rcamp48 adding a file Quote Share this post Link to post Share on other sites
rcamp48 #2239 Posted January 28 Spy Visits Spy BBS is now resurrected and available at telnet://christfollowersbbs.ca port 6502 And yesI will make the software available to anyone that wants it. I am thinking about restarting ForemNet as well, so you can apply for Node numbers if you want. Russ Sorry no 6.0 ok? Quote Share this post Link to post Share on other sites
_The Doctor__ #2240 Posted January 28 I'm confused, why would we need to apply to you to set up our own nodes? I didn't remember the sysop conference that appointed you to be the lead or to handle the node list. You certainly run with things. I appreciate some of what you do, but you are awfully bold to do such things when others have done the hard work to make it happen. Maybe you should have a conversation with folks before assuming such roles. 2 Quote Share this post Link to post Share on other sites
rcamp48 #2241 Posted January 28 Sorry Doc, I should have checked things out more.... I apologize to everyone. Quote Share this post Link to post Share on other sites
+Tillek #2242 Posted January 28 42 minutes ago, _The Doctor__ said: I'm confused, why would we need to apply to you to set up our own nodes? I didn't remember the sysop conference that appointed you to be the lead or to handle the node list. You certainly run with things. I appreciate some of what you do, but you are awfully bold to do such things when others have done the hard work to make it happen. Maybe you should have a conversation with folks before assuming such roles. So.... those who are "in the know"... already know. The others... well.. they're not going to listen to anything until... they... experience it for themselves... and then become one of those who are "in the know". It's one of the reasons the "real BBS community" doesn't post much here anymore. We're discussing these things on BBSs. There is a separate BBS "community"... those who don't actually call real BBSs but just like to talk about them on internet forums..... That's the only audience who might be confused, and since they never actually enter BBS land... It doesn't matter what they say, think or believe (well, at least it doesn't matter to us, so ....) 2 Quote Share this post Link to post Share on other sites
rcamp48 #2243 Posted January 28 1 hour ago, rcamp48 said: Spy Visits Spy BBS is now resurrected and available at telnet://christfollowersbbs.ca port 6502 And yesI will make the software available to anyone that wants it. I am thinking about restarting ForemNet as well, so you can apply for Node numbers if you want. Russ Sorry no 6.0 ok? Sorry but node numbers are beyond me , I am just not interested, if someone else is doing this I would be interested. Quote Share this post Link to post Share on other sites
rcamp48 #2244 Posted January 28 21 minutes ago, Tillek said: So.... those who are "in the know"... already know. The others... well.. they're not going to listen to anything until... they... experience it for themselves... and then become one of those who are "in the know". It's one of the reasons the "real BBS community" doesn't post much here anymore. We're discussing these things on BBSs. There is a separate BBS "community"... those who don't actually call real BBSs but just like to talk about them on internet forums..... That's the only audience who might be confused, and since they never actually enter BBS land... It doesn't matter what they say, think or believe (well, at least it doesn't matter to us, so ....) What is your BBS address Tillek? Quote Share this post Link to post Share on other sites
+Amis #2245 Posted January 28 On 1/26/2022 at 10:47 AM, DarkLord said: Nite Lite was the first BBS software used by Atari Corp. with their BBS, followed by Michtron BBS software for the Atari ST, IIRC. I wonder, did they ever use any other BBS software or was that the only 2 they ever used? Just adding the Nite Lite ST Files here.. Nite Lite ST.zip 2 Quote Share this post Link to post Share on other sites
moonlight_mile #2246 Posted January 28 Spy Visits Spy BBS is now resurrected and available at telnet://christfollowersbbs.ca port 6502 And yesI will make the software available to anyone that wants it. I am thinking about restarting ForemNet as well, so you can apply for Node numbers if you want. Russ Sorry no 6.0 ok? Sorry but whenever I try to connect there is no answer. Quote Share this post Link to post Share on other sites
+bf2k+ #2247 Posted January 28 4 minutes ago, moonlight_mile said: Sorry but whenever I try to connect there is no answer. Same here... Quote Share this post Link to post Share on other sites
rcamp48 #2248 Posted January 28 (edited) Sorry but its down right now I have to totally redo it from the original arc files, apparently the files that I got from the 'latest sources' are corrupt, or have become corrupt. Be assured that I am working on the whole thing as we speak, it might take 3-4 days or more but I will get it done. An example : the Sigutil.bxe is corrupt, as well as several other files. This is my own fault. I believe the culprit is the unarcing of the various arc file , correct me if I am wrong Amis, but it has to be done on the Atari 8 Bit, I am taking the original files and unarcing them separately on my 800XL, in the meantime try logging into telnet christfollowersbbs.ca port 23 , it has been up for over 2 years and is running solid. Online games etc, and Atari 8 Bit files, over 10 TBs online. This is my original work of making a BBS but it is PC run not Atari, still it serves Atari files. Also for those of you who have Fujinet devices, I have a TNFS server at christfollowersbbs.ca Anyways for the rest of the afternoon I will be working on Forem. I know that there may not be a lot of interest in it, but #1) I have been in isolation for over a month and #2) I am interested in it so thats all that counts. I will also be working on my website by the same name, getting the secured end up and running, I paid for secure service way back in December and it is not working , that is # 1 priority right now. Edit: I used the arc files from my directories for disks 2 and 3, so what I had running was definitely corrupt, its was not working right , as the file section was no good.... I may have had a BBS that let you log on , but that was all, still if you want a good BBS, try my telnet site from above. And give the online game Rocking Radio a try, it is cool. Russ Edited January 28 by rcamp48 Quote Share this post Link to post Share on other sites
+bf2k+ #2249 Posted January 28 Couldn't connect on port 23 either... Quote Share this post Link to post Share on other sites
rcamp48 #2250 Posted January 28 27 minutes ago, bf2k+ said: Couldn't connect on port 23 either... Try it now its up and running , I had to reboot the computer about the time you called. Quote Share this post Link to post Share on other sites
