The Usotsuki Posted December 4, 2012 Author Share Posted December 4, 2012 Yeah, it might be. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 5, 2012 Share Posted December 5, 2012 I spent a few minutes on this and I got it to assemble, but I had to comment out all the .IFDEF .ELSE .ENDIF code and force it to assemble the lines I wanted. I'll test it tomorrow if I get a chance. Then I'll see about writing the Donkey Kong music. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 5, 2012 Share Posted December 5, 2012 Couldn't sleep so I looked through the lst file. The test code + variables take almost 255 bytes. For the game, some of that would go away but would be replaced with stub routines to play different songs. The interrupt handler that actually plays the song takes about 100 bytes of that. The stub routines as well as start/stop routines could reside in one memory location and the interrupt in another if needed, The demo song I have makes the demo take up over 5K. I didn't realize it was that big. Donkey Kong songs shouldn't be very large though. If I add support for one shot sounds, the interrupt handler will probably grow by at least 50 bytes just due to having to manage timers for 3 channels and via control for the 2nd sound chip. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 5, 2012 Author Share Posted December 5, 2012 If it works... I don't know a lot about sound programming, honestly. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 5, 2012 Share Posted December 5, 2012 Now if I can just get Ciderpress to write to the disk image so I can test. Working with new tools always seems to be worse than the actual coding itself. Are you working on the intro screen animation still? Once I get some music up I could help. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 5, 2012 Author Share Posted December 5, 2012 I couldn't figure it out x.x. All I have is the blank image. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 6, 2012 Share Posted December 6, 2012 Well, it took me over a half hour just to get Ciderpress to work. Turns out it transfers the file just fine if you double click on it but if you select it and click the button it gives you an error. At least on the version I have. The binary isn't loading at the proper address or something so I still have some work to do. New platform... new tools... new issues. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 6, 2012 Author Share Posted December 6, 2012 From BASIC you can force the load address. Generally, Ciderpress uses a tag on the filename to determine the load address to place in the filesystem (#068000, for example, means type $06 or BIN, load address $8000 or 32768). Most of my homebrewed tools rely on this tag. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 6, 2012 Share Posted December 6, 2012 (edited) I'm using DOS 3.3 for the test so I put a fake DOS 3.3 header at the start of my file which tells DOS the load address and length. <edit> The ProDOS header is a bit more complex and I didn't want to deal with that yet. The DOS 3.3 header is built automatically like this... at least if the docs I found are correct. This before any CPU instructions or data. .CODE .org $8000-4 ; 4 is the length of the DOS 3.3 header ;************************************************************** ;* dos 3.3 header ;************************************************************** DOSHEADERSTART: .addr _main ; start address .addr (PROGRAMEND -DOSHEADEREND) ; length where PROGRAMEND is placed at the end of the program & code DOSHEADEREND: Edited December 6, 2012 by JamesD Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 6, 2012 Author Share Posted December 6, 2012 The DOS 3.3 header is a little-endian word with the address, and a little-endian word with the length. I think you got it right. I too usually do most of my testing with DOS 3.3 - it's just quicker to get going that way. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 7, 2012 Share Posted December 7, 2012 Well, the header code doesn't seem to work. Something Ciderpress does to a file with the extended name does. Ill figure that out another time. The code runs but the interrupt wasn't triggering. The VIA timer code needs some changes and I might have to test a few different settings. I'm trying to switch from the one shot timer to a free running timer for more accurate timing. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 17, 2012 Share Posted December 17, 2012 Ok, I have some time to work on this today. Just an FYI, the Mockingboard demo disk includes an interrupt driven music demo. They just didn't include source to it. I didn't work out the numbers but I think they are playing at 30Hz, which explains why earlier Mockingboard emulation interrupted at that rate no matter what. The AY chip setup for the Mockingboard appears to be slightly different than for the Oric so I'll have to change a few things. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 17, 2012 Share Posted December 17, 2012 The test player now works. I had to fix a couple defines that were wrong and it wasn't playing because I used the wrong branch test for the playing flag in the interrupt. It was always exiting the interrupt without playing. Once I figured out the debugger it was obvious what was going on. One question... when the hell did I change that line of code? LOL I have some cleanup to do on the code, I have to look up a couple Apple specific things, and I have to write some music data appropriate for Donkey Kong but progress has been made. How do I attach a disk image to a message in this forum? Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 18, 2012 Author Share Posted December 18, 2012 Prolly same as anything else. In full editor mode you can attach files. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 Initial test disk image attached. Just BRUN the bin file on the disk image. ForestTest.zip Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 (edited) I found a rough disassembly of the demo music player that came with the Mockingboard on this page. I just borrowed some of the VIA settings from it rather than figure out the free running timer settings myself. <edit> Oops, it's a disassembly of the Music Construction Set player. I didn't read the title of the post until I checked the link. Edited December 18, 2012 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 Ok, each separate song will have a routine similar to this that has to be called at the start of a level or screen. Since it's only called at the beginning of a level I figured it would be simpler this way. Just insert a jsr to the song routine at the beginning of each level. The variables could be initialized inline and you could jsr directly to the playsong routine if you prefer. ;************************************************************** ;* playtestsong ;************************************************************** ;* This plays the sample song for testing the code ;************************************************************** playtestsong: lda #<testsong sta songstart lda #>testsong sta songstart+1 jmp playsong The first level music would be a good test case so that's what I'll work on first. I thought about the 'How High Can You Get' screen but it's existing "music" would have to be removed and would require more work. I think screen 4 is going to have to be a unique case where the song is the spring bouncing and falling sounds. The sound will get out of time with the animation if it's not played every time a spring starts so that could make patching difficult. Maybe we can implement an intro screen before we do that. I'll post more code when I get things cleaned up a bit. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted December 18, 2012 Author Share Posted December 18, 2012 It plays. Bit low and in AppleWin it distorts, but it works. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 (edited) It sounds the same on the Oric. Edited December 18, 2012 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 How low it plays just depends on the data. I think that sounds like something from an RPG but I really don't know if it came from a game or was just a demo. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 Here is the code that just calls everything else for the test case. The init only needs called once before you play anything and the destruct only needs called if you want to clean up to exit. You just call the routine you want to start a peticular song and when you want it to stop you call stopsong. BTW, the demo song wasn't very complex and the player is actually capable of updating all the AY registers each interrupt which is at the same rate the screen is refreshed. .CODE .org $8000 START: ; just so we have the start address in the list file ;************************************************************** ;* main ;************************************************************** ;* This is the main routine for the demo code. ;* It calls routines to initialize the hardware/software, ;* plays the song, performs a busy loop until the song is done, ;* and then calls the stopsong to disable playing. ;************************************************************** _main: php ;save registers pha tya pha txa pha jsr playerinit ; initialize the player and sound hardware jsr playtestsong ; call the stub routine that plays the test song data @loop: bit Playing ; wait for song to finish bne @loop jsr stopsong ; clear the playing flag and stop the AY chip sound output jsr playerdestruct ; remove our interrupt and cleanup pla ;restore registers tax pla tay pla plp rts ;return Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 Here is what the test song looks like. Much longer than the songs for Donkey Kong. testsong: ; rem song ; rem wait, number of registers to change, ; register number, new value ; register number, new value ; etc. ; ends when number of registers to change is 0. .byt 1,4,8,0,9,0,10,0,7,56 ;-- snip .byt 1,3,0,221,1,1,8,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,8,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 29,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 29,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,236,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,89,1,2,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 29,2,8,0,9,0 .byt 1,3,0,246,1,2,8,15 .byt 29,1,8,0 .byt 1,3,0,236,1,5,8,15 .byt 29,1,8,0 .byt 1,3,0,221,1,1,8,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,8,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 13,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,251,1,4,8,15,2,62,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,83,1,3,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,187,1,3,8,15,2,221,3,1,9,15 .byt 29,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,112,3,4,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,246,3,2,9,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,8,0 .byt 1,7,0,221,1,1,8,15,9,0,2,151,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,169,1,1,8,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,123,3,1,9,15 .byt 29,1,8,0 .byt 1,7,0,221,1,1,8,15,9,0,2,244,3,3,9,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,9,0 .byt 1,7,8,0,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,187,1,3,8,15,2,221,3,1,9,15 .byt 29,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,112,3,4,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,246,3,2,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,8,0 .byt 1,7,0,89,1,2,8,15,9,0,2,236,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,236,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 29,2,8,0,9,0 .byt 1,3,0,221,1,1,8,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,8,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,221,3,1,9,15 .byt 28,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 13,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,62,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,123,3,1,9,15 .byt 28,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,187,1,3,8,15,2,221,3,1,9,15 .byt 29,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,236,1,5,8,15,2,89,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,236,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,112,3,4,9,15 .byt 29,2,8,0,9,0 .byt 30,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,4,9,0,2,125,3,2,9,15 .byt 15,6,0,251,1,4,8,15,4,62,5,1,10,15 .byt 14,1,10,0 .byt 1,4,9,0,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,244,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,123,1,1,8,15,9,0,2,187,3,3,9,15 .byt 14,1,8,0 .byt 1,3,0,169,1,1,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,62,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,9,0 .byt 1,6,2,236,3,5,9,15,4,123,5,1,10,15 .byt 14,2,8,0,10,0 .byt 1,3,0,169,1,1,8,15 .byt 13,2,8,0,9,0 .byt 1,9,0,179,1,4,8,15,2,246,3,2,9,15,4,221,5,1 .byt 10,15 .byt 13,1,10,0 .byt 1,3,4,250,5,1,10,15 .byt 13,3,8,0,9,0,10,0 .byt 1,6,0,112,1,4,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,246,3,2,9,15 .byt 13,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 28,2,8,0,9,0 .byt 1,3,0,123,1,1,8,15 .byt 13,1,8,0 .byt 1,3,0,62,1,1,8,15 .byt 13,1,8,0 .byt 1,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 13,1,8,0 .byt 1,4,9,0,2,125,3,2,9,15 .byt 14,6,0,251,1,4,8,15,4,62,5,1,10,15 .byt 13,2,9,0,10,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,221,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,203,1,2,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,236,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,89,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,112,1,4,8,15,2,56,3,2,9,15 .byt 30,2,8,0,9,0 .byt 32,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,4,9,0,2,125,3,2,9,15 .byt 15,6,0,251,1,4,8,15,4,62,5,1,10,15 .byt 14,1,10,0 .byt 1,4,9,0,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,244,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,123,1,1,8,15,9,0,2,187,3,3,9,15 .byt 14,1,8,0 .byt 1,3,0,169,1,1,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,62,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,9,0 .byt 1,6,2,236,3,5,9,15,4,123,5,1,10,15 .byt 14,2,8,0,10,0 .byt 1,3,0,169,1,1,8,15 .byt 13,2,8,0,9,0 .byt 1,9,0,179,1,4,8,15,2,246,3,2,9,15,4,221,5,1 .byt 10,15 .byt 13,1,10,0 .byt 1,3,4,250,5,1,10,15 .byt 13,3,8,0,9,0,10,0 .byt 1,6,0,112,1,4,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,246,3,2,9,15 .byt 13,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 29,2,8,0,9,0 .byt 1,3,0,123,1,1,8,15 .byt 13,1,8,0 .byt 1,3,0,62,1,1,8,15 .byt 13,1,8,0 .byt 1,6,0,83,1,3,8,15,2,101,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,56,1,2,8,15,2,169,3,1,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,9,0 .byt 1,6,2,251,3,4,9,15,4,62,5,1,10,15 .byt 13,2,8,0,10,0 .byt 1,3,0,101,1,1,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,123,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,221,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,236,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,89,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,112,1,4,8,15,2,56,3,2,9,15 .byt 30,2,8,0,9,0 .byt 32,3,0,221,1,1,8,15 .byt 14,1,8,0 .byt 1,3,0,250,1,1,8,15 .byt 14,1,8,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,1,9,0 .byt 1,7,8,0,0,187,1,3,8,15,2,221,3,1,9,15 .byt 28,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,112,3,4,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,62,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,123,3,1,9,15 .byt 28,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 13,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 14,2,8,0,9,0 .byt 1,6,0,203,1,2,8,15,2,123,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,251,1,4,8,15,2,62,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,101,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,83,1,3,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,187,1,3,8,15,2,221,3,1,9,15 .byt 28,2,8,0,9,0 .byt 1,6,0,244,1,3,8,15,2,221,3,1,9,15 .byt 13,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,112,1,4,8,15,2,56,3,2,9,15 .byt 13,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,56,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,125,3,2,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,236,1,5,8,15,2,89,3,2,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,246,1,2,8,15,2,123,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,169,3,1,9,15 .byt 13,2,8,0,9,0 .byt 1,6,0,151,1,5,8,15,2,221,3,1,9,15 .byt 14,1,9,0 .byt 1,3,2,250,3,1,9,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,236,3,5,9,15 .byt 14,1,8,0 .byt 1,3,0,125,1,2,8,15 .byt 14,1,8,0 .byt 1,7,0,56,1,2,8,15,9,0,2,112,3,4,9,15 .byt 30,2,8,0,9,0 ;-- unsnip .byt 1,3,8,0,9,0,10,0 ; .byt 0,0 .byt 128,128 ;=== end of song dataend: ; so we have the end of the data in the list file ;.end Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 I'm going to look through the code and document some things before posting the rest. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 The disassembled interrupt player set the rolling timer on the VIA to $40FF and the value I had calculated for 60Hz when I wrote the Oric code was $4100. At some point I'll have to look into the discrepancy. Quote Link to comment Share on other sites More sharing options...
JamesD Posted December 18, 2012 Share Posted December 18, 2012 (edited) Total code + variable size for the demo (with my latest changes) is 269 bytes but clearly some of that isn't needed and it doesn't have to reside on one page. 28 bytes are for the test player and that code would be part of the patches somewhere else. Keep in mind the following do not include any code required for patches to the existing Donkey Kong code. This is in addition to that. Each routine for playing a specific song is 13 bytes in length. 4 levels + play "how high can you climb" + play "opening screen" + play "made it to the top tune" So 7 songs at 13 bytes = 91 bytes. Ouch. Well, the 6502 isn't exactly known for code density. If all the songs are small enough to fit on one memory page, we can set the MSB once and dump 5 bytes per play routine, dropping each to 8 bytes. If one of those routines is set right in front of the playsong routine we can shave off 3 bytes by letting the code just fall through. So 7 * 8 - 3 = 53 bytes required for routines to play individual songs. The interrupt handler is 101 bytes and I can shorten that a few bytes if I yank out the "playing" flag and just disable the interrupt output from the timer. You can't test for the end of a song but Donkey Kong doesn't seem to need that. I believe it drops 16 bytes from the entire player code. If songs don't cross a memory page I can drop 4 more bytes making the actual player interrupt around 93 bytes. I am reordering some code so I can reuse a load here or there and save a few more bytes in various places but I think I've only saved 4 or so bytes that way so far. The difference between my timer value and the disassembled code allows one more reuse of a load so that may be why they used that value. <edit> Do we have enough memory for that? Edited December 18, 2012 by JamesD Quote Link to comment Share on other sites More sharing options...
