thomas3120 Posted December 4, 2013 Share Posted December 4, 2013 Hello, Spending the last couple of days looking through many webpages and here searching on the forums..but no luck. Looking for the pinouts, preferably with a picture of that connector that somewhat resembles a telephone connector with numbered pins, etc... Closest I got was "The connector has: *Signal GND *+5V (Input) *Reset (input) *Rxd/Txd (Input/Output) " No numbering or picture/diagram to go by. Any help is appreciated. thomas 1 Quote Link to comment Share on other sites More sharing options...
adamcon Posted December 5, 2013 Share Posted December 5, 2013 Hello, Spending the last couple of days looking through many webpages and here searching on the forums..but no luck. Looking for the pinouts, preferably with a picture of that connector that somewhat resembles a telephone connector with numbered pins, etc... Closest I got was "The connector has: *Signal GND *+5V (Input) *Reset (input) *Rxd/Txd (Input/Output) " No numbering or picture/diagram to go by. Any help is appreciated. thomas Thomas, it is on here somewhere. BUT, all you need is a 6 wire telephone cord that flips the send receive lines, just the same way a phone works Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 6, 2013 Share Posted December 6, 2013 As far as the cable needed, it is an RJ12 6-conductor Reversed (or Twisted as some list it) cable. However, I don't recall ever seeing a pinout diagram of the cable or ADAMnet connector on the Keyboard or Memory Console, but it should be in the "ADAM Technical Manual" that was released by Coleco and available on the web. Check "The ADAM Resource" linked in the footer of my posts. Quote Link to comment Share on other sites More sharing options...
hardhat Posted December 21, 2013 Share Posted December 21, 2013 That is all of the information in the Adam Technical Reference Manual. But the good news is that I had the exact same issue, and I stopped and figured it out: http://adamcon.org/pipermail/coladam/2011q3/001719.html is the information that I found. Quote Link to comment Share on other sites More sharing options...
ZarK Posted February 17, 2014 Share Posted February 17, 2014 I plug my keyboard into the adamnet connector and it works. I then checked the schematics ( from here: http://ann.hollowdreams.com/programming.html ) and the adamnet, keyboard, and printer use this bus to communicate. In theory, I should be able to fashion a db9 connector to an rj12 and plu the printer into the adamnet or keyboard connector and have it work. Besides the disk drive, what other devices plugged into this bus? Quote Link to comment Share on other sites More sharing options...
adamcon Posted February 17, 2014 Share Posted February 17, 2014 I plug my keyboard into the adamnet connector and it works. I then checked the schematics ( from here: http://ann.hollowdreams.com/programming.html ) and the adamnet, keyboard, and printer use this bus to communicate. In theory, I should be able to fashion a db9 connector to an rj12 and plu the printer into the adamnet or keyboard connector and have it work. Besides the disk drive, what other devices plugged into this bus? Any ADAMnet device will plug into the "phone" ports on the front or side of the ADAM. This means the disk drive, auto answer device, maybe speech synthesizer, midi interface,clock, and the keyboard, in any order or either port. Quote Link to comment Share on other sites More sharing options...
NIAD Posted February 18, 2014 Share Posted February 18, 2014 Besides the disk drive, what other devices plugged into this bus? As far as the two phone jack style ADAMnet connectors on the Memory Console, the only hardware that uses these are the Keyboard and the Disk Drive... the Coleco made disk drive which also includes the modded disk drives that were made available in the late 80's as well as the Micro Innovations line of disk drives. Coleco developed some prototypes that attached to these ADAMnet ports, but they were never finished/released. Aside from that, the rest of the hardware that was developed for the ADAM either installed in the right side Expansion Bus or the three internal Expansion Slots. Quote Link to comment Share on other sites More sharing options...
