Dr Do Posted August 25, 2012 Share Posted August 25, 2012 Yet more Atari questions! After several rounds of adjusting and swapping out ICs, I've now managed to get my Atari 800 up and running. There is, however, a slight quirk in its operation that I'm hoping to iron out. The function keys don't appear to perform the actions that they should do - at first, "Select" was doing a warm restart, "Start" (or was it "Option") was doing the action of Select and "Reset" was doing nothing at all. My guess was that it was something to do with the J114 connector, so I turned this the other way up - only to find that the functions changed, but still didn't correspond to the buttons (now, "Reset" acts as "Start"!). Does anyone know what I should be doing with this connector, or whether I should be looking at something else? Quote Link to comment Share on other sites More sharing options...
russg Posted August 25, 2012 Share Posted August 25, 2012 Yet more Atari questions! After several rounds of adjusting and swapping out ICs, I've now managed to get my Atari 800 up and running. There is, however, a slight quirk in its operation that I'm hoping to iron out. The function keys don't appear to perform the actions that they should do - at first, "Select" was doing a warm restart, "Start" (or was it "Option") was doing the action of Select and "Reset" was doing nothing at all. My guess was that it was something to do with the J114 connector, so I turned this the other way up - only to find that the functions changed, but still didn't correspond to the buttons (now, "Reset" acts as "Start"!). Does anyone know what I should be doing with this connector, or whether I should be looking at something else? How are you measuring the consol keys? Are you using a BASIC cart, with PEEK(53279)? Quote Link to comment Share on other sites More sharing options...
Dr Do Posted August 25, 2012 Author Share Posted August 25, 2012 (edited) How are you measuring the consol keys? Are you using a BASIC cart, with PEEK(53279)? I just tried using them in Star Raiders and noted how the game responded, and then tried to do a cassette boot with what I thought were the correct function keys. Should I do the PEEK as described? (Although I don't have the BASIC cart). Edited August 25, 2012 by Dr Do Quote Link to comment Share on other sites More sharing options...
russg Posted August 25, 2012 Share Posted August 25, 2012 (edited) How are you measuring the consol keys? Are you using a BASIC cart, with PEEK(53279)? I just tried using them in Star Raiders and noted how the game responded, and then tried to do a cassette boot with what I thought were the correct function keys. Should I do the PEEK as described? (Although I don't have the BASIC cart). You,re probably correct. Do you have a SIO2PC or APE or Aspeqt, something to load DOS from? How are you measuring the consol keys? Are you using a BASIC cart, with PEEK(53279)? I just tried using them in Star Raiders and noted how the game responded, and then tried to do a cassette boot with what I thought were the correct function keys. Should I do the PEEK as described? (Although I don't have the BASIC cart). I guess you don't have a SIO2PC or APE device. If you can get a way to load a DOS disk, you can load BASIC from DOS. Then you would type: 10 X=PEEK(53279) 20 ? X;", "; 30 GOTO 10 RUN <ENTER> It should show: no consol key pressed - 7 OPTION - 3 SELECT - 5 START - 6 and RESET should exit the program back to READY prompt. Here's DOS 2.5 disk with BASICB.OBJ .ATR file. DOS25.zip Edited August 25, 2012 by russg 1 Quote Link to comment Share on other sites More sharing options...
fibrewire Posted August 25, 2012 Share Posted August 25, 2012 I know this sounds dumb and obvious, but are the keys in the right spot? 1 Quote Link to comment Share on other sites More sharing options...
Dr Do Posted August 25, 2012 Author Share Posted August 25, 2012 Here's DOS 2.5 disk with BASICB.OBJ .ATR file. Thanks for that Russg. The output for my keys make for interesting reading: Option returned 5 Select returned 3 Reset returned 6 Start reset the machine! I know this sounds dumb and obvious, but are the keys in the right spot? You say that sounds dumb, but the same thought did cross my mind for a second. They are in their correct positions, though. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted August 25, 2012 Share Posted August 25, 2012 Ribbon cable plugged in upside down.. 1 Quote Link to comment Share on other sites More sharing options...
russg Posted August 26, 2012 Share Posted August 26, 2012 (edited) Ribbon cable plugged in upside down.. Yes, that's it. The little four pronged cable is upside down. Edited August 26, 2012 by russg Quote Link to comment Share on other sites More sharing options...
Dr Do Posted August 26, 2012 Author Share Posted August 26, 2012 Ribbon cable plugged in upside down.. Yes, that's it. The little four pronged cable is upside down. That's fixed it - marvellous. Thanks folks. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted August 27, 2012 Share Posted August 27, 2012 (edited) Some more PEEK(53279) values. Values Keys pressed 0 OPTION/SELECT/START 1 OPTION/SELECT 2 OPTION/START 3 OPTION 4 SELECT/START 5 SELECT 6 START 7 none Edited August 27, 2012 by rdea6 2 Quote Link to comment Share on other sites More sharing options...
sanny Posted November 17, 2017 Share Posted November 17, 2017 Or, maybe, for us ASM and C programmers, a bit mask: Value of 53279 ($D01F), key pressed results in a "0" bit, not pressed in a "1" bit: OPTION XXXXXX011 SELECT XXXXXX101 START XXXXXX110 'X' means: ignore that bit. Quote Link to comment Share on other sites More sharing options...
