knusperfisch
where to get replacement track 0 sensor for 1050 disk drive?
Hi,
does somebody know the part number of the optcal fork sensor used in Atari 1050 disk drive?
thanks!
B&C/myatari.com list the following:
PRA048   TRACK 0 SENSOR TANDN 1050       10.00PRA047   TRACK 0 SENSOR WORLD 1050       10.00
More of a confession then helpful. At some of the track zero sensors can be ~hacked apart. Invariably, it is the infrared LED that has gone out. Just jerking around, I ground a regular red LED down to size, flat and square IIRC, and used it. Worked fine. I wish I still had that much energy and time! Probably only took me 8-10 hours.
If you are absolutely sure the sensor is bad, probably would save you a couple of bucks and some delays for shipping.
Thanks for the answers.
I know that there is a small sqare shaped IR led inside the case, but it is glued in place. I need to break the housing to remove it. The LED is dead because one pin broke off with my attempt to pull it out. I don't know if the photodiode works. Maybe not, because I accidentally plugged the header connector on the pins for the drive motor which maybe destroyed the diode as well.
I think I'll first experiment with a common fork sensor, to see if it works electrically. To mount that thing in place will be a bit of a challenge...
Working on an Indus GT - same mech - tandon.
I am getting a G5 error - which is a read error.   If I get the diags program running and switch this drive in.. so I can test.. many of the tests pass. But the track Zero sensor I cannot get to work.
In fact it should say move in or move out.. but I am just getting msg no feedback from sensor? or is disk inserted. SO I figure the sensor is bad.. is there a test to make sure I am replacing the correct part?
I have a bunch of 1050s around.. I am thinking maybe swapping a mech out.. except the part of changing the indus controller card.. so.. maybe swapping a zero sensor in?
James
Posted (edited)
Mouser.com has the replacement of the sensor for 1050 according to some YouTube video I saw.
I have not tested myself if it work, but I see no problem with it.   The part number is opb842w51z as mentioned before. Not sure it will work with Indus.
Edited by manterola
