Madi Posted August 11, 2014 Share Posted August 11, 2014 (edited) With reference to the Firmware, after scanning all my roms I found these were missing, could anyone fill them please? The ones in solid black after the U1mb rom... @ Mclaneinc I have the Same status. I think, Altirra scanning for ROMs is not accurate. Actually, I have the following ROMs inserted and working, I do have all other ROMs except for the BLACKBOX rom but did not play with the rest yet. 1200XL Kernal ROMs - Installed working rom Ultimate1MB ROMs - Installed working rom (my default setup now ) MyIDE-IIROMs - Installed working rom (need to disable SIDE/Ultimate 1MB hard disk before accessing the MYIDE disk) SIDE ROMs - Installed working rom SIDE 2 ROMs - Installed working rom Madi Edit : The above are the missing ROMs as per Altirra scanning .. But they are inserted and working Edited August 11, 2014 by Madi Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 11, 2014 Share Posted August 11, 2014 Thanks Jon and Madi, hopefully the blackbox roms will turn up, again, thank you. Quote Link to comment Share on other sites More sharing options...
mono Posted August 11, 2014 Share Posted August 11, 2014 (edited) I have Altirra 2.50 official release. My Altirra config is: - SDX 128K cartridge, - vbxe enabled, - atari 600/800 xl, - 320 rambo extram (no Axlon extensions), - slightsid enabled, - ultimate disabled. When I disable SDX cartridge by JHWCTRL and disable all ROM areas by PORTB ($FE) then any write operation into $A000..$BFFF area does nothing. This range contains $FF values. Debugger shows: Altirra> .bankBank state: FE Kernel ROM: disabled BASIC ROM: disabled CPU bank: disabled Antic bank: disabled Self test ROM: disabledAntic bank: $000000CPU bank: $000000Cartridge 1 bank: disabledCartridge 2 bank: disabled Could you fix it? Edit: I'm sorry, but I didn't saw new 2.60-test2 revision - this bug is fixed Thank you. Edited August 11, 2014 by mono Quote Link to comment Share on other sites More sharing options...
serj Posted August 11, 2014 Author Share Posted August 11, 2014 Madi, please can upload rom images here? Quote Link to comment Share on other sites More sharing options...
Madi Posted August 11, 2014 Share Posted August 11, 2014 Madi, please can upload rom images here? The zip file doesn't contain the ROMs listed by Jon :http://atariage.com/forums/topic/228110-altirra-250-final-out/page-3?do=findComment&comment=3051107 I included the original Ultimate 1MB and my current flashed one as an alternative of flashing a new one. Madi ROMS for Altirra.zip Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 11, 2014 Share Posted August 11, 2014 Questions about Altirra screen display: I have Altirra set as an NTSC 800XL with Rambo 320K. The display is somewhat blurry, and I'm wondering if there is some setting to sharpen it? I've looked through the HELP topics and see nothing there, and when I click on "filter sharpness" it is grayed out (can't find a setting that activates that menu). Can someone shed some light on this? Thanks, Larry Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 11, 2014 Share Posted August 11, 2014 Try a different filter mode, Larry. Only "Sharp Bilinear" enables the Filter Sharpness menu. Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 11, 2014 Share Posted August 11, 2014 Thanks, Jon. I experimented with it, and It doesn't really seem to have any effect that I can see. I went to the stretch mode and set it to preserve aspect ratio (even multiples only), which shrinks the screen maybe 20%, and that *seems* to make it a bit sharper. -Larry Edit: Perhaps it is not so sharp as I compare it to my All-in-Wonder Atari display because the AIW is a scan rate/line doubler. (?) If that is true, that might make a nice addition for a future version of Altirra. Quote Link to comment Share on other sites More sharing options...
serj Posted August 11, 2014 Author Share Posted August 11, 2014 I did not understand that it is necessary to specify for myide 1 & 2, and blackbox. spread your configuration and images. Avery, in the settings of "Firmware images" you forget the built-in game for xegs. still would like to ask whether the added mapper "Corina" for the game Yie Another Kung-Fu. Altirra-2.60-test2_my_config_&_bios_images.zip Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 11, 2014 Share Posted August 11, 2014 I like to use VBXE mode (even if I'm not accessing the hardware), since it provides a nice, crisp emulated RGB picture. I think Altirra does a really good job of emulating the video characteristics of the Atari, and I think the kind of moire effect shown below is really down to the host's display driver: Same kind of effect you get running an ST in hi-res on a 1024x768 LCD. Enlarging the display window completely eliminates the moire, though, as the effect of interpolation is lessened by the increasing resolution. Quote Link to comment Share on other sites More sharing options...
Xuel Posted August 11, 2014 Share Posted August 11, 2014 I have Altirra set as an NTSC 800XL with Rambo 320K. The display is somewhat blurry, and I'm wondering if there is some setting to sharpen it? I've looked through the HELP topics and see nothing there, and when I click on "filter sharpness" it is grayed out (can't find a setting that activates that menu). Can someone shed some light on this? You can use these settings to get crisp square pixels on the pixel boundaries of your monitor: - View -> Filter Mode -> Point - View -> Stretch Mode -> Square Pixels (fixed multiples only) - Resize window until desired zoom fits. Note you'll only be able to get integer zooms, e.g. 2X, 3X, etc. The display will "pop" when you make it big enough to fit the next size. Though square pixels may be too harsh for some tastes. It's great for debugging graphics but not so great for simulating what it will look like on a CRT. For that, turn on System -> Video -> PAL Artifacting (high) and maybe View -> Filter Mode -> Any suitable. 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 11, 2014 Share Posted August 11, 2014 Larry, you also might have Artifacting set on, its in the video menu.. You also might want to go to tools / options and then the display tab to see what you have for GUI settings per driver, I normally have directdraw and direct3d9 ticked.. Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 11, 2014 Share Posted August 11, 2014 Thanks, guys. I'll give those settings a try. -Larry Quote Link to comment Share on other sites More sharing options...
Madi Posted August 11, 2014 Share Posted August 11, 2014 I tried to insert the Ultimate 1MB in the Altirra-2.60-test2 without success. Also, the Hard Disk option from "System" is not available. On the contrary, Altirra is running monthly under the 2.50 final version. madi The image of what I get under v2.6 test2. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 11, 2014 Share Posted August 11, 2014 Thanks Jon and Madi, hopefully the blackbox roms will turn up, again, thank you. Look towards the bottom of Mathy's page for the BlackBox ROM's: http://www.mathyvannisselroy.nl/blackbox.htm Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 11, 2014 Share Posted August 11, 2014 (edited) Thanks AG.. @Phaeron, is there a reason the rom scan does not pick up these items? It would be great to know what versions are correct in respect to what you have used to coded around. Thanks. Edited August 11, 2014 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
serj Posted August 12, 2014 Author Share Posted August 12, 2014 Madi, select option in System-->device-->hard disk For hard disc activate. Sorry for my english, writing for smartphone. Quote Link to comment Share on other sites More sharing options...
danielcg Posted August 12, 2014 Share Posted August 12, 2014 @Phaeron, I like to add adjustable dead zones for joystick axles in input mapping dialog for Altirra. Right now, Altirra has fixed dead zones for joystick axles and did not show up in input mapping edit dialog. My main control panel (not Altirra related) for my Thurstmaster Power 3 controller does not have adjustable dead zones, but however it does have adjustable forces (Vibration). Quote Link to comment Share on other sites More sharing options...
AnnaWu Posted August 12, 2014 Share Posted August 12, 2014 I tried to insert the Ultimate 1MB in the Altirra-2.60-test2 without success. Also, the Hard Disk option from "System" is not available. On the contrary, Altirra is running monthly under the 2.50 final version. madi The image of what I get under v2.6 test2. ditto! Also some problems exist to scan the ROMs. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 12, 2014 Share Posted August 12, 2014 http://www.virtualdub.org/beta/Altirra-2.60-test3.zip http://www.virtualdub.org/beta/Altirra-2.60-test3-src.zip Fixed the mixup in the hard disk dialogs, added missing XEGS game ROM category, made firmware loader prefer external firmware images over internal ones, added some missing .arc filters in file dialogs, changed the filter default from bilinear to sharp bilinear (+1), and removed the Ctrl+F1 filter shortcut by default (you will need to reset keyboard shortcuts to see this if you have already run Altirra before). You need a 3D card capable of at least pixel shader 2.0 in order for the sharp bilinear setting to work. For the All-in-Wonder line, you will need at least a 9600 for this to work -- the original 7xxx and 8xxx series is too old. And if you have the original Rage based AIW... you're probably better off with software rendering. The Direct3D 9 or 11 display modes must also be active. If you have selected OpenGL or for some reason don't have 3D acceleration then you also won't get sharp bilinear. The firmware image scan can only pick up images that are known. Currently it has entries for the original 5200, 800, XL/XE, XEGS, and 1200XL kernel ROMs, as well as the three main Atari BASIC revisions. It can't really pick up the other types of images because there's no solid way to detect that a ROM image is for, say, IDEPlus. I'm thinking of changing the Add dialog so that it asks what type of image is being chosen instead of having it determined by what category is selected, which is obscure. Currently all firmware types other than OS kernel and BASIC can only have one firmware bound, as there is no place to choose it. Thought is that adding a way to mark an entry as (default) in the firmware dialog will allow for switching the more seldom used types of ROMs without cluttering up the main menus. Quote Link to comment Share on other sites More sharing options...
bfollett Posted August 12, 2014 Share Posted August 12, 2014 Working like a charm now. Of course much of the program is running too fast now, but that's what I wanted to see. Bob I may have spoken too soon, there is one more spot in the program where something doesn't appear to be working correctly with Altirra basic. I believe somewhere between line 3000 to 3050. After you've answered all 12 multiplication problems, the display at the bottom should flash and beep with the number of problems you got correct several times, but with Altirra basic it doesn't work correctly. Bob Quote Link to comment Share on other sites More sharing options...
AnnaWu Posted August 12, 2014 Share Posted August 12, 2014 Fixed the mixup in the hard disk dialogs, added missing XEGS game ROM category, made firmware loader prefer external firmware images over internal ones ... Thanks for the fix. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 12, 2014 Share Posted August 12, 2014 I may have spoken too soon, there is one more spot in the program where something doesn't appear to be working correctly with Altirra basic. I believe somewhere between line 3000 to 3050. After you've answered all 12 multiplication problems, the display at the bottom should flash and beep with the number of problems you got correct several times, but with Altirra basic it doesn't work correctly. Bob $3B18: 3010 COLOR 8: X=BROW(CORRECT): Y=153: FOR I=1 TO 20: IF PEEK(200)=7 THEN COLOR 8: SOUND 0,30,10,6: GOTO 3020 {end $3B99} You used an illegal PEEK to get the current color!! atbasic.bin Quote Link to comment Share on other sites More sharing options...
Keatah Posted August 12, 2014 Share Posted August 12, 2014 Thrilling! Absolutely thrilling! Another release of Altirra.. Every time a new version comes out I feel like I'm taking my Atari apart and adding in an upgrade. Or going to a store (in 1980) and purchasing new hardware. 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 12, 2014 Share Posted August 12, 2014 @keatah, that is exactly what I was thinking... I feel like I'm back in Silica Shop in Sidcup and just brought that new upgrade and all excited to get home and fire it up. That most likely sounds rather daft to others but evey time Avery updates Altirra I feel like although I may not use all the added things, that I have the best Atari out there.. Thanks as always Avery... 1 Quote Link to comment Share on other sites More sharing options...
