Sign in to follow this
AtariChick
Ok, a question about a not working 2600
I finally found a power source....I plug it in...switch it on and it is just gray/black screen with a few lines....is this a wrong power source or something wrong with the system? help!!!!?!!!???
The power adapter kind of should match exactly.
Atari®
Part No. co16353
Plug in-Power Supply
For use with video game
used only with models cx-2000/2600
input: 120v 60 Hz 9w
output: 9v DC 500mA
- --(o-- +
I hope that helps.
Never mind....the power adapter I got has a switch to choose the voltage you want....i had it on 3 volts....*note to self* read package before freaking out...:P
are you using a universal adaptor for it? i was jsut wondering cause i was using one on a atari jr a couple of days ago and it blew up literatly. it made a big pop sound and then shut off then smoke was running outta it i unplugged it and waited till the next day pluged it in with a real adaptor and it worked again but i was enough to turn me away from ever using uni adaptors again i hope what your using isn't a uni adaptor
I've used universal adapters on various consoles with no problem at all. You just have to make sure you have it set to the correct specs.
