Shawn Posted May 29, 2014 Share Posted May 29, 2014 Hmm. I guess a higher score is worth the trade off in using the uglier paddles over the iconic ones then. Hmm. I guess a higher score is worth the trade off in using the uglier paddles over the iconic ones then. The resistance level of the pointometer could be used to the same effect without sacrificing the cosmetic looks. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted May 29, 2014 Share Posted May 29, 2014 (edited) Great work by everyone that can do this sort of thing! One question, how hard are these to make? Meaning what skill level should one have to make these? Mine are limited at best so I doubt I could do it. Is the posted video the only guide or is there another one people have used? Just curious more than anything. Edited May 29, 2014 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted May 29, 2014 Share Posted May 29, 2014 Is the rom available? Or are you the gatekeeper? Or is he the Keymaster? Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted May 29, 2014 Share Posted May 29, 2014 How well would this controller work with 5200 Tempest? 1 Quote Link to comment Share on other sites More sharing options...
Prosystemsearch Posted May 29, 2014 Author Share Posted May 29, 2014 How well would this controller work with 5200 Tempest? better than the Joystick, that's for sure. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted May 29, 2014 Share Posted May 29, 2014 better than the Joystick, that's for sure. Actually, this recently finished and released version of Tempest plays excellent with the CX52 analog Joystick. http://atariage.com/store/index.php?l=product_detail&p=1014 2 Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted May 29, 2014 Share Posted May 29, 2014 I would assume a lot of 5200 games would work fine with paddles - from a hardware recognition standpoint - because due to the analog nature of the 5200 joystick and the POTs, the joystick is a paddle. As such, Space Invaders should really work well with a paddle controller. Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 2, 2014 Share Posted June 2, 2014 What would happen if the Driving controller pot was used in the 5200? Would I be able to spin it completely around and have tempest act accordingly? Is there an upper/lower limit? Quote Link to comment Share on other sites More sharing options...
joystickjedi Posted June 2, 2014 Share Posted June 2, 2014 What would happen if the Driving controller pot was used in the 5200? Would I be able to spin it completely around and have tempest act accordingly? Is there an upper/lower limit? That'd be so good. First Tempest, then Gyruss. Heck, even make a spinning wheel for Pole Position. 1 Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 4, 2014 Share Posted June 4, 2014 (edited) i too made a paddle i used an old pc superjoy carcas a sears pong pot and knob and one more button i used to have the top button be start but then i realized it was impossible to play moon patrol with the jump button all the way on the other side so i made the right button (start) some little things for people wanting to make their own #1 you have to use the opposite lug on the pot from an atari paddle as it is reversed on the 5200 #2 paddle pots are 1 meg ,5200 pots are 500k so along with the wires you attach to the pot jump those lugs with a 1 meg resistor so when you play games you get more travel and thus more precision you can do it with 8 conductor cable you dont need to go out and buy 15 conductor wire 3 wires for the buttons and ground 2 wires for the start button (pin4,pin7) and 2 for the x and pot common i'm soldered the Y to the remaining wire and was going to add a switch so i can change gears ,the switch would just have a 1 meg resistor across it so it would either but full up(shorting the resistor) or full down y and common connected through the resistor Edited June 4, 2014 by bohoki Quote Link to comment Share on other sites More sharing options...
boxpressed Posted June 4, 2014 Share Posted June 4, 2014 How well would this controller work with 5200 Tempest? Mine don't work so well with Tempest. I'm not sure if this is a problem with my controllers or the game itself. Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 4, 2014 Share Posted June 4, 2014 Mine don't work so well with Tempest. I'm not sure if this is a problem with my controllers or the game itself. its the game they did the control the best they could with the controllers available unlike say gorf,superbreakout,kaboom that have edges so you can have absolute positioning tempest goes around and around so it would need a spinner a trackball can simulate a spinner but i dont think this game is programmed to do that they also could have used the same joystick scheme as gyruss but nope Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted June 5, 2014 Share Posted June 5, 2014 The trackball simulates a spinner just fine in Tempest. The original release of the game had a problem with the trackball code, but the fixed release plays excellent. Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 5, 2014 Share Posted June 5, 2014 So would a driving controller pot work? Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 5, 2014 Share Posted June 5, 2014 its not a pot its a 4 bit encoder wherever dial is one way it counts up the other counts down Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 11, 2014 Share Posted June 11, 2014 Great work by everyone that can do this sort of thing! One question, how hard are these to make? Meaning what skill level should one have to make these? Mine are limited at best so I doubt I could do it. Is the posted video the only guide or is there another one people have used? Just curious more than anythingI I just completed making a 5200 paddle controller. It's pretty easy. I would say if you know which end of the soldering iron to hold, you are half way there. A beginner should be able to do this in about an hour. I used a 1 3/16" washer to act as a plate to tighten down the pot from a 2600 paddle. I had to widen the hole in the washer since the pot wouldn't go though it. That is what my dermal is for. Then it is a matter of soldering the brown wire to the center post and the black wire to right post and putting it all back together again. I also put in a new rev 9 flex circuit. Super breakout works great! 2 Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted June 12, 2014 Share Posted June 12, 2014 (edited) I just completed making a 5200 paddle controller. It's pretty easy. I would say if you know which end of the soldering iron to hold, you are half way there. A beginner should be able to do this in about an hour. I used a 1 3/16" washer to act as a plate to tighten down the pot from a 2600 paddle. I had to widen the hole in the washer since the pot wouldn't go though it. That is what my dermal is for. Then it is a matter of soldering the brown wire to the center post and the black wire to right post and putting it all back together again. I also put in a new rev 9 flex circuit. Super breakout works great! You didn't use a Best Electronics Super Paddle POT replacement? Edited June 12, 2014 by Lynxpro Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 12, 2014 Share Posted June 12, 2014 No, I went with the cleaned up 50 cent thrift store paddles for a donor. All you have to do is spray a little bit of electronics cleaner in the POT and turn the POT about a hundred times. Works just as well as the Super Paddle POT replacement. Besides, any electronics store would have 470 ohm potentiometer for about dollar or less. 1 Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 12, 2014 Share Posted June 12, 2014 470,000 ohm 470k ohm Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted June 13, 2014 Share Posted June 13, 2014 Late to the party, but I actually have one of the protos. It's been on display at most of the CGE's I've toyed with the idea of bringing it to Vegas this year and auction it off. Still thinking. I found it back in 98 I believe. 3 Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 13, 2014 Share Posted June 13, 2014 That's pretty cool! How well does it work vs a home made version? Also, what games can I play with this thing except Super Breakout? Too bad Tempest isn't playable with it. Quote Link to comment Share on other sites More sharing options...
Bakasama Posted June 13, 2014 Share Posted June 13, 2014 Since 5200 paddle controller is just a 5200 controller modded with a washer, a paddle pot, and a paddle knob, has anyone thought of putting a 2600 driving controller encoder inside 5200 controller and finding out if that works? Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 13, 2014 Share Posted June 13, 2014 Bohoki shot me down on that idea. Quote Link to comment Share on other sites More sharing options...
+evg2000 Posted June 13, 2014 Share Posted June 13, 2014 It's great for Kaboom! Quote Link to comment Share on other sites More sharing options...
Master Phruby Posted June 13, 2014 Share Posted June 13, 2014 (edited) Space Invaders is not playable with it. I wonder why? Why would it care about the up/down part of the joystick? Is there something I should do with the extra wire from the old joystick pots? Should it be grounded to make Space Invaders work? So list of games that work: Super Breakout Kaboom Edited June 13, 2014 by Master Phruby Quote Link to comment Share on other sites More sharing options...
