fdurso224
The Official NEO-GEO Thread!
Hey folks!
Newest NEO GEO title in my "20 From" series, this is the gorgeous PULSTAR by Aicom and SNK in 1995.
The graphics include pre-rendered and anime-style. The game is VERY difficult and it's a bit frustrating that touching water kills you! Otherwise, great power ups and it's cool that you can increase your firepower just by shooting rapidly!
Hey Russ,
Thank you for sharing your Pulstar video with us. Certainly one of the best Neo-Geo titles and shooters out there in the video game industry. Glad you enjoyed it nd keep up the great work bro. :)
Anthony..
Edited by fdurso224
Hi guys,
<再新作・稼働開始> お正月バラエティーゲームとして【ちびまる子ちゃん まる子デラックスクイズ】を只今より稼働開始いたします。豪華声優とアニメーションはファンも納得の良作です。 PS:家庭用NEOGEO版は史上最大のプレミアムソフトです。
Translated from Japanese by BingWrong translation?
As new year variety game (again new and work started) [Chibi Maruko-Chan I like child Deluxe squeeze] will start working more now. The gorgeous voice and animation fans are convinced of is. PS: household NEOGEO Edition is the largest premium software.
0 replies5 retweets4 likes
Reply
Retweet
Liked
Anthony...
Edited by fdurso224
Hi guys,
<再新作!好評稼働中> 【新・豪血寺一族 闘婚 -Matrimelee-】ボタン配置選択可能NEOGEO対戦台にて稼働中です。システムや技表はコチラ http://www.noise.co.jp/game/toukon/index.htm 濃い〜世界観の名(迷)作 豪血寺一族の第5作目、是非お楽しみ下さい。#neogeo
< Again new! Favorable reviews > [new-Australia-blood Temple clan fighting marriage-Matrimelee-: NEOGEO battle units can be selected button placement is running. Systems and technology table click here for http://www. noise.co.jp/game/toukon/index.htm dark-please come and enjoy first 5 name of the world (weak) by Australian blood Temple clan. #neogeo
0 replies3 retweets3 likes
Reply
Retweet
Liked
Anthony...
Hi guys,
<再新作・好評稼働中> ネオジオゲームより2本の良作が只今、好評稼働中。【キングオブモンスターズ2】【ショックトルーパーズ・セカンドスカッド】共にネオジオ純正筐体にて稼働です。良作の両作品、ファンも多いゲームですので是非お楽しみください。 #Neogeo #snk
Neo Geo games (again new and favorable reviews) than two good is now a very popular running. King of monsters 2 [shock troopers, second Scud] Neo-Geo genuine enclosure in the production is both. Good because it is a game made two works, the fans come and enjoy. #Neogeo #snk
0 replies0 retweets3 likes
Reply
Retweet
Liked
Anthony..
Hi guys,
<好評稼働中> NEOGEO名作STGの【ビューポイント】と【ブレイジングスター】、ネオジオ純正33インチ筐体にて稼働中です。3.5mmヘッドホン端子もMVS用メモリーカードも使用出来ます。
< Popular running > NEOGEO classics STG [view point] and [blazing star] Neo-Geo genuine 33-inch enclosure is running. 3.5 mm headphone jacks also for MVS memory cards can be used.
0 replies2 retweets6 likes
Reply
Retweet
Liked
Anthony...
Hi guys,
Cheap(ish) brand new Neo Geo CD/CDZ/AES joystick
The Neo-AEC joystick for the Neo-Geo AES was the first truly great joystick controller for a home video game system. If you’re collecting AES or NGCD systems today, they can be expensive and difficult to get ahold of. Average shape used copies are typically in the $100 range, and new old stock can run $150 and up.
Fortunately, the re-released USB version for the Neo Geo X is the same build quality and readily available for $40-$50. With a $15-$20 replacement cable and a little legwork, this can be readily converted to use on any of the vintage Neo-Geo systems.
You’ll need:
  • Neo-Geo X Arcade Stick ($40, Amazon)
  • Replacement lead ($13, eBay)
  • Soldering iron & solder
  • Multimeter or ohmmeter
  • #1 Philips screwdriver
  • Wire cutter/stripper
  • Scrap wire
  • Heat-shrink tubing & heat gun, or electrical tape
  • Around 45 minutes to put it all together
Start by flipping over the joystick and removing the rubber feet, which cover four screws. Set the feet aside, as you’ll be reinstalling them afterwards, and remove all five screws (four under the feet, one visible at front center).
Carefully separate the halves to reveal the controls & USB encoder.
Interestingly, the RoHS soldering is all performed by hand. The layout is very simple, and most pins are labeled. GND is on the center pin of the 3p connector to the start/sel board, as well as the unlabeled 5th pin by the direction pins.
We’re going to solder the replacement cable’s leads onto the main PCB.
Unfortunately, the wires for the new cable aren’t long enough to reach the posts we want to solder to. The strain relief that fits into the plastic case is moulded into the cable, so can’t be moved. We’re going to use the scrap wire to extend them.
Okay, next we need to make sure we get the wires soldered to the right pins. Refer to these pinouts:
The bottom of the DA-15S pinout is the connector on the new cable. With your meter set to continuity check, stick a probe into pin 1 of the connector and locate the wire on the other side. Bend the end of it into a hook shape, then do the same to one of your pieces of scrap wire. Solder them together, then insulate with tape or heatshrink tubing. Strip the end of the scrap and tin it with your iron, then solder to the correct labeled pin on the joystick PCB. Repeat for the rest of the pins, making sure to connect 4 AND 9 to the D button, and set 2, 8, and 10 aside. These should be trimmed so no wire is exposed and insulated so they don’t short against anything — pin 8 has +5v on it.
If you used heatshrink tubing, shrink it down now, otherwise make sure the solder joints are wrapped with electrical tape. Coil up the USB cable and tuck it in the front of the housing. If you want to switch back to USB down the road, you can open it back up and swap the cable coming out the back.
Because there’s +5 on the connector and it’s easy to mix wires up, I suggest that you use your meter to compare against a factory controller prior to connecting to your console. It takes a few minutes, but could save you significant time, hassle, and money.
Once you’re feeling good, button it all back up and play some games with your brand new joystick!
arcade joystick snk neo-geo aes hacks tech
Anthony...
Hey guys I wanted to give an update on my Neo Geo games by meg count video. I got around 1 fifth of the games covered but my midterms are coming up soon so it may take longer than expected.
That's not a problem Evan! :)
When you feel your video is ready to be showed, I'll gladly post it onto the thread for you.
Thank you for the heads up. :)
Anthony...
Hi guys,
Back with Colin Mackin having fun as usual. Here we se him in action playing Pleasure Goal for the Neo-Geo. Enjoy. :)
Anthony...
