awesp #1 Posted June 26, 2013 Greetings all, I have two (soft) disks that contain the APESoft Expanded Basic routines. These routines were later included in the Mechatronics Extended Basic II Plus cartridge. The disk files are: mecha2.dsk (the actual routines) graphxb.dsk (example programs) The program that loads them into memory ('LOAD') is: 10 CALL INIT 20 CALL LOAD("[email protected]") 30 CALL NEW (The file '@XGGENINT' as well as 'LOAD' are both located on DSK1 - mecha2.dsk) However, after RUNning the 'LOAD' program, the routines do not work. If I try to initialise them with the command 'CALL APESOFT', I get the error message 'SUBPROGRAM NOT FOUND'. The same happens if I try any of the other routines. I'm running TI Extended Basic and I have a CF7+ installed, so it shouldn't be a memory problem. Would anyone know how to get this routines to work correctly? Any help/ideas/suggestions would be greatly appreciated. Adam Quote Share this post Link to post Share on other sites
Tursi #2 Posted June 26, 2013 It's almost guaranteed that the functions are accessed via CALL LINK... maybe try CALL LINK("APESOFT") and see if that starts it up? A CALL LOAD in itself can not add subprograms, as far as I know (or if it did, it would only be by adding them to the program, so you'd see them in a LIST). Quote Share this post Link to post Share on other sites
senior_falcon #3 Posted June 26, 2013 (edited) I think what is happening is that the LOAD program expects to see the mechatronics XB cartridge in the slot. I don't think CALL NEW is valid in standard XB and I know that CALL APESOFT is not. The CALL LOAD in line 20 should load the assembly subroutines into low memory using the slow XB assembly language loader, but these don't show up in the program.. Tursi's advice is good - if these routines worked with regular XB then there must have been a CALL LINK to something instead of the CALL APESOFT. If CALL LINK("APESOFT") doesn't do the trick the following program should display the contents of the DEF table; 10 FOR I=16376 TO 0 STEP -8 20 CALL PEEK(I,A,B,C,D,E,F)::PRINT CHR$(A)&CHR$(B)&CHR$( C )&CHR$(D)&CHR$(E)&CHR$(F) (take the spaces out of CHR$( C )) 30 NEXT I (i think it is CHR$ - it's the one that is the reverse of ASC) This isn't tested but should work. Stop the program when it starts to print garbage. It will show the names of all the assembly subroutines Edited June 26, 2013 by senior_falcon Quote Share this post Link to post Share on other sites
mizapf #4 Posted June 26, 2013 Yes, CALL NEW is a subprogram of "Extended Basic Plus" or "Mechatronic/PS Extended Basic" (try in MESS with the cartridges "me_extended_basic.rpk" or "extended_basic_plus.rpk"). Quote Share this post Link to post Share on other sites
awesp #5 Posted June 26, 2013 Thank you very much Tursi, senior_falcon and mizapf for your suggestions. I'll give them a go! Quote Share this post Link to post Share on other sites
awesp #6 Posted June 26, 2013 (edited) Hi Tursi, senior_falcon and mizapf, I run the program suggested by senior_falcon and I did get the contents of the DEF table: GRAFIC SETCOL ARCUS etc. I tried running some of the commands using the CALL LINK statement and most of them worked. Some didn't. I guess this is due to the fact that I'm using as a language guide the manual of the Mechatronics cartridge and not the original APESOFT manual (I couldn't find this one). For example, CALL LINK("GRAFIC",0) gives me a 'BAD ARGUMENT' error message, so I guess the parameters of this command must have changed between the original APESOFT routines and the Mechatronic's. Edited June 26, 2013 by awesp Quote Share this post Link to post Share on other sites
awesp #7 Posted June 26, 2013 (edited) Hi Tursi, senior_falcon and mizapf, I run the program suggested by senior_falcon and I did get the contents of the DEF table: GRAFIC SETCOL ARCUS etc. I tried running some of the commands using the CALL LINK statement and most of them worked. Some didn't. I guess this is due to the fact that I'm using as a language guide the manual of the Mechatronics cartridge and not the original APESOFT manual (I couldn't find this one). For example, CALL LINK("GRAFIC",0) gives me a 'BAD ARGUMENT' error message, so I guess the parameters of this command must have changed between the original APESOFT routines and the Mechatronic's. Edited June 26, 2013 by awesp Quote Share this post Link to post Share on other sites
+RXB #8 Posted June 26, 2013 Yes, CALL NEW is a subprogram of "Extended Basic Plus" or "Mechatronic/PS Extended Basic" (try in MESS with the cartridges "me_extended_basic.rpk" or "extended_basic_plus.rpk"). RXB has CALL NEW and CALL BYE and CALL XBPGM("device.volume.xbprogram",#files to open) The CALL XBPGM opens the number of files does a NEW then runs the program all from one command. Only RXB has this feature. Quote Share this post Link to post Share on other sites
+Ksarul #9 Posted June 26, 2013 The disk version of APESoft will should work with any Extended BASIC cartridge, as that was the environment they were targeted to. I'll have to pull out my original APESoft manual and check. You can also look in the Amerisoft Expanded Graphics BASIC manual, as that was just the English Translation of the APESoft manual. Quote Share this post Link to post Share on other sites
awesp #10 Posted June 26, 2013 (edited) Thanks RXB and Ksarul for your responses. I found the Amerisoft Expanded Graphics BASIC manual and gave its instructions a try. For some reason some of the commands don't seem to work, like CALL LINK("GRAFIC",0) produces a "BAD ARGUMENT" error message and CALL LINK("WINDOW",10,10) generates a 'SUBPROGRAM NOT FOUND' error message. However, CALL LINK("SETCOL,16,6) and CALL LINK("RECT",1,1,30,20) don't produce any error messages. Running the program sent by senior_falcon I just realised that the 'WINDOW' command is not present in the APESOFT routines on mecha2.dsk, mind you 'GRAFIC' is. So, it seems that I may have a different version after all. Edited June 26, 2013 by awesp Quote Share this post Link to post Share on other sites
senior_falcon #11 Posted June 26, 2013 Let me put in a shamless plug for "The Missing Link" which can be found in the Development Resources section of this site. It offers pretty much the same graphics routines as apesoft, plus you can get support for it right here on this site! 2 Quote Share this post Link to post Share on other sites
awesp #12 Posted June 27, 2013 (edited) Thanks senior_falcon. I'm just getting back into the TI99/4a after 30 years and wasn't aware of 'The Missing LInk" extensions. I have already loaded them into my TI and am ready to try them. Thanks again for your help! Edited June 27, 2013 by awesp Quote Share this post Link to post Share on other sites
senior_falcon #13 Posted June 27, 2013 Welcome back! It's like riding a bicycle - it will all come back to you with a little practice. Quote Share this post Link to post Share on other sites
Opry99er #14 Posted June 27, 2013 Since you're on the Missing Link train, make a stop at the new XB256 station... It's a Gold Mine of goodness. Also a seniorfalcon offering. Some of the cooler features include full character sets, pixel scrolling, and a sound list converter/compiler/player. It's a truly awesome development environment when coupled with Classic99 and NotePad++. Quote Share this post Link to post Share on other sites
humeur #15 Posted June 27, 2013 For the apesoft work, you use the 32k memory obligatory. Jean Louis Quote Share this post Link to post Share on other sites
awesp #16 Posted June 29, 2013 Thanks Opry99er, I downloaded the XB256 package and it looks pretty impressive. I'll give it a go on mi TI. Thanks Jean Louis for your comments. I'm running a TI with a CF7+ that gives my TI an additional 32K of RAM. Quote Share this post Link to post Share on other sites
senior_falcon #17 Posted September 24, 2014 Here are the APESOFT graphics routines in case you want to give them a try. The program LOAD will move them into low memory. Then you have to CALL FILES(9) and NEW before using them. There is a manual in PDF form - I tried a couple of the sample programs to see if they work. This is much more limited than Missing Link. Unless I'm missing something, it is running in Graphics mode (like LOGO) which means you have nowhere near the full screen for your graphics, nor do you have the color control you get with the bit mapped mode in TML. I was wondering how they dealt with some of the XB vdp memory locations that are at awkward places for bit map mode. Now I know... APESOFT.zip 2 Quote Share this post Link to post Share on other sites
awesp #18 Posted September 24, 2014 Thanks senior_falcon. I'll give them a go, just out of curiosity. Quote Share this post Link to post Share on other sites
+Ksarul #19 Posted September 24, 2014 There were two versions of the APESoft routines as released in Germany/Austria, which may explain the original issue with missing routines during test. I think I may have both versions of the disk. . . Quote Share this post Link to post Share on other sites
senior_falcon #20 Posted September 24, 2014 These came from the Mechatronics XB cartridge in the Win994a simulator. Quote Share this post Link to post Share on other sites
senior_falcon #21 Posted September 25, 2014 (edited) Here is the LINES program adapted for the Apesoft graphics routines. Remember to CALL FILES(9) and then NEW before pasting this in. 100 ! LINES110 RANDOMIZE120 CALL LINK("GRAFIC",0)130 CALL LINK("WINDOW",5,9)140 CALL LINK("SETCOL",INT(RND*14)+3,2)150 RFV=INT(RND*13)-6 :: CFV=INT(RND*13)-6 :: IF RFV=0 AND CFV=0 THEN 150160 RTV=INT(RND*13)-6 :: CTV=INT(RND*13)-6 :: IF RTV=0 AND CTV=0 THEN 150170 RF=INT(RND*120):: CF=INT(RND*128):: RT=INT(RND*120):: CT=INT(RND*128)180 FOR I=1 TO 100 :: CALL LINK("SETTO",CF,RF):: CALL LINK("MOVETO",CT,RT)190 RF=RF+RFV :: IF RF<1 OR RF>120 THEN RFV=-RFV :: GOTO 190200 CF=CF+CFV :: IF CF<1 OR CF>128 THEN CFV=-CFV :: GOTO 200210 RT=RT+RTV :: IF RT<1 OR RT>120 THEN RTV=-RTV :: GOTO 210220 CT=CT+CTV :: IF CT<1 OR CT>128 THEN CTV=-CTV :: GOTO 220230 NEXT I240 FOR I=1 TO 500 :: NEXT I :: CALL LINK("CLSCRN"):: GOTO 110 If you play around with the apesoft grahics, they are set up to use x,y coordinates, so SETTO and MOVETO expect column first, then row. Missing Link expects row, then column as is usual in XB. Edited September 25, 2014 by senior_falcon Quote Share this post Link to post Share on other sites
+Ksarul #22 Posted September 25, 2014 The cartridge had the complete set of routines, so you've got everything you needed, Senior_Falcon. They were originally released on disk, as two separate subsets of the whole. I have a set of the original disks from APESoft. They aren't too common as originals even in Germany. Quote Share this post Link to post Share on other sites
