+SabertoothRetro Posted September 14, 2013 Share Posted September 14, 2013 Over the summer I picked up a used Lynx II bundle on Game Gavel. It worked great for a few months but the sound has recently stopped working. I've read that this is a common issue for the Lynx II and that either the capacitors or speaker may need replaced. Is this a simple repair? Or should I just get another unit as their relatively inexpensive? Thanks! Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted September 14, 2013 Share Posted September 14, 2013 (edited) It's probably the speaker or capacitor. Easy to repair. If memory serves the cap is 220uF, 10v or 16v will be fine. If you have a multimeter you can disconnect the speaker and check connectivity across the 2 connections, it should measure almost a short. If its open circuit you need a new speaker. There are equivalent speakers on EBAY, I think the impedance of Lynx 2 speaker is 16 ohm, and Lynx 1 speaker is 8 ohm (could have those wrong way around), it will be marked on the existing speaker. Edit: search this forum, I've also posted a few other threads about similar audio problems. Edited September 14, 2013 by GadgetUK Quote Link to comment Share on other sites More sharing options...
LX.NET Posted September 15, 2013 Share Posted September 15, 2013 You can PM me if you need an original replacement speaker for the Lynx II. Quote Link to comment Share on other sites More sharing options...
